-September 2024 Special Lease Deals-
Mitsubishi Outlander Navigation and Electronics
tidester
Member Posts: 10,059
in Mitsubishi
We're consolidating related discussions into a single topic including, e.g. radios, stereos, navigation, communication and so on. Enjoy!
SUVs and Smart Shopper
I purchased a special retractable cable (3.5mm to 2 RCA jacks). If you put the Navi unit on AUX, it will take the infeed from the RCA jacks located behind the middle arm rest (in the rear passenger foot area). just use your mp3 player as normal.-it will not display any info on the head unit. The name of the jack is th Zip-Linq compact audio 3.5 mm M-RCA, I got it at cables4computer.com. Its not a perfect solution, but works for now. I am in awe at why a 3.5mm jack wasn't built into the system?
Ipod also sells Ipod AV cables which are "compatible with all ipod models with color display." We plugged an "old skool" mini ipod in with these cables and it also worked. After you plug in the cables and connect to the earphone jack in your ipod, be sure to touch "aux" on the navi screen. You will not see the music on the screen. You have to control music selection through the ipod.
I hope this helps.
Nope. Doesn't seem to work for me. I am using the following audio cable.Should've been straightforward! Need to spend some more time figuring this out
For example:
I'm listening to a rock song. The song is crystal clear with the "highs" sounding crisp and clean. Then all of a sudden, the "highs" will decrease and the sound is now dulled and crappy sounding. The volume remains the same, but the clarity is gone. It sounds like the radio is automatically turing the treble all the way to the negative, and then back up...every 20-30 seconds!!!
I've tried every setting in the book, remained parked, moving, etc... It doesn't matter which stations, FM/AM, etc...
This only occurs while listening to the radio (am/fm) and does NOT occur while listening to the HDD or CD system.
Please listen to your radio and tell me you're experiencing the same thing!!! This problem needs to be fixed! Do I HAVE to go back to the dealer?
Concerned in Chicago,
Steve
I did bring mine to the dealer. They tested the speakers and found them to be in working order. I took it for a test drive with them and was able to reproduce the problem. They suggested waiting to see if a service bulletin came out before they started pulling the sound system apart tying to locate the problem.
I'm going to write Mitsubishi informing them of the problem.
I use an Ipod. I bought an Monster IcarPlay FM Transmitter/charger. I plug it into the power outlet upfront, under the dash. It works great! The sound quality is very close to using a cd. I can't tell the difference myself but I'm not a audiophile. I like the fact that it charges my Ipod as well as letting me listen. Monster makes differt models for your type of Ipod. It interfaces thru the USB port on my Ipod, I dont have to connect anything to the audio jack. I got mine for $17.00 on Amazon.com plus shipping.
http://www.monstercable.com/mp3/
I thought it was just a reception problem but I guess it is more.
I haven't spoken to the dealer about it yet.
Has anyone noticed any problems with Satellite?
http://us.kensington.com/html/11206.html
If anyone is using one with RDS please post, I'm wondering if it will work as good as the Monster brand did in my Outlander!
In one of my cars I have Blupunkt receiver that has a feature that is described per manual:
"The HiCut function has the effect of reducing interference noise during poor radio reception. If interference occurs,
the system automatically reduces the treble thus reducing the interference level"
In this particular unit you can turn it on and off or even set sensitivity.
I thought, I would share...
Listen to the radio again and see if that "HICUT" appears when reception is a bit worse than normal.
I know there are some differences in options between the LS and XLS (no option for factory navi and factory RES on XLS) and (no center console 110V AC outlet on XLS).
So my questions are this: Anyone out there have an XLS with navi and RES? If so, what is the make/model of the RES DVD player? (mine is a Rosen A8). Does the RES audio play over the car stereo speakers when you put the front head unit in Aux mode? Did the dealer install the RES?
Possibly related, I do not have the RCA type auxillary input ports on the bottom of the arm-rest. If I take off the center console's back cover there are some open quick connector type wiring harnesses. Could this be something else that was missed at the dealer or port? Or the console aux ports this only something that comes with the Sun & Sound package? The RES DVD player has RCA aux ports, but then my MP3 patch cables are going to be hanging down from the ceiling all the time... ugh.
