Mazda CX-7 AWD Questions
hi all
recently bought an AWD CX7.
Took it up to the snow and got bogged in just 6 inches of snow at the front axle. The back wheels had hardly any snow under them...
I tried to reverse very gently with TCS off, but all that happened was the front wheels spun freely, which dug the car further in. The rear wheels only started turning if I pressed the accelerator a bit harder. Finally had to get towed by a 'real 4wd'!!!
Is this how the CX7 awd system is meant to work? I thought the rear wheels would start turning as soon as the fronts lost traction?
Could someone please advise me. I don't think there's a problem with the car but it's something that's rather hard to test (without driving 3 hours to the snow and getting towed again!). I've kinda lost confidence in its ability now... :-(
thanks in advance
satz
thanks in advance
satz
Your email didn't mention if you tried to get "unstuck" with TCS engaged. TCS and AWD work seemlessly and there are no "indicators" that show when power or what percentage of power, is transferred to the rear.
Sometimes, all of this technology fails us. You only disengage TCS when other options fail. In the old days, before 4wd/AWD, if one got stuck in snow, one way was to rock the car, back and forth, by repeatedly shifting between fwd and reverse. Such is true with the CX-7, IF you disengage the TCS. TCS automatically senses loss of traction, then applies power to the rear axle. If AWD doesn't pull you free, you have to try the old fashioned methods.
BTW, CX-7 is basically a very light-duty off-road vehicle. It wasn't designed for extremes, so don't put too much confidence in the CX-7 to pull you out of a jam. Here in northern VA last winter, we had one pretty good snow storm and dumped about 1.5 feet snow is some spots. My CX-7 handled all of that with ease and I was bookin' down the freeway, when other drivers were ploddin along at 15 MPH in the slow lane. Here I was, troopin' along at 45 MPH ! I WAS IMPRESSED! :P
Vince.
My father in law has had no problems driving in the snow.
For my wife's new cx-7, I will buy winter tires. In massachusetts, they are worth having. Not mandatory though.
thanks for the responses to date. I actually tried both TCS off as well as on. Neither seemed to make any difference to the rear wheels getting power...
The tyres were new (the car was only 1 week old!) and were the Goodyear RSA mud and snow...
cheers
Satz
