Chevy Impala Low Tire Pressure Indicator
in Chevrolet
Hello
The low tire pressure indicator came on in my 2005 (beau-t-i-ful) Chevy Impala...I checked the pressure (low) and added air to all four tires. How do I get the light to go out? I read the manual, and it says something about the system having to recalibrate itself...very confusing. I think I did what I was supposed to do, but the light is still on.
Any words of wisdom? Thank you.
Steph
I'm sorry I didn't reply sooner, but had to remember how I fixed the problem - I had no luck with the switch turning on/off, had to go through the radio settings. Since I just reset my clock for daylight savings time, I think I can remember...
switch the ignition to on or acc. Press the display button on the radio for a few secs until "settings" comes up. Once settings comes up, then hit the tuner arrows on the radio until tire pressure comes up. It will say oil change, oil pressure, all kinds of things, eventually tire pressure. Then I think you hit the display button again, then the arrow keys again until exit.
Sorry, I don't have my manual right in front of me. I remember it was a real pita.
Good luck, write again if it doesn't work.
Steph
Would you have another resolution aside from going to a dealer to have them reset it. I don't want to pay the money if I don't have to. Thanks again for your timely response though!
If you have the change oil light on turn car to acc and press the gas petal all the way in and let off 3 times the light will go out.
Since I don't have the stock radio that was out of the question. I tried the light switch procedure without any luck. Then I read the owner's manual looking for the procedure to calibrate the pressures. (Note: only do this if you have first verified all tire pressures are in spec and within 12 psi of each other). On the passenger side of my 2001 Buick Century is a fuse panel. open it and find a rest button in the lower left side. Press and hold the button for 3-5 second, the LOW TIRE light will flash then turn off. Pretty simple once I read the instructions.
