Transmission selector switch problems
1999 v6automatic with 144k miles. Gear shift in floor has one position and selector on dash has another. When this happens, transmission bucks when shifting. Sometimes can cut motor off and restart - shifting slowly to drive and will fix problem. Sometimes "shaking" stick will fix it. It started only happening if shift stick was moved fast, now happens more often. Mechanic says transmission itself is sound. Has anyone got any ideas what this could be and what the cost of repair would be. THANKS
http://isuzufaq.ibctech.ca/range.pdf
My '00 Trooper and daughter's '02 Rodeo have the problem occasionally. I have seen folks talk about a replacement mode switch being around $150, or installed around $300.
THIS CLEANS THE CONTACTS.THEN RESTART THE CAR.
Good day
Bill
At first my car would not start in "P", but would fire up in "N." I was told that this could be due to a faulty NS switch. After replacing the NS switch the car started acting funny.
It will only mark "P" at the dash when the car is in "P", "R", or "N." It will only mark "2" when in "D", "3", "2", or "L." When driving the car hits high RPMs, because it thinks its in "2."
Although, it seems as if, once the car warms up or the NS switch gets hot if finds the right gear, and will then indicate that it is in "D." Any Ideas what this can be? Is their a sensor that needs replacing, to synch the two?
'00 Isuzu Rodeo LS V6 3.2L 4WD 197,XXX miles
