GMC Yukon Cold Air Intake
gaserupgaserup Member Posts: 7
edited July 2014 in GMC
Has anyone installed a cold air intake on there truck? I'm driving a 2007 Denali XL and have read that the CAI adds about 20hp and gives you better gas mileage. I've also read some debate over the K&N filter messing up the Mass Air Sensor from the oil on the actual filter getting on to the sensor. The GM version of the cold air intake has a metal intake "tube" but the other manufactures intakes use non-metallic rotationally molded tubes that can reduce intake air temperature and decrease intake sound over a metal tube. The whole purpose behind the intake is to use free flowing cooler air because colder air is denser. I'm also wondering how the Cadillac Escallade gets the extra HP? I'm suspecting it's the exhaust.
  • brewboybrewboy Member Posts: 36
    I would suggest you try the Diablo Sport Predator programmer for the Denali 6.2 engine. I did my 2007 Denali and it made a big difference. Thats all that GM did for the Escalade, its just programmed different. HP and mileage are better. A GM OEM cold air intake would help even more and its under $300.
  • gaserupgaserup Member Posts: 7
    I went and checked out their website and the Diablo Sport Predator programmer sounds complicated to set up the truck or am I just not reading it right :confuse: Brewboy what did you do with the programmer? If anything I think I would like something plug and play and very simple to use and reliable as well. I would however like the have a Denali that's faster than a stock Escalade. ;)
    Its not difficult at all, took about 5 minutes to do. You plug the programmer in to the UDC port under the steering wheel and follow the LCD screen instructions. I take it out and swap the OEM programming back in every time it goes to dealer for service.
    The Diablo Sport Predator manual talks about removing a fuse for the OnStar in case of an OnStar signal effecting the programming session but I have never done it and never had a problem.
    My Denali eats Escalades for dinner! Plus in a Denali your less likely to be mistaken by the cops as a drug dealer.
    Thanks Brewboy. I have been reading the posts on the Diablo site about the Predator to get some more information and it sound like a nice addition to the truck. I'm like you, if I need to show an Escalade whose boss I want to make sure it's me with the better truck. ;)
  • dsteberdsteber Member Posts: 5
    Brew,
    Did you use the tune that came with the Diablo, or did you get a tune from someone else, then load it on the Diablo? I am asking because I have a SCT II tuner for my mustang GT, but I bought my tunes from someone who wrote them for my engine code and upgrades, like the CAI. I have an 07 Yukon Denali, and want more form it. I see what a tune did for my stang. Holy crap!!! It's like driving a different car!! Thanks, and let me know.
    I used the Diablo Performance tune because I didnt even know you could custom make your own tunes or buy the specs from someone else. I just read that the Escalade has the exact same engine and transmission but puts out 420 HP so its just a programming difference. I would be very interested to see what you could get for a Denali 6.2L custom tune, especially if you could crispen up the shifts. I hate the hesitation at low speeds with this 6spd. Let me know.
    I have searched and searched, but I have yet to find any custom tunes for it. So, it looks like I will just use the one that comes with it. You see, with the Mustang, the tune changes for any mods you might have. So, I don't know if it will affect it when I add the cold air intake or not. We'll see!! I know what you mean about the lag. sucks. But, it sure is alot better than my Infiniti QX56!!
  • rsktkrrsktkr Member Posts: 2
    I put a Volant CAI on my 08 Denali and it seemed to make a significant difference in performance. Fuel mileage seems to be somewhat better but it could be my imagination. It's getting 15+ with both HWY and City driving and I don't really drive like a grandma. I plan to have the exhaust done and possibly the Diablo programmer. Is the U7194 Predator the correct programmer for my Denali? Stock HP on the Escalade is 403. Is it in fact the exact engine the Denali has? The Cadillac site makes reference to the VVT on the 6.2 in the Escalade.
    Yes, the U7164 is the one that I have. I will have to look into the Volant CAI. Did you have any check engine light come on after the install? It would be nice to get a tune on my diablo that had the CAI factored in. I just do not know where to get one.
    I got my Volant CAI at 4 Wheel Parts. The part/model number is 15253. I didn't have any check engine lights come on. I went in planning on getting the AFE intake but the Volant was the only one they knew for sure would not cause any check engine lights. It's a clean look and pretty simple to install. I paid $313.91 for it out the door but they were having a 20% off employee discount. I just got it 10 days ago. Here are some pics of it installed.
    Does the Diablo make a significant difference in performance? How negative is the impact on MPG?
  • rem2818rem2818 Member Posts: 1
    I bought a Diablo Predator for a 2006 GMC 5.3 engine. I chose the 87 octane mode, but noticed little change if any in power. In fact my fuel mileage dropped 1 mpg. Does anyone have any ideas on what else I need to do with the programmer to get more power, without going to the 93 octane mode.