Sorry for the long post. Thanks for your guidance.
I'm also curious how GPS data will be updated as maps change.
And of course - look at upgrading to a larger capacity hard drive...
Has anyone made an attempt at this?
GPS data is by Navteq, but browsing through the Navteq site, I can't find the 07 Outlander among their list of OEM vehicles. Maybe to be updated later. But with regards to maps, Navteq has a Map Reporter tool (or something like that), where you can actually send a request to Navteq to update a certain portion of the map. Like in my area, some of the new homes and newly created streets are not yet on the map, so I plan to send a request to Navteq to have this part of the map updated. And they're suppose to include the newly updated map as part of an annual update CD, which for some makes like GM, are being sold for $100+. I am not sure though how things are with Mitsu. But I am hoping map updates through the dealership during the 5 yr new vehicle warranty will be free.
Gracenote CDDB too has free updates, just in case you have a couple of new CDs not in the database. Haven't tried it yet, but I found out you can actually update it yourself using a self-created update CD.
Larger capacity drive? Sounds cool. :shades: Too bad my DIY skills are a little bit rusty. And maybe we can have RDS hacked too and have it enabled for Navi FM tuners. I have this feeling it's in there, waiting to be unlocked.
This is b/c the rear DVD player does NOT play audio through the main audio system of the car when I put the front navi unit in "Aux" mode.
I was told by the dealer, and have read in one of Mitsu's press releases that in factory installed RES, you can actually watch the DVD playback in the Navi screen from the RES. What's not clear to me though is if it's at all possible to do this trick with a dealer installed RES. But my feeling is that because they made that statement, that it's not at all possible to watch the RES video in the Navi screen on a dealer installed RES. I guess this has something to do with the wiring.
I suspect that I did not get the RES that Mitsubishi intended for the 07 Outlander and believe the dealer just sent it to a local car audio shop for whatever system they had.
This is what the genuine OEM RES system should look like. Is this similar to what's installed in your Outlander?
Also, I would have liked the 110v outlet on my XLS, although for now I don't really see a real need for it other than using my home outlet cellphone charger, and not buying an extra 12v charger just for car use. But I guess rather than being charged extra, buying a good inverter would be a better, and cheaper.
Rosen A8
So I bet you don't have the genuine OEM RES. Too bad, we could have confirmed if RES playback was indeed possible on a dealer installed genuine OEM RES. Did you signed for a genuine Mitsubishi RES? Because if it was me, I'd take it back to the dealer and have it replaced with 100% original Mitsu parts.
Once again, if you're noticing this problem, then I suggest calling your dealer and MMNA so they can find a solution.
I live in Pittsburgh and we have alot of local FM stations.
I'm not happy with the radio reception.
I have owned many cars and have never had this problem.
The radio fades in and out with the highs cutting out just as others have posted. Also many station don't even play in stereo. I will be watching this post, please let me know want Mitsu says about this problem.
I have not tried turning off the speed compensated volume control. I still have to see if this could be the culprit. It is set to "ON" by default.
Does anyone think there could be an electrical problem or a problem with the cable running to the radio that is subject to electrical interference or surges of some sort? I am going to get this repaired again, but it is getting a bit annoying...
I got the run-around for the most part.
They don't have anything listed on the radio issue.
They want me to go to the dealer.
I'm sure that will be a total waste of my time.
I guess I will call my service manager and let him know that I'm having a problem.
This is what happens when you buy a first year product. I'm sure the 2008 Outlanders will have all the bugs worked out and I'll bet they get better sunvisors...bastards!
If the sunvisors will be better in 2008 model, you could buy them as parts and replace them. They shouldn't cost you a fortune. I don't think Mitsu will change the bracket so they will still fit. They are not too bad either IMO. As far as I'm concerned, there are other things, more serious IMO, to be fixed with the interior fit and finish, which I don't think I will be able to replace even if they improve in the coming model years.
