The daytime running lights draw little power, and are on only when the car is running, so I doubt they are the source of the problem.
OTOH, the amateur alarm and remote? starter system installation may have caused some lingering problems.
Second that advice - there's a chance the service manager isn't even aware of his summer intern oil-change monkey's sloppy habits. paulcudlip should also have someone in the know check the oil drain plug to be sure "Jr." hasn't x-threaded it with an impact wrench...
I sometimes get a strong gas smell at the rear of the car when it's not running. I don't smell anything when inside the car, only when standing at the rear. The Toyota shop couldn't find anything a couple of months ago but thought it might be a faulty seal at the gas cap. They replaced the cap and it seemed to help for awhile. But the smell is back, as strong as ever. I don't see anything dripping from the car. Has anyone else had this experience? thanks
You should get this checked by someone who knows what they're doing, and pronto.
I've searched the user manual high and low and can not find a specific way to set this. Anyone have any information on how this can be done?
There is only one way the doors can lock "by themselves" when the car is unoccupied: If you hit the unlock button on the remote when all 4 doors are closed, and you do nothing further, the doors will relock after 30 seconds.
This can happen accidentally, even when I'm in the house, and squeeze the keys in my pocket by crouching down, etc. The car will unlock in the garage and then relock after 30 sec. (I can hear the faint beeps.)
The car has positives...affordible, mechanically sound, roomy, reasonably attractive, and interior materials and textures have a quality look and feel to them.
Now for the negatives: I swear that the structure of this car is made of JELLO!!!! When you pull into a driveway at an angle, you can hear the body flexing...squeeking. The car is full of squeaks and rattles...all three "pillars." The sunroof doesn't fit in the hole in the roof properly...and sounds just as loud popped up as it does closed. I actually have to close the sunroof the whole way, and then try to pop it up maybe 1/16th of an inch at a time to make the wind noise stop, but it still squeaks and rattles. (They dealer has looked at this issue...three times...supposedly fixed it once...said that the wind noise was NORMAL!) EVERY door wiggles around in it's opening and squeeks on the seals. There is a buzzing sound coming from both ends of the dash. The shifter knob is loose, and I have a front suspension clunk when backing up. Hmmm...I think that is all. *sarcasm*
The '02 Subauru Legacy GT that I traded...with 68K very roughly driven miles on the odometer...didn't have a single rattle or squeek. My only problems with that car was a bad spark plug at 15K, a sunroof that leaked once...and that was completely replaced with no questions asked, and brake rotors that warped easily...no doubt because of my aggressive driving.
Needless to say...although I do love the extra interior room that the Camry has over the Legacy...I think that my next car will be a Subaru!
Your sunroof may not be properly "initialized." Have you replaced or disconnected the battery in the past?
Here's how to initialize it -- sounds like your roof isn't sealing flush when closed, which it should.
To do so without disconnecting the battery, which will mess up your radio presets and clock as well as temporarily affect your engine's idle speed, pull the "power no. 1" fuse in the lower left instrument panel.
Easier said than done, however. I had to use small pliers and ended up destroying the fuse. So have a replacement (30 amp) on hand before you start. Before you pull the fuse, make sure the keys are out of the ignition and the moonroof is fully closed and flush with the roof. (Tap the switch to position it.) Once the fuse is out, drive around for a day or two. Note: both your moonroof AND power windows will be inoperable, so if you have to pay tolls or use drive-thru restaurants or banks, this won't work.
Then re-install the fuse, turn on the ignition, and follow EXACTLY the procedure in the owner's manual. It worked for me -- no problems since I did this in early November. Good luck!
FWIW, I had an outrageously expensive luxury car a few years back, and not long after getting it (new), it started sounding like an off key choir practice. I took it to the dealer and they did the silicone thing, and voila, no more noises.
We have an 07 Camry (wife's car 4 door with a moon roof),and it's as quiet as a church.
But if this helps, for a 2007LE 4cyl........
- Remove front wheel, RH
- Remove engine undercover, RH
- Remove front fender apron seal, RH
- Remove V-ribbed belt by using a SST (long handled socket breaker bar) with a 19MM socket wrench, loosen the v-ribbed belt tensioner arm clockwise, then remove the belt.
- Notice: be sure to connect SST and the tools so that they are in line during use; when retracting the tensioner, turn it clockwise slowly for 3 seconds or more. Do not apply force rapidly. After the tensioner is fully retracted, do not apply force any more than necessary.
- The picture shows the breaker bar in a near verticle downward position, with the handle by the oil pan.
I'll stick to oil changes and tire rotations myself and leave this one to the pros!
My mom has 2000 2.2L 4cyl Camry. Last week I drove her car for 4 hours and I was disappointed. The drive was on a hilly area and I noticed that the car was shifting gears so erratically (I think you guys call it RPM Flare) to maintain a cruising speed of 60mph that passengers had to tell me to drive smoothly. I was ashamed of this vehicle. I also noticed a brief lag of 2-3 seconds while accelerating for a slow speed. E.g. while accelerating after the End of a School Zone. I don't think that 2000 Camrys had drive by wire throttle. However, this vehicle doesn't feel like a Camry at all. And it has only 70,000 miles on it. Could it be the spark plugs or something?
