Audio Removal Instructions
Hello ,
I need some help
I need to access the back of the audio on my 07 Santa Fe with XM. The instructions on hmaservice.com suck!
http://hmaservice.com/viewer/index.asp?vie...7&enginecode=47
first of all there is no central speaker where they say it is - I have a small box/compartment there instead - it's ok, the box comes off in a similar to speakers way - 2 screws - and now I can see the back of the radio but to take it off i'm stuck at the next step:
Remove the center facia panel (A) after loosening the screws.
(Refer to the Body group - Crash pad).
Loosening what screws? where are they? Refer to what? Where is that mistical body group - crash pad instruction?
Has anyone figured a way to do it ?
P.S. I'm installing a permanent in-line FM modulator that plugs in to the antena connector (this part I can do from the top, but I also need 12v to power the modulator and for that I need to connect to the radio harness.
I need some help
Group: Members
Drives: 2007 Santafe LTD AWD 3.3
Status: ONLINE
I think I'll answer my own question:
http://documents.victorytechnologies.com//...uct/95-7325.pdf
I haven't done it yet ,but I found the instructions.
also found helpfull:
http://www.hyundai-forums.com/t14713-remov...m-modulator.htm
and
http://www.hyundai-forums.com/t14998-clari...ics-details.htm
Here is the new link:
http://www.installer.com/pdf/95-7325.pdf
if this doesn't work ,then google for 95-7325.pdf - th second from top is your link
the hyundai forum links are still working for you, right? they do work for me in firefox
