T&C Corrosion Problems
I'm starting to see a corrosion problem develop on my 2003 T&C. The van is well maintained, garaged and waxed at least twice each year.
The problem is showing up mainly on the front underside of the hood along the seam. It's visible in several locations along the seam and is starting to expand some, opening up the seam slightly. In addtion, I have a similar problem on the rear liftgate along the seam. I also see minor corrosion starting to develop around the the fold line near rear wheel well/fender.
Is this normal for a 5+ year old vehicle? I'm debating whether to trade it in before the problem becomes visible on the outside or just gets worse. Trade in now is about ($6000+ for the 03,ex w/ 70K).
Where are you located? Do they use a lot of salt, etc on the roads?
Underside of the hood seems like a strange place for a rust problem to first show up. I could maybe understand the wheel well/fender, but not the hood.
The location on the underside of the hood is along the horizontal seam where the exposed hood sheet metal is folded over on the inside. It is about 3/8 of an inch from the front edge of the hood. The corrosion on the rear liftgate is in a simalar location along the horizontal joints at the inside fold.
Over the weekend I tried to touch it up with by applying a primer and finish paint to the seam area, mainly to try to protect it from moisture or air. I doubt it will do much.
My goal was to keep the van for another two+ years, but don't want to if it becomes a rust bucket. Nor doI want the morw visisble rust to depreciate the value much beyond its current black book value.
I wonder what that place up in Ontario uses? I had a fella here at work that swore by Linseed oil.
http://www.krown.com/
