-September 2024 Special Lease Deals-
GMC Envoy Heating Ventilation and Air Conditioning
I'VE GOT A '02 ENVOY SLT AND MY PROBLEM IS NO AIR IS COMMING OUT ON THE VENTS AND SOMETIMES I HEAR A CLICKING SOUND UNDER MY DASH, IF THIS IS THE BLEND ACTUATOR WHERE COULD I FIND IT AND WHAT TO REMOVE TO GET INTO THE ACTUATOR? YOUR ADVICES IS GREATLY APPRECIATED....THANKS
Did you get a reply to your same problem, and if so, can you give me a copy of the fixit reply you received?
Is there a problem with a leaky hose or something that handles the condensation. There is no condensationh on the ground when you turn off the car.
Help!
Mart
Hope this helps.
If you replace it, you need to update the ambient air temperature display on the HVAC control module, perform the following procedure:
1- Turn ON the ignition.
2.-Simultaneously press the MODE, FRONT DEFROST and REAR DEFROST switches.
This process worked a couple of times before I was able to replace the sensor. Hope this helps!!!
I also have the same problem. Did you get it fixed and if so what was the fix? Thanks very much. Bob
Note: this fix is for the digital type control with the up/down bar graph on the console, not the rotating switch type blower speed control, which has a resistor module instesd of the electronic module.
Bob
does anyone has had the same problem?
Can anyone help me in solving the problem?
thank you
angelo
I checked the power at the end of the blower sensor and the power was ther..
I also decided to bypass the blower sensor and connect the power directly to the blower, the blower started working so i went to buy a new blower sensor and about $160 later with the new sensor i restored the heat in the Envoy.
Angelo
but is not coming out front vents ,checked fuse boxes any suggestions
I don't believe it is the compressor but maybe a switch. I called my local GMC dealership and they said they have never heard of this problem. I do not believe that. Not from reading this. Any help will be great. Thanks.
1) When a/c is on sometimes the blower blows, sometimes not. Turning the speed up or down does not adjust the air flow. It might blow a little bit but then when driving down the road it turns on full blast. Then on it's own when it wants to starts blowing nothing again.
2) When I turn the car off the A/C Heater Blower does not turn off. Once in awhile if I keep messing with it or turn the car on and off it might stop. It has drained my battery twice now and I have to unhook the battery to get it to stop.
When I hook the battery back up, start the car, I do not turn it on and it will turn on automatically even though you do not hear it and then I am back in the same boat again.......
Somebody please help!!!
Thanks Jess
C.B.
SUVs and Smart Shopper
Ty
