2000 Isuzu Trooper possible misfiring
I have recently had a new engine put into my 2000 Trooper (dont ask me why) I haven't driven it for a month and it drives great. However for the past couple of days whenever the car is in motion the check engine light blinks on and off and I smell gas. I know this means problem so I call Isuzu service and was told its misfiring. That was a couple of days ago. Today I back the car out to find a pool of what smelled like gas in the driveway and the gas gauge seems lower and then when I put the car back to the original spot there is another pool in the place the car was in park. Does anyone know what may be the problem and does the car sound safe to drive to the dealership?
When you change spark plus you need to use Denso OEM plugs. K16PR-U11 PK16PR11.
Also you must put the right spark coil in cylinder 6 ( drivers side rear).
The bulletin lists part # 8-19005-250-0 for cylinder #6. #6 coil is shorter than the other 5. TSB # is IB01-04-S004. The coil for the No. 6 cylinder is 3 /16 in. shorter than the coils for the rest of the cylinders. Putting the right coil in #6 solved my Code 300 problem.
