-September 2024 Special Lease Deals-
Jeep Cherokee Grand Cherokee Driveline
We're consolidating several discussions relating to the driveline into a single topic which includes everything in the drivetrain after the engine and transmission.
SUVs and Smart Shopper
Does anyone know of any problems with this?
I suspect that even if you could remove the driveshaft, the impact on your gas mileage would be minimal.
i have a 4.7 and average 17 to 19 gall all the time can't complaine about that also have quadratrack with nv247j transfer case
from the sounds of the ware patern you are running to low of air pressure
if you check your own pressure your gauge may be off new gauge cheep would try that and move tires to rear
have michilln x tream have 75000 on them and just now starting to look for new tires
cant replace them in size i have so will get michilln FORTERA SILENTARMOR this time
A Tip from the Old Man....................
Fly away ! [Lady Bird]. Get away from those guys, there after your money.
Now lets put some air in those tires ! And move them to the back if there wore bad enough. Always keep your best tires on the front of the car / truck.
Tires will ware on the outsides if under inflated /excessive ware in the middle equals
over inflation.
If it worries you go by your local tire shop and ask them.
Also the tire pressure should be in your owners manual and its written on the tires.
Good Luck.
Cactus “PEP” :>)
I recently ran over a curve going 50 miles per hour. After I notice a vibration under the driver's floorboard when I continue up the ramp while placing stress on the front end. Later, I found out that I did bend my driver's hub and replaced it along with a new axle. My jeep is a 1997 Grand Cherokee V8 with continuous 4 wheels drive. If I remove the front driveshaft completely the vibration goes away and the jeeps drives perfectly normal. While the driveshaft was out I had it rebalance, however as soon as I hookup the driveshaft the noise recurs but only going up hills when the gas pedal is accelerated. The noise and vibration is felt under my left foot when driving. As soon as I release the gas pedal the vibration goes away. When the vibration begins again and I continue to leave my foot on the gas pedal and reach higher speeds the vibration and noise goes away. Can anyone help or come up with a solution.
Carl
We recently bought a 1985 Jeep Cherokee in good shape except the engine. We had a new engine put in plus all the hard ware that goes with it,'water pump, fuel pump ect...; $2,300.00 worth of work.
Now we have a new problem. The lever for Hi & Low drive is locked in the Nutural position and the Jeep won't move. You can hear the tranny kick in when it is put into drive or reverse and hear it whine. Somtimes if you race the engine really hard in drive or reverse it will kick into gear, but as soon as you change the gear or put it into Park, it won;t go back into gear again.
If anone has had a similar problem or knows of a solution please let me know. We are told the problem is in the transfer case but no one seems to know how to fix it.
Thanks so much,
Also, sometimes when I go over a bump something sound loose. I have checked under my jeep and cannot pinpoint where the problem is.
Appreciate any help on this.
This is my very 1st post on any forum.
This is actually my first vehicle and with the year as you know it has some problems.
And i know nothing about cars what so ever.
I actually just purchased a 95 JGC Limited with approx 176,xxx miles.
There are a few problems-
1) The front axle boots are completely garbage. lots of dirt and other debris in the bearings and joints. my question on this is- am i going to not only going to need to purchase new boots- but am i going to have to replace everything included with the front axle???? if so what am i looking at to replace these parts and fix this problem??
2) The front drive shaft was removed before purchase due to a gear. neither i nor the previous owner can recall the weather the gear is in a differential or a transfer case. now my question to you guys is seeing as none of us can remember the issue would you recommend re-installing the drive shaft and see if we can figure out what/where the problem is??? in doing so i have a couple buddys who know how to install it but would you suggest taking it to a shop and paying to have it installed,diagnose problem, remove, fix,and reinstall...
3) I have a LOUD ratle somewhere in the exhaust system.. Again my question to you--is there a common reason this may happen or is there a large number of things that could cause it.
4)Another issue is that more often than not when the car is started and in park it idles at 1000rpms for the most part after about 30 seconds it drops down to almost nothing as if the car is going to die that jumps up to 1500+rpms than drops back to 1000, and repeats every 30 sec or so. The other day it seemed to be doing the same thing while i was driving a really worried me. Does anyone know the cause of this?
5) My last issue is when i park at a slant. The other day was the first time and its happened numours times since. When shifting into park, releasing the brake the car proceeds to roll back wards. it actually ended up in the middle of the road behind my driveway rolling about 20 feet. Again what is the cause and how much is it gonna cost to fix...
I believe these are all the main issues im having right now other than the rear windshield wiper motor not working but thats minor and can wait.
I greatly appreciate any help your guys can give me. id live to get these issues resolved asap.
Thanks Everybody.
Just a thought from a guy who uses his jeep on rare occasions to do something off the daily grind
