-September 2024 Special Lease Deals-
Pontiac Bonneville General Maintenance and Repair
Hey guys,
I have a '97 SSE. The driver information console
shows that my tail lamp is out. I fixed it, but
the lamp won't go out.
Also, I am not sure how much gas I have in the
car. When I fill it with about 6 gallons with the
needle at almost empty the reading goes up to the
1/2 mark. This is happens every time.
Has anybody else experienced this?
The gas tank, i guess, the design is different. I had the same issue. When the tank is full, the needle is perfect. It would come very slowly till half and fall down drastically from half to empty. When i asked the service manager, the guy gave me a written notice saying that it is the design of the gas tank and the meter. Don't know what that is. But, got used to it now and i have a habbit of keeping a tab on the no of miles i drive, by resetting the trip meter everytime i fill the tank. I know that the tank would be empty very soon once the no. crosses 350 miles.
I am used to it now. Also, I notice that when the needle is at Empty or below I am able drive for quite a while. I try not to drive more than 10-15 miles so I don't get stranded.
Jono4
By the way, I love the car!
ezrapon's message #495 and might have an explanation. I'm just turning in a '98 GC and
it has a 5.9L motor. I replaced the computer and put in a K&N cold air box (57i), both we ordered from the local Chrysler dealer. The K&N setup for this truck is dyno'd 27hp extra, at the rear wheels....Between the 2 add-ons and the factory 245HP, I surprised many drivers. I'm going to try and run the two vehicles before I give back the GC. I'll let you know.
As far as everything else goes, the ssei rules supreme.
Our alternator was replaced at 18K. They decided is was a bad unit from the factory. We took it in because the gauge was reading low and battery charge problems. Surprise -- the replacement was replaced within a few months. They said its rare for the replacement part to be bad as well, we're so lucky.
Now, our car is having the transmission replaced. A few short months after the warranty period is over. We had complained about bad shifting into overdrive, and they couldn't diagnose (wait until it gets worse). We took it to a transmission shop, their diagnosis was that the torque converter was locking up, an electrical unit that they were ill equipped to diagnose more specifically. So, back to the dealer with this to check out, and the dealer now says the transmission needs to be replaced. Ouch.
Very disappointing. We like the car also, very comfortable to drive. But, this is the second GM product with major needs at the end of three years.
So yesterday I carried the car to a friend of mine and he replaced a bad injector and said he'd seen this type of problem before on bonnevilles but never the less my car still surges back and forth with any type of strain on the motor. I'm in desperate need of sound mechanical advice-any help with this problem would be greatly appreciated.8/31/00
im an owner of a 92 bonneville se. for some strange reason the power locks will open and close at random times. even at times the trunk will open every now and then. anybody have any clues as to what the hell is going on with my car? thanks!!
second off. Gas millage. since the 1st time the engine was rebuilt, and the torque convertor problem, i have noticed gas millage problems. before the repair, i was geting 450-500 miles per tank. now, i can only get 380 if im lucky. if you do the math, i was getting 33highway, and now i get 24 highway and 24 city. in my oppinion, if a great number of you are experencing these problems, we need to start writing GM and demanding that these problems be fixed. we are getting robbed guys!
6 months later my service engine light started coming on and the car would run rough,Untill I realized that when I turned the car off and turned it back on, the service engine light would go off and the car would run ok.Now,it is still doing it and now it is making a bad bearing sound once and a while and it seems like the charger is NOT working properly.HELP
Steve
So far the car has run flawlessly after a 1000 miles. I cant say for sure yet if this was the solution but its been a long time since the transmission has felt this good.
Have you looked in the Sedans conference. All you SHOULD read about in this conference is trouble. Check out the Sedans conference for a more balanced view, but remember, 10 satisfied customers may never say a peep about their experience, but the ONE who has a bad experience is NEVER silent....
