01 V8 LS HOT IDLE PROBLEM
Hi, I have a 2001 V8 LS that runs perfect when its cold (first started) but about 35 minutes later the idle get real irratitic. Will run steady then skip and cut in and out and just run bad and hesitate. It only take the engine about 10 minutes to warm up(thermo opens)car continues to run good and only starts to act up after 30-35 minutes later. I have a new c.o.p and have tried it in each of the eight cylinders one at a time no change. No check engine lights are on and I had it scaned and the only code was p0795 for a trans solenoid. I just purchased this car and could really use some help. I really love the car and would like to get it running good so I can enjoy it. Thanks in advance for ANY help offered!!!! Mike
But what may be the cause of the problem. I read on this site that the PCU is self-learning on these cars, if so, would not driving the vehicle allow the new PCU to adjust and learned the old problem?
This respons was from a member named " fordfan 17"
I haven't done it yet but when I do, I'll update.
I have a 02 ls recently it started idle high, the difference in performance is wait time (for allowing it drop in idling) and from park to reverse has a rough transition, it appears as the car almost is being force into gear. I had it check by the local transmission shop they said it idling high...go figer...so would it be the idle control valve? if so is it hard to replace?