Also, about a month ago I met an Assistant Toyota Service Manager at aa friends house. I expressed my desire of rading in my 98 camry for a 2007 model. He warned me about the issues of Drive by Wire throttle system and that it was affecting Camrys and highlanders primarily and the TSBs were not solving the problem to satisfaction. The Hybrid Camry however doesn't have any problems. After that I started visiting these forums and found out about these problems.
Now I'm thinking of giving mmy car to my mom and buy an 07 Hybrid for myself.
It has the look and the feel of the XLE and the same pickup and power of the 3.0L V6 from your Gen 4 Camry. I also had a '97 and a 2000 2.2L Camry.
Since so many of the 99 RX300s are incurring premature transaxle failures I strongly suspect the new shift pattern/schedule was adopted at the beginning of Rx300 production.
The bottom line is that DBW, e-throttle, is not the cause of the transaxle downshift delay but the fix, bandaid, Toyota used to "protect the drive train", prevent premature transaxle failures resulting from the need to downshift without enough ATF pressure/flow.
We also own a 2003 V6 Highlander FWD and have experienced the same.
Good to hear that about Camry Hybrid. I like its front grill. Do you know if i has any problems?
In the 8 months that the TCH has been out I haven't seen anyone complain here on the 'net or in person either.
First: The speedometer/odometer cut out and works only sporadically
Second: The car began to stall at stops RPMs drop sometimes while still stopping, other times once stopped or in park
Then: Had my husband change spark plugs and problem stopped for a few days then came back and..
Finally: Transmission does not always shift while accelerating. For insatance-was doing 15mph at over 3kRPMs.
All of these things happened within about a week of each other. I had my transmission fluid replaced and a leak repaired at the end of November. Also, right after I purchased the car 2years ago I had to have the heads remachined. It has 140k miles on it now. Is this thing a :lemon: or is it not as bad as it seems?
Thanks for your help!
My dad has a 1992 Mazda 626 with 20,000 miles on it. It looks brand new, he is the orginal owner. It just needed a new master cylinder, clutch and some other odd repairs cost about $3,000 bucks
As rubber and other things age problems just occur.
I have chips and tarnish all over my paint. I don't think I could hit a floating cobweb with out a match head size chip coming out. I'm not looking for a new paint job . . . any way to touch and feather these little nicks?
Also, rear passenger door window no longer operates. How difficult is it to trouble shoot these things. Any particular hazards to watch for when you go into the door? Any "common break points" that I should check first?
The problem is the motor is a pancake size device. It looks like you need a special tool to get it out. I know I had no room to pull it out. So I put it back together and I do not use it anymore. Just be glad its the rear window. I would leave it as is. I think it cost like 400-500 to fix.
Probably cost $125+ I had it done on a 2001 Camry CE 2.2L at 50,000 and it had needed it for at least 5,000 before that. Change your plugs afterwards. Air Filter, too.
Thanks for any info.
So try the hair dryer. You don't even need to take the cover off. Be patient. You may be able to push at little from behind.
Isn't it great when you have a car that repairs itself?
Are you a librarian? My wife is, but will be retiring soon.
I should have guessed what was happening because the dent seemed to be getting smaller over time as I procrastinated on going into the body shop.
Now the rear dillema. My tire guy will do a pad job on the rear brakes for about $100. I've been with guy for years and wouldn't have even questioned it except I was at the dealer with my wife's new RAV and asked the service tech how long my brakes might actually go. Anyway after chatting he said they get $250 to do the rear brakes but that includes changing cylinders...EVEN IF NOT LEAKING. He says they likely will leak if he does not change them. I thought this odd so I called another dealer. They said they did not change the cylinder if not leaking and have not seen that many that do leak over the years. Of course there brake job was about $219 w/out the cylinder swap out....very high.
Finally, I believe the cylinders, if leaking are covered under my 7/75 platinum warranty! The original Toyota dude said to check and make sure but even if covered I would still pay to have them replaced today as he could not replace them under warranty they were NOT leaking....but he still thinks its wise to replace them. I asked WHY? He said if they leak and drip on the pads I'd have to pay for the pad job again even though the cylinders would be covered.
This all sounds crazy but I want to be safe...if this even is a saftey issue. At the same time I spent more for the Toyota up front to get away from these expensive repairs...espicially when the part is not even broke!
WHAT SHOULD I DO?
Of course, the brake shoe linings should be checked periodically for wear, the metal insides of the drum should be checked for scoring or excessive wear, and the wheel cylinders should be checked for leakage. This is a routine and easily performed maintenance item.
Generally only the brake shoes will need to be replaced, certainly if the car is under 100K miles. Don't fret about replacing the wheel cylinders if they're not leaking.
New to post, I hope someone can help.
My brother-in-law just got back from Iraq and needed to borrow my 2003 Camry sedan. It was the least I could do.
When he brought it back, I could see right away that something was wrong. The black plastic "molding" was hanging down from the front bumper. He said he rolled over a concrete stopper in the parking lot and then as he backed up, he heard it scraping and dragging all the way home.
I think this could best be described as a splash guard, but I can't seem to find this part anywhere. We bent it back into place for the time being, but it still drags on occasion. I'm afraid to remove it b/c the engine would then be exposed.
Any ideas out there of what it's called and where I could get one or how to repair it?
