Rodeo starter
My 02 Isuzu Rodeo wouldn't start. Turn the key on, it clicks one time, then nothing. I'm thinking starter solenoid, which I'm told is actually mounted on the starter. But, there is a cylinder shaped solenoid (?) mounted to a triangular shaped housing (about 3 inches) attached to the firewall. I tapped on that solenoid several times and the starter engaged and started. What is that solenoid (on the firewall)? Should I replace the starter.. or what?
