2002 Aurora 3.5 liter V6
Does anybody know details of the technical details of this engine? I have a 2002 3.5 liter V6, and it is exceptionally smooth running as well as economical. Anyone have comments on durability or oil consumption? I understand it is a variation of the GM Northstar engine.
http://www.greatautohelp.com/more_oldsmobile_questions.html
Clearing Diagnostic Trouble Codes
Use a scan tool to clear DTCs from the PCM memory. Disconnecting the vehicle battery to clear the PCM memory is not recommended. This may or may not clear the PCM memory, and other vehicle system memories will be cleared. Do not disconnect the PCM connectors solely for clearing the DTCs. This unnecessarily disturbs the connections and may introduce a new problem.
I couldn't find anything that said how to clear the codes, other than using a scan tool. Disconnecting the battery may or may not work, according to the manual. I don't know for sure, as I've never tried it. Just about any auto parts store can check and clear the codes for free.
Most recently.... I also noticed water 'inside' the trunk lid, which came pouring out from within the trunk- lid- liner. Is it possible that water is leaking inside from the trunk!!!! The spare tire seems dry.... but are there any other drain galleys that could be clogged????? Any tricks on drying out the carpet other than Shop- Vac????
Any help would be very appreciated!!!
