-September 2024 Special Lease Deals-
2006 Chrysler 300C AWD shudder when turning
blarneystone
Member Posts: 3
I have a 2006 300C hemi AWD with 18,000 miles. I have found a few posts on the AWD Dodge Magnums having a low speed shudder or growl in the front end when turning hard left or right. My dealer thinks I am imagining it. (I have been an auto mechanic for 25 years and I'm absolutely not imagining it). Has anyone else had this problem? There is supposedly a Technical Service Bulletin on this but the dealer can't find anything on it. Any help?
Apr.19 2006.Problem listed was transfer case shudder.I would say this is your problem.We have alot in common,I also was a mechanic for 25yrs.
The problem is located in the transfer case on the right side of the power divider where the front drive shaft goes into the back of the case.
At least in Canada the TSB Number is TSB 21-011-06 and it says, "To repair fpr slow speed shudder in parking lot turning".
The parts are:
1 - 5191126AA Cap
1 - 5170055AA Lubricant
1 - 4318083 Sealer
Part Number 5191126AA
i have an '05 300c AWD and have noticed it doing this when i'm taking a sharp turn left or right very slowly; whole car seems to shake and it appears it is coming from the rear.
everything seems fine jetting down the highway and taking corners aggressively - but slow movement and slow turning seems to make shakes
is this the problem you guys are talking about?
if so what kind of costs are associated with fixing it?
That's the TSB that will fix it. It applies to 300's also.
Can U build one? Will the 5.7 hemi /transfer case bolt up to the 6.1 Hemi block/tranny/mounts etc?
I really want an AWD but I'd like the SRT8 as well
Thoughts
Thx
