-September 2024 Special Lease Deals-
Hyundai Veracruz Heater and A/C Questions
On high fan mode, the blower constantly fluctuates. Does anyone else have this problem? It is not related to the automatic temp. control.
My wife had the same thing with 2004 camry But I couyld get around it by playing with the a/c to clear it and temp. Anyone having simular issues ?
Steve
I could never figure this out myself, not just with my Veracruz, but every car. I think that there is a certain temp range and humidity outside that makes this difficult since it only happens sometimes...At least for me.
i was wondering if anyone knows how to turn on the heating in the veracruz. its very confusing because there isnt a diagram going from blue to red in most cars (though it has that in the rear seats). i have a GLS.
thank-you. any advice is greatly appreciated
Hyundai USA Owner's Page
Are all the connectors/wiring the same? the shop manual is not detailed enough to tell.
Thanks in advance
Once you get the glove box off you squeeze the two tabs inward on both sides of the filter cover
Here is a link:
http://hyundaiparts4u.com/oem_parts.html?gclid=CM2G9o3Q8JgCFRRhnAodT1vT1w
Is this filter visible when the headlight bulb is being replaced? Where are these filters located?
The "cabin air filter" and "air conditioning air filter" is one and the same on the Veracruz.
Its inside the car behind the glove box.
How to change instructions are in your owners manual.
Turning on the A/C should also take out the moisture since it should condense on the evaporator coils and drain out of the car.
