The Lexus is an OK car but I never looked at Lexus when I purchased a 9-5 SE and 9-3 in 1999 and 1998 respectively. SAAB wooed me with its torque, its utility, its safety and its design (comfortable seats, cargo capacity, cockpit). The SAABs just stirred my soul and excited me unlike the Audis, BMWs and Volvos I test drove.
As for value, you can not beat year end close out deals on SAABs.
The fact that you are torn between a Lexus and a SAAB tells me you want the SAAB but feel the call of the majority beckoning you to select the quality leader like a lemming heading over an Icelandic cliff.
If you plan to trade or sell in two to three years, sure buy the high demand Lexus, but if you are committed to a long term relationship with an ageless car that will grow on you like a leather jacket, get the SAAB. If you already test drove the 9-5 and you still are undecided, buy the Lexus because you "lost that loving feeling" for SAAB and it is that fanatical love of SAABs that makes SAAB owners so loyal to the brand.
Right now I'm running 40psi for normal driving with 1 to 2 people in the car and I'm wondering if I should be running more. I realize 40 is above Saab's recommendations, but I don't mind trading off a harsher ride for a noticeable increase in handling, fuel mileage and tire life. As higher pressure also helps preserve tires and wheels when hitting holes, I'm wondering if I shouldn't increase it. Any comments?
Thanks/Mike
i keep mine at 38 psi all around but still had a blow-out.there is no way to prevent it.--it all depends on what you hit---the speed---and the angle at which you hit it.
on a long trip i have gone to 42 psi.and it is comfortable.
but,if your car is not loaded you will wear out the center of the tire faster than at lower air pressures and prematurely.
the air pressure is determined by your load factor
and speed.
By the bye, I have kept my tire pressure above the manufactures recommended pressure, usually 5 lbs. or more, for many years. I have never worn out a tire in the center before the edges. This could be partially because I drive hard but I suspect it has more to do with steel belts. Bias ply tires deformed a lot under pressure and over inflation would chew them up in a hurry. Good steel belted radials, are much more tolerant of higher air pressures. I suspect that the idea that higher then recommended air pressure wears out the center of the tire faster is more myth hanging on from the bias ply days than reality.
i too have always kept my tire press. above rec.
specially in s class mb.
and,i do wear out the center first. i get about 18,000 miles out of michelins.
mxx---many years ago up to the new mxv4's
18,000 miles out of michelins.<
You guys were leaving me scratchin my head with all these psi recommendations. It just didn't make any sense to me and goes against everthing I've been told.
18K? - Now I know I'm doing the right thing. If I only got 18K out of a set of tires, I would be very upset. With the vehicle I use for business that would mean almost two sets per year! I've always followed vehicle manufacturers recommendations and aside from one minivan I had, I always got close to 40K before replacing tires. However, I don't have the Aero wheels and tires. I realize 40K would not be possible with those types of tires.
Drew
You might have a clogged drain leading from the AC evaporator or heater core. Acccumulated moisture can create mildew which could cause the smell you describe. On the 9000, the well that contains the evaporator also houses the cabin air filter. This well accumulates a lot of crap--leaves, bugs, mice, etc. I'm assuming the 9-5 has a similar setup--with the well hidden under one of the panels at the base of the windshield.
Find and clear any system drain tubes, locate and clean out the cabin air filter compartment. If that doesn't work, the dealer or an AC shop can decontaminate the system, which usually clears up the problem.
If the smell is noticeably sweet, you have a coolant leak somewhere in the system, which would be a warranty item (it's worth keeping an eye on your coolant level, just in case).
Inflation pressure also affects handling and it used by manufacturer to adjust a cars handling. On one extreme, Ford used very low pressure to cure a rollover problem with the Explorer. The low pressure let the tire break away before before generating enough force to cause rollover. It also caused overheating and failure of the tires. More commonly front and rear tire pressures differentials are used to tune the handling or compensate for the difference in handling between partial and full load. Another adjustment used by manufactures is lower pressure for a smoother ride at light loads and higher pressure to keep the tires from overheating at high speed or high load.
The lower temperature at high pressure is due to less internal friction in the tire. This is where the increased fuel mileage with higher inflation pressures comes in, less internal friction equals lower rolling resistance. The better handling is due to tread squirm, the higher pressure keeps the tread blocks from closing up.