Your host, Bruce
If you can provide this info I would appreciate it. (concering trans. shifting problems at mid-range speed)
Well, I'm happy to post that my 2000 SSEI has reached the 3000 mile mark without any problems; the only complaints I have is some rattling here and there, especially ion the sunroof and the passenger front door (fixed by the dealer), and the lousy designed headrests - other than that, this car is a dream come true.
Sincerely,
Dennis D. Mullert
1. After coming to a stop, turning the steering wheel is very difficult when the car is not moving; it's much easier to turn when the car is rolling forward or backward slightly. Somebody said it could be a problem with the "Rack" of the car.. He said it was called a "Lazy Rack". Is this something that is easily corrected? I don't know anything about rack & pinion steering.
2. After driving home (about a 48 mile trip), when the car is idling, before I turn it off, the motor seems to surge a bit, over and over, fluxuating the RPMs just a small amount. This doesnt happen every time, but happens enough for me to notice it. Should I be concerned?
I'm now at 12K miles. Thanks all!
Dennis
If the the torque converter locks in first or second or fails to unlock when coming to a stop, then there's likely a failure with the TCC switch. This failure is not uncommon in GM cars; my 86 Grand Am experienced it. The switch is inexpensive and should only take about an hour to replace. By the way, my 89 Grand Prix has done that since new. The car now has 221,500 miles on it w/o a failure to the tranny. AND that's with the infamous 440T transmission!
As to the power steering unit, GM's Magna Steer is not without complaints of erratic performance. While I believe there is a software 'fix', the problem is not related only to Bonnevilles. Seems the unit tends to think it's going slow when it's going fast and vice versa. When the car is going fast, steering effort is supposed to increase and when the cars slows, steering effort is supposed to decrease. There are some reports of Magna Steer units doing the opposite and causing vibration. See topics related to Suburbans for discussions on steering problems.
THE THING WORKED AGAIN. OVER THE NEXT 18 MONTHS WE HAD MINOR SHIFTING PROBLEMS, ALWAYS CURED WITH ADDING FLIUD. ODDLY ENOUGH, WE NEVER SAW ANY FLUID LEAKING ON THE GARAGE FLOOR. LAST SPRING WE FINALLY NOTICED SOME TRANNY FLUID ON THE GARAGE FLOOR AND PROMPTLY BROUGHT THE CAR TO A MECHANIC. THE PAN BOLTS WERE LOOSE. THE MECHANIC EXPLAINED THAT THE PAN BOLTS CAN NOT BE SNUGGED DOWN TIGHT BECAUSE THE PAN IS ALUMINUM AND WILL WARP. ONE DAY MY HUSBAND WAS RELAYING THIS INFORMATION TO AN OLD SEASONED MECHANIC. HIS RECOMMENDATION: PURCHASE SPECIAL PAN BOLTS FROM A GM DEALER At about $20. THESE BOLTS CAN BE SNUGGED DOWN AND NOT WARP THE PAN. HE ALSO RECOMMENDED A CORK GASKET. ALL TOGETHER IT COST US $120 WITH THE LABOR ETC. 2 MONTHS AGO WE PULLED A 1400 LB TENT TRAILER OVER A CASCADE MOUNTAIN PASS AND THE BOONIE NEVER MISSED A BEAT. THIS IS WORDY ,BUT HOPE IT HELPS SOMEONE.IT BETTER THAN $2800 FOR A NEW TRANNY.
That is very helpful information, thanks for posting it. I'm sure it will help someone out around here.
I just wanted to mention, though, that posts are easier to read if they are not in all caps.
Hope you are finding your way successfully around Town Hall and enjoying what you see.
Thanks again!
Pat
We have owned 7 various models of Pontiac and never encountered a serious problem before this one.
After reading the previous posts, I was pretty convinced that I had the same problems as everyone else. When I cruised at 60mph in overdrive and slowly pressed the accelerator, the car would buck violently as though it had a problem shifting. I could alleviate the problem by shifting to drive myself. A friend of mine also witnessed it and thought the same.
