Pontiac Grand Am cruise control
My husband purchased a 2004 pontiac grand am. It came with no owners manual. He does not know how to work the cruise control.
Does anyone know where I can find information on how to work it?
(button on bottom of steering wheel) then push the set button
( next to the on button)
I just had a drunk hit me and rold me over 3x and totled it out
it was a 04 grand am
Gearr
There is no button on the bottom of his steering wheel. He said what he needs is a diaghram of how the 2004 pontiac's work. I have searched the entire web and come up empty.
on the 04 grand am it was on the bottom of the steering wheel.
Gearr
But we went out and looked again after you said this and there is nothing UNDER the steering wheel.
any idea where I can find a book on this car?
Gearr
it on then on the end of the arm is a button that is the set and decl
button the on button is the accel button
I hope this help's let me know
Gearr
Great job!
Gearr
Any help would be greatly appreciated.
Thanks Moe
thankfully the only problem i've encountered is that the cruise control doesn't work at all... (i found the middle button cover under the driver's seat 3 weeks later)
the cruise assembly lights up with the interior/dash lights that function with the headlamp switch and dimmer control. but the real problem is that the ON/OFF button does NOT stay held in when depressed. and the LED in the on/off switch never lights up..
anyone know which fuse powers cruise control or have any other advice at all.
is the ON/OFF switch a mechanical switch which should hold each change of state reguardless of the presence of voltage (like if a fuse were blown)
i'm trying to figure out if i need a new switch in addition to a fuse. hopefully i won't need some of the expensive parts.