Part of the problem with tire/wheel damage on the Aero is due to the tires. The MXM Michelin they come with are designed for high performance (soft rubber) with a smooth ride (soft side walls). This leads to a tire that probably won't last longer than 18,000 mi. and is susceptible to damage from pot holes, etc. Increasing the inflation pressure will partially compensate for the soft sidewalls though and minimize pot hole problems.
Hope this helps.
Thanks for posting a well thaought out and informative note.
Joe
The lysol should kill the mold and bacteria in the system making the smell.
i do think it's weird that the air intake draws air from the engine compartment. Not the best in stop-and-go traffic.
We got 40K miles out of out mxv4 tires. It should have been 30K miles, though.
dave
or,8500 on a 911.
it all depends on the tire compound. the stickier the tire the softer it is and the less wear.
driving habits also influence the wear.
My opinion: I can understand the trade off on a limited use vehicle such as an NSX or 911; however, now that we are seeing more high performance designs on "Every Day" type sedans I would think average customers would be very upset with such short tire life. As long as a customer is well informed in advance,(LOL, who do I sound like now?) I guess it's fine but I sure would prefer a longer lasting tire with acceptable performance on my every day car.
Drew
to my surprise my aero tires have about 19,000 miles on them and it looks that they only have about 35 % wear---not too bad for this tire. i had thought that 18,000 miles was the limit for this tire.
Although the car's manual recommends oil changes at 16,000 km intervals, the dealer recommended service every 8,000 km. In addition, I was given to understand that Consumers Union downgraded the car's reliability - previously "outstanding."
I would be very interested in hearing opinions of other customers, especially those located up north. Thanks and best regards - Peter
Todays oils will hold up fine for the longer intervals but my concern is more about debris such as metal flakes that will be present by waiting to change at a longer interval.
I'm not sure what types of "early wear" your refering to but ours is almost 2 years old with over 20,000 miles and everything is holding up as expected or better than expected so far. But we have been the only owners and it's always garaged.
We probably aren't in a climate as cold as yours but we certainly are in a colder climate and consider the 9-5 to be a great cold climate car. If a cold climate car is what you wanted I think you chose well. Remember, in Sweden & Findland (where they do use the metric system and have tons of Saabs) it's much colder. These cars were built for their brutal conditions.
Good Luck to you.
Drew
I heard about the ECU problems, but I got the impression that they affected essentially cars made for the US market - and showed up primarily in hot and humid weather conditions. Is this correct? I currently reside in Newfoundland, part of Atlantic Canada. I wonder whether the 2000 model was affected - and when these problems were corrected by Saab?
I have driven in the Scandinavian countries; mostly Volvo rental cars, but also a base Saab 9-5. Fortunately, they have better dealer service networks, and it would appear that parts availability and service costs are better than on our side of the pond. I believe there is room for improvement here, and hopefully GM will take the initiative.
As far as the Consumers Union reliability ratings are concerned, they tend to be pretty accurate. For instance, we also have a Toyota 4-Runner Limited - not much fun to drive, but absolutely reliable under our rather severe driving conditions. The only problem we had were warped disks, which were promptly replaced under warranty.
I hope that our experience with our new 2000 Saab 9-5 (2.3t) will turn out just as positive. It certainly is fun to drive hard...
I look forward to further comments. Thanks and regards - Peter
as far as saab is concerned,they rate poorly in this area going back many years.
but,the new ones seem to have improved.i own an aero and so far ,20,000 miles it has not let me down. but,saabs are known for massive failures after 60,000 miles.
we will see
1)don't listen to anyone who talks asthetics. beauty is in the eye of the beholder. you'll have to make that call on your own.
2)you can also ignore those that talk about the saab as if the uniqueness of the car is all the reason you need to buy it. at the risk of sounding like a saab sales brochure; 'real' saab owners buy into the saab philosophy. unfortunately, there are plenty of folks that buy a saab so they can make a contrarian statement about themselves based on the car's reputation. these are not 'real' saab owners. being different just for the sake of being different is just as mindless as doing something because everyone else does.