As it turns out the ignition coil pack was failing when the engine was bogged down or under heavy load. The coil pack has 3 sections, each firing a set of 2 cylinders. Apparently, #4 & #6 were not firing. Oddly enough, as I said before, the car ran FINE when going through all the other gears. The problem was easily reproduced when going up a hill at 50mph in overdrive.
I can't really see why/how a dealer would miss this but I guess anything's possible. The coil is about $70 a the parts store. I paid $240 for 2 hours labor and a $130 GM part. I went with the dealer install because in comes with a warrantee . Hope this helps somebody....
Hope this takes care of the problem once and for all.
Pat
My 96 Bonneville recently started bucking after about 50 MPH or when going uphill under light acceleration. I took it to my trusty tranny guy who suggested I check the coil pack & change the plug wires. The coils checked out OK and I was not too optimistic but I changed the sparkplug wires and guess what? Runs perfectly! Shifts perfectly under any condition. Try it. I still can,t believed it's fixed for $50.00.
He is one honest transmission guy.
Also the Adaptive memory does not seem to be the solution. I ran fine for about 1100 miles and then the car sat for the weekend and on monday it was worse than ever. I also suddenly had a great deal of vibration so severe I could not focus on the cars in my rearview.
On Tuesday the car ran better but still had more vibration than normal. After having the tires balanced and rotated there was no change.
The coil pack seems to make sense to me because I keep thinking the car doesnt feel like all pistons are firing properly.
It goes back in on 9/19 for the 6th time with my patience running out for this problem. Ill let you know what they say.
My 96 Bonneville has 182,000 highway miles on it with no major problems - until today.
The car won't start, the battery is fully charged, and interior lights work until key is turned, engine tries to turn over, but then everything dies.
Also, one other little problem I've been living with for a while...car vibrates very badly when going around 70 mph, even on flat roads, no problems around 65 or 75 though. Is this the same type of transmission problem you other guys were experiencing?
Any help would certainly be appreciated!
I was wondering if you had found the Our Turn conference yet? That conference is dedicated to women's automotive issues of ALL sorts - Town Hall is fortunate to have an automotive technician co-hosting there. Her name is Kristina and she posts under the ID of md_tech.
While you are waiting for a response here, you might want to drop by over there to see if she has any thoughts for you.
Good luck and again, welcome.
Pat
Also was running a 165 deg. thermostate in my 2000 SSEi to help reduce detonation and after a few days it made the PCM upset and it turned the "SERVICE ENGINE SOON" light on . Changed back to stock therm. but light stayed on till I reset codes by disconnecting battery , then every thing was OK .
May sound dumb on the vibration issue , but are tires OK ? all in balance and no belts broken , no scalloping of the tread ?
It's always nice to hear about a bonnie getting near the 200 k mark , good luck . Doug
What octane gas are you running in it . My 2000 SSEi always liked 93 or 94 octane and runs very smooth , even with modifications I have made for performance . The problem may be that previous owner ran cheap 87 oct. in it . Are you interested in increasing performance in your SSEi ?
I have a 97 SSEi and about a week ago the alarm went off 3 times for no reason. It happened in 3 different places so I'm sure nothing occured to prompt it. It also happened today twice at work. Could it be a short? I don't think it's the key controller since it has also happened in the middle of the night (happy neighbors, I'm sure!). Is there some kind of a fuse for that or any way of disabling it until I can get it looked at? Thanks in advance!
Jackie
I have a '97SSE with 78K, and recently my ABS and Traction Control lights came on when I started the car and stayed on. It didn't happen all the time. I took it to the mechanic, and he says the computer shows a "Stuck ABS motor." He is not sure if it is the traction controle module or the whole ABS system needs to be replaced. Apparently there is a whole procedure he has to go through to determine that. Anybody have a similar situation, and what would case this?
...by the way my transmission was behaving very similar to what you guys are describing and putting a little fluid in fixed it.
