Pontiac Bonneville
Some where on the Grand Prix net I saw mention of a GM part number for a pulley assembly for the belt idler, in this case it was a slightly larger diameter idler pully to fit the SC belt tensioner, giving you more rap around SC pulley and you didn't need a shorter belt with a smaller pully. I think it was under $20 with a new bolt so GM does make a replacment pulley without tensioner body.
QTP's are electricly activated and you can set one up for less then $200. Some GTP guy's set them behind the resonator and they aren't that loud when open. This setup will reduce Knock Retard quite a bit when open. And of coarse you can activate partial opening also. I'm going to do this mod as I don't like real loud exhaust systems for highway cruising but can't take KR when I'm racing.
The headers would be nice on your car but I cheaped out and got a set of ported stock manifolds from a guy here in the club who does them for $150 with exchange of your old manifolds. About 12 hp and with the RT downpipe / low restriction cat at 8 hp($300) I'm ready for the Elec. cutout.
belt change.Between the crankshaft pully and the compressor, the engine mount is attached to the block. Between the engine mount and the block there is a spaceer held in place by a hex bolt going thru the engine mount bracket, spacer and into the block. Your best access to this area is thru the right wheel well. You do not have remove the tire, but the wheel must be turned to the right.You may have to purchase a deep socket for this service.Once the bolt and space is removed,release the tenioner for belt removal.
This worked on my 95 Bonneville.
I have TOG headers for the SSEi, on the way. I going out to Intense in Columbus,OH to have Scott Cook install them.
I may see if he can also do an LSD.
I have next level sway bars and strut tower braces on the way for the GTP. I am going to have local shop install them.
My future plans for the SSEi on the Intense 4T65E HD with 3:69:1 final drive ratio and a custom Digital Horsepower chip. I need to wait for DHP to do a 2002 chip before going to new trans, do to speed/rev limiters.
I plan to install a Quaife torque biasing differential for the GTP, along with DHP chip, and Intense rocker arms and headers.
Who would have ever thought that things would come to this?
Question is, though, why has it taken seven trips to the dealer to get this far? They should be collecting data from the vehicle right off the bat, even if they "think" they know what the problem is. There may be more to it and that information might save additional trips to the service bay.
But then again, I may be expecting too much...:-)
One issue, the dealer recommended 5w30. When I pointed out the manual said 10w30 they said the manual was wrong and than printed out a couple pages from their service manual. The pages they printed out from the service manual had several typos so it didn't look correct and since my 2001 gtp has they same reference to 10w30 I have to think they are full of it.
Where can I get the definitive answer on 5w30 or 10w30?
Please keep us informed on your experiences.
Ken
Chuck
And another problem is that the manual requires or recommends the preminum gas. ANd it seems that in those kinds of gas, there are lots of additional material. So I just wonder about that.
I may choose dealer since maybe the mechanics there know the car better.
Thanks mfahey1 again.
Hope you have had a good summer. I finally have placed the picture online with Yahoo.
Hope everyone enjoys the pictures....sxb
http://photos.yahoo.com/xavier64_pa
Take care everyone, back to work.zzzzzzzzzzzzzz..sxb
No disgusting body cladding and very sleek lines. A much improved front-end too.
No shots of the interior, but hopefully Pontiac is abandoning it's cheapo Fisher-Price interior look. Now if only Pontiac could combine their exterior with the Oldsmobile interior styling, they'd be much better off.
Not to get on a rant, but the revamped 2004 Grand Prix exterior styling looks nice too, but the pics of the interior seem to indicate a continuance of the cheapo plastic styling.
As for the Maurader, well, it is a Ford when all is said and done but it would be one of the all time sleepers. Traction in snow?
Good News: The tires are quite, quite grippy in the dry, and very secure feeling in the wet. These were the things I was most concerned about as it snows here in S.E. Virginia once or so every year, about 1/4 inch which lasts about 1 hour.
Bad News: The front tires were completely worn out after 11K!( I do not drive the car hard, although my 17 year old takes it on dates every now and then.) The rear tire's tread had about 85% tread left. The dealer I bought them from replaced the tires under warranty, so we will have to see....
Has anyone had these problems
1. Weeping power steering hose requiring 1/2 bottle of fluid to repalce lost fluid?
2. Clicking in steering wheel when turning or stopping?(TSB on this one-supposedly wrong lube on steering joint)
3. Air compressor failure ?
4. Trailer Hitch puncture of front bumper ( Ha Ha, my fault)
5. Strange banging noise from moonroof closing which
always disappears at the dealer?
The good news is that since both front tires are worn out, it is highly unlikely your son is responsible. Unless he had the initiative to fry the first tire on the right front and then rotate them so he could fry the other one, you would think only the right front one would die due to abuse, which is only too easy to do on this car.
I personally haven't had any of the other problems you mentioned, thankfully. Water in the trunk, now that's a different story.
Sorry I've been reclusive of late. Those pics from Pa of Steve's car and mine are great - thank you Steve. Hope you're well.
Looks like the traffic is pretty light around here these days. I don't frequent the boards as I used to but do want to stay in touch here. The car is just fine other than an annoying vibration from my tires - have 18K on the Aquatreads now and seem to have feathering. Not sure what it's from but it's almost unnoticeable now that the fronts have been rotated to the rear.
Summer went by fast - lots of hot weather and great fun at camp. Going to have to get some pine pitch off the car now - always a nuisance there under the pines even though I use a cover.
Take care all
Ken
It has been a great summer, fun with cars and boats... it is just great to reaping the fruits of all those years of hard work
The first time I tried to use the compressor I thought the same thing... i.e. is this thing broke? The controls are a bit quirky, if I remember right ya push the button to start it, then push it again to stop it. I was trying to push the button and hold it to pump air, and that didn't work.
I still love the SSEi... it is 2 1/2 years old and it has been flawless... never been in except for oil changes (and a back bumper replacement which was clearly not its fault.... some jerk in a Suburban didn't see it)
Bill