3) the lexus is a ringing endorsement of japanese engineering. it is a fine car but, as a saab owner, i couldn't imagine myself in a lexus. the two cars may both be classified as entry level luxury sedans, but they are worlds apart (no pun intended)in design and operationl philosphy. they are not comparable cars in my mind.
the reason 'saab-o-philes' exist, and they do, is because of the automotive nuances that you'll become aware of after spending time in a saab. as i said above, these nuances are not a reason in and of themselves to buy the car but, realize the car is different and determine if those differences suit you. i personally would highly recommend a saab purchase.
if all of this sounds too esoteric, please feel free to disregard it.
good luck!
Thanks to Julie at Countryside Saab in Maplewood, MN for all the assistance. I must have visited the dealership at least 6 times, and Julie was always very positive and helpful, especially the day I spent a good hour and a half driving around with her checking for the fuel tank "thunking" problem (I never really heard it, as I said when I posted on this topic a while ago).
The first thing I did was to adjust the amplifier volume as explained by SMU1976 in post #214 -- the stereo gets REALLY loud during the adjustment, but (just as SMU said) mine was at the default of 9 or 10 and I raised it to 25. It helps a bit to turn down the standard bass and treble controls during the adjustment period to take the "edge" of the noise. As predicted, the volume adjusts back down in about 8-10 seconds and sounds much richer (dont forget to return your bass and treble controls to neutral after the adjustement). I wonder why Saab sets the default at 9 or 10 when it has such an obvious effect on the sound?
I'm looking forward to going through the owner manual of my new "toy" and I'll try out the OnStar
system on the way home tonight! (Geez, thats a "toy" within a "toy"....)
My wife and I recently had our first child and felt the urge to sell/trade our Inifiniti G20 and purchase a larger, "safer" vehicle, i.e. more safety features. We already own an SUV so we felt that the proper replacement car would be a mid-sized "entry-level luxury" class car. The vehicles we compared from this class included the base models of the Infiniti I30, Volvo S70 and S80, Lexus ES300, Audi A6 and the Saab 9-5.
Although the I30 was a very roomy vehicle with nice amenities and the least expensive of the lot, we were so disappointed by the "soft" market price (as the Infiniti salesman had warned us) for our Infiniti that we felt it would be unwise to purchase another Infiniti and suffer the same fate down the road. On top of that we felt the I30 was rather ordinary and derivative in design (to quote Edmund's review of the car). And although the commercials for the car would lead one to believe otherwise, the car wasn't all that quick considering it had 225 hp. And to top it off, I hate FAKE WOOD!
We ruled out the Lexus because we felt it was nearly comparable to the I30 but was grossly overpriced, at least it was not worth 4-5k more than the I30. Besides, we felt that "everyone" owns a ES300 and did not want to follow the pack.
We ruled out the S70 largely because it was already an outdated and obsolete design, having been replaced by the S60 by the time we had commenced our search. But that having been said, there were some really goods deals available.
The base model A6 by far had the most luxurious of interiors, but my wife despised the design of the car's backside, and I was not impressed enough with the car performance to be willing to pay, in my opinion, Audi's rather lofty pricetag.
So, we came down to the S80 and 9-5, the two cars that we felt were the most highly rated "safety" choices among our group I researched both cars rather extensively, including the sharply polarized views of those folks posting on this site concerning both cars. We were so torn when it came down to our final decision that we chose to test drive the S80 over to the Saab dealership and compare them head-to head. We both agreed that the Volvo, notwithstanding its FAKE WOOD(!!) interior, had a more luxurious and somewhat roomier interior, but we preferred the Saab's quickness and the Saab's sportier interior design and driving experience(including the 5spd manual transmission, which Volvo does not offer in its base model). The other most influential factor was Consumer Reports having given the S80 a very low reliability rating (I am not surprised having spent some time reading the S80 postings on this website).
We have owned our 9-5 for almost one month and we both love the car. We are very pleased with our decision. We have not had any "fuel thunk" problems or "ECU" problems and we have received excellent service from our dealer, which unfortunately is the only Saab dealer in Houston, which all along has made us a bit uncomfortable about the Saab. Nonetheless, we feel it was worth the risk.
Having said all of that, I don't think anyone could go wrong with any of the cars we tested. We chose the Saab b/c we felt it had the best combination of safety features, price, "sportiness", interior luxury, uniqueness of design, fuel efficiency and dealer service.
I could probably drone on with data and statistics but I will refrain.
