Hyundai Santa Fe Brake Problems
I have a 07 SantaFe AWD 7-passenger version.
The engine is 3.3L, I noticed a problem that almost happens every time after I start up the car and try to accellerate very slowly through 30KMs.
As soon as it hits 30KM in speed, I can feel a very small feedback from the gas pedal, I can also hear the 'click-click' sound when it happens. It feels like something is trying to be hooked up at that time. The weird thing is, this only happens only the first time I accellerate through 30KMs after I start up the car. After that, as long as the car is still running, even if I reduce the speed to 0 and try hit on gas to go beyond 30KMs (very slowly) again, it doesn't happen. So it happens only the first time I start up the car.
I took it to a hyundai service but the mechanic couldn't feel anything during a test drive. But the problem still happens almost on a daily basis, esp. for a cold start (parked overnight).
Anyone has any suggestions?
Now, if your make/model doesn't have ABS, then I don't know what to think.
The feedback (clunk, clunk) is very similar to what you'd feel from the brake pedal when ABS kicks in on a slippery road.
And Yes my model does have ABS, I am pretty sure.
Is this a problem or simply the way it works?
Now I am feeling a bit better that I didn't buy a lemon.
I'm curious. Where would that be? 45° is quite extreme. The brake would have to support about 70% of the car's weight with that grade.
SUVs and Smart Shopper
We've TWICE asked the dealer to 'tighten it up'...it still rolls on even a gentle hill, until the Parking Pawl engages..but under heavy load, or steep slope, that is Not healthy for the transmission 'pin' that locks it in Park. In our use, we have a boat, and on the launch ramp, I assure you, you MUST use the parking brake to launch & retrieve. This brake, even when I step will all my weight to depress the pedal, it holds, but needs the assist of the parking pawl. This brake will not hold the vehicle from rolling on a gentle slope driveway. This is not my first car, all other vehicles would lock the tires and you'd drag them and flatspot them if you were silly enough to try....my point being, a parking brake should be THAT strong, to not allow any tire rotation. Anybody else have SUCCESS with the dealer on this issue????
Find a safe place to do this with a SLIGHT incline. Park your SantaFe and turn the engine off. Place the car in Neutral and take off the parking brake (the car should start to roll down the incline). Press the brake (it should feel normal, very little pressure like when you normally drive). Press the break maybe 10 more times and you will use up all the left over vacuum in the lines. Now, it’s VERY hard to stop. Does it feel the same as when you start the car (I would guess yes). If so, you know you have either a vacuum leak or power booster leak. Go ahead and start your car again and you’ll feel the brakes are easy to push again. You can put a vacuum gauge on the power booster and watch it over night (if possible) and see if it goes down (it will somewhat). I would guess you most likely have a bad power brake booster. Flushing will have no effect on this, nor replacing pads. It’s further up the line. Good Luck
I had the same problem with the rear brakes at only 14K miles. They started squealing Easter week and I didn't have a chance to get them looked at til after the weekend. By that time the rear left brake had eaten into my rotor so much that I needed it replaced. I am going to call my Hyundai dealer and let them know this is BS. If you have talked to them already let me know some feedback on how it went. Good luck to the both of us with this fight.
I hope I helped you.
At this point, I don't think there's any question to what the problem is - looking at the rotor, you can see it's been worn quite badly, particularly in comparison to the others.
Did the dealer/warranty cover the cost for you? Or am I looking at a big bill?
I'm rather upset that when the car was in 6 months ago they told me that nothing was wrong, particularly if it means I have to pay for a rotor (or two), when the rotor would have been fine if they had corrected the caliper issue.
The dealer replaced the pads on both sides of the rear, machined the rotors, and "corrected" the calipers to prevent seizing. All were covered under warranty.
I have to admit, I was muttering some bad things about Hyundai last night, but after how quickly they responded without giving us any trouble (other than the inconvenience of being without a car for a day), I have to take it back and compliment them on a job well done.
I hope anyone else with this same issue gets the same treatment we did, I'm quite satisfied with both Hyundai and my dealer.
never had this problem with other hyundais i owned , either elantras or sonatas.
Again, good luck.
Maybe the owner's manual is different up there (the Guide get the maintenance from the manual).
I like the Sonata and had been considering a Santa Fe until reading this thread. I doubt I'll buy another Hyundai mostly because the manufacturer won't own up to (and therefore take steps to solve) their problem which, by the way, is prevalent in Kias, too.
SDB1
Bob
