I have taken it to a couple of mechanics, and have gotten different suggestions, as no one seems to be able to re-create the problem. One said that it could be the cam shaft sensor. Unfortunately, the particular engine configuration I have requires that the entire distributor be changed in order to change the sensor. He wanted to charge me $900 just for the part, and he didn't even know for sure that was the problem. Great. I don't want to throw that kind of money into this unless I know it's gonna fix it. Is this going to be one of those problems where I just get something changed, drive it for a while and hope I don't get stuck--ad infinitum?
This car has become a problem child; I don't know what to do with it. I don't drive it much anymore because I don't want to get stuck, so it sits parked out on the street, gathering dust, pine needles, and spiderwebs.
Thank you in advance for any help you can give me.
This is my first post on the Stratus; have had many on the Durango! Anyway, my husband has a 2001 R/T and the ignition key won't come out. It started happening once in a while and now it hasn't come out for days. He was looking underneath for some switch but didn't readily find what he was looking for. Does anyone know where this switch may be that is defective and won't release the key?
I am experiencing the same exact problem as the user in message #138. I haven't put a lot of money into the problem yet, except I did replace the ignition switch. I have the 1995 Dodge Stratus 2.4. I am getting really tired of having to replace the ignition fuse everytime i need to start my car. I have talked to people who think that the cellonoid in the starter might be bad? or that it might be a bad fuel pump? Does anyone know what is causing this problem and what I should do to fix it.
Please resond or email me at robe2040@wlu.ca
Matt
What is the high side A/C switch and where is it located? How should I proceed to troubleshoot the electrical? Thanks, Tom
The car still had this issue when I traded it off. I didn't want to spend three-hundred dollars to fix it.
replaced alternator the new on is putting out 14.5 volts when tested but will not charge battery tried another used ECM but still have the same problem
has anyone had this problem
Thank You,
would lije to give car to my niece...17... and she does not need alot of power. is a change over to 4 cyl easy...or what should I do?
Thanks Nate
P.S. Yes my stratus also has the famous "creaking sound" when I turn my wheel espcially when slowing down to park and the oil pressure light also comes and my engine cuts off in stop and go traffic.
-Jess
I took my car into the dealership for some other problems and I mentioned the whining and how it only occurred at freeway speeds. When I picked it up, they said they didn't notice anything. I couldn't believe they didn't hear it, so I asked them if they took it on the freeway. "Nope. But we got it up to about 50 on the road right out here." Uh, hello?. I didn't have time to let them take it for another drive, but I doubt they would figure anything out anyway.
So, I don't have a solution, but I think I share your problem. Anyone have any suggestions?
-Jesse
Thanks...Raven
rdonovan