Drew
dski, actually the real wood in the S80 looks very similar to the fake wood (I've got the real wood in my '99 S80 T6 so I know). In general, real wood these days usually looks pretty fake or plastic like in appearance. This is due primarily to safety considerations. I'm not sure if there is a regulation or if it was voluntary but most manufacturers have resulted to highly lacquered wood in order to prevent splinters in accidents. The result is that more and more real wood looks shiny like plastic. I'm beginning to think less wood (and more carbon fiber, brushed aluminum, etc._) is better with the exception of true luxo cruisers like the S Class and LS430. Just my opinion.
-rdo
rdollie@home.com
The recall notice categorized the recall as "emissions related." The notification said that sulphur, in the rubber mountings for the printed circuit, may cause a chemical reaction that may damage the electronics in the ECM.
The anticipated replacement time, according to the notification, is approximately 20 minutes.
Believe me, after having replaced many major components on my 1999 S-80, except the engine itself, this MINOR recall doesn't even register
on my radar.
By the way, as far as I can tell, my Aero has shown no ECM related problems after 10,000. No squeaks, rattles, very tight.
Which engine do you have? If I absolutely flog my V6 ('99) the worst mileage it gets is still in the high teens. Additional things to check for might be clogged air filter or exhaust (unlikely) or a dragging brake.
If you have the LPT 4 automatic I'd think you should be getting in the low to mid 20s in town and low 30s on the highway. You should also calculate the actual mileage the old-fashioned way, because the EDU could be off as well.
Doug
FWIW, I have used systems similar to the Saabs, ironically I just spoke to someone this morning using one, and I think they are GREAT. If the Saab were my work vehicle, there is NO question that I'd have it installed.
Hope this helps.
Drew
Dave Kovacs
No luck. Had the hard wire harness put in by Saab, then to ATT shops to connect to the nokia.
Three shops could not do it. They could not figure out the Saab wiring and how to connect to the Nokia. Lost out on about $250.00 in labor and parts. My 92 9000 Griffen came with the Nokia installed and its great when it works. Radio goes down when phone rings, speaker and mike built in. But the cell phone models change so frequently now that it is does not match. If someone got it done, help me. I have a harness of wires under the dash with no home.
Jim
Thanks for your comments,
Kevin
Audi more reliable than Saab
Audi more reliable than Volvo
Lexus more reliable than (hmm anyone?)
What is an evilpancakewoman? ;-)
I have never really thought of driving any U.S. car for direct comparison purposes against the Saab 9-5. I guess the most likely cars to compare would be a Cadillac Catera (not a pretty package -but a newer and quoted 'nicer' ones debuts next year). Olsmobile has a possible offering to compare . . . however I honestly don't see a drastically similar U.S. car to compare.
I guess when it comes down to it - - the only person that can best determine if something is worth the money is the actual buyer. Most opinions expressed here are going to be highly polarized. It seems you like the Saab for its design and look . . . but only you can weight all your options, needs etc.
Good luck in your decision.
Dave Kovacs
If you are truly down to 2 cars, you ought to test drive the Audi (sans salesperson) over to the Saab dealership, or vice versa, and compare them head-to-head. We did that (see my "Two Cents" post from last week) and it greatly assisted us in our final decision.
I agree with SMU1976. On similarly appointed cars, you will get a much better deal on the Saab than the Audi. We compared MY 2000 cars and the Saab was avaiable for about $4-5k less than the Audi.
For what its worth my suggestion to you is to GO WITH THE SAAB BABEEEE! I really enjoy mine. Good Luck.
The '99 model A6 was bog slow so I didn't have much of a problem discarding that option. A very nice car to be sure, and the only AWD option in the bunch. I'm certain I'd like driving a turbo A6. As to Audi reliability, go see their forums. It's absolutely clear that they suffer from far more engine problems than do Saabs. Saab's I4 is one of the stoutest engines in the industry.
Drew
Regarding leasing, can anyone provide input on the approximate % residual Saab uses when calculating a lease. I'm trying to do the rough math on a lease for the SE and Aero.
Much to my surprise, I've been driving in 3-5" of snow for the past few weeks on the stock Aero 225/45 - ZR17 Michelin Piolt's with 14K on them and have not experienced any difficulty. Along with the TCS and putting the automatic in the "winter mode" driving has not been one bit problematic.
Anyone had any problems with the stock tires in the snow or have you switched to snow tires? If you have switched, what's your experience?
