Inspections: What are you referring to by inspections, state inspections?. If this is the case, any authorized center (the gas station, tire shop, etc. around the corner should be able to provide this) otherwise, the manual doesn't mention anything about inspections outside routine service.
Hope this helps in your decision.
Think about it pierce1, if everything goes well, you will only taste your BMW dealers coffee and donuts ONCE a year!!! :-). And believe me, their coffee is probably not that good, although, there are some dealerships that are worth visiting. There is one in Kansas City that reminds me of the Guggenheim museum, worth a trip every week just to check it out!
mfeldman - Shipo's 328's steering was marginally heavier than my 325i's retro'd steering but I'd say road feel was the same.
sunnybrook - I would not take a stir fry pan for an oil change at Jiffy Lube. Not any more at least - I used to take my "disposable" cars ($200 cars that run for a few months before you junk them) there back in college.
any others with same situation??
ps - i checked oil levels and it seems fine.
stg
Best Regards,
Shipo
Best Regards,
Shipo
Best Regards,
Shipo
I now have my 330cic, it is a lot of fun. Got here quicker than expected produced 4/19 recieved 4/15.
Shipo, out of curiousity at a high level when do they deploy vs not. The manual says that the air bags deploy in some rollover crashes.
The following are the links to the sites that I have just referenced:
http://www.edmunds.com /ownership/driving/articles/43822/article.html
http://www.autosafety.org/Airbag/AdultDeath.pdf
The following links contain other airbag information that you might find of interest:
http://www.solid.ikp.liu.se /Research/po2.htm
http://www.ibl.vt.edu/research.htm
http://www.intellimec.com /products/controller.htm
I hope this helps. ;-)
Best Regards,
Shipo
P.S.
For some reason this site is fussing about the above links being longer than 115 bytes (silly, I know), so please remove the spaces from the Edmunds, Solid and IntelliMec links.
Jean
As for changes for the 2003 model year, my guess is that there will be virtually no change for the sedan versions of the E46, however, there may be some minor face lifting for the Coupe and Convertible.
Best Regards,
Shipo
One mistake I made was I added too much oil. After I checked on the dipstick, I thought I was really low on oil, but if you read the manual carefully, a low level on the dipstick equates to less than a quart. After I added the oil, the light hasn't come back on again. I think that it is not atypical for new bimmers to suck up half a quart of oil in the beggining.
Anybody else on the board have a different thought?
I am referring to state inspections. I prefer to take it to the dealer where I bought the car. I have had bad experiences before with the "gas station around the corner". They always seem to find the burned out turn signal bulb that I know wasn't burned out when I dropped off the car, etc.. Otherwise, they can't cover their cost on inspections. Also, I had a minor sidewall (just barely in the sidewall) puncture in a fairly new tire once. It was plugged, and had been driven hard for months. No problems, whatsoever. Wouldn't pass state inspection, though, by the letter of the law, so the local BP failed me. I wasn't about to pay another $150 for a new tire and have one tire with different wear characteristics than the other three, so I took it to the Dealer. They either didn't catch it, or they let it go because they didn't want to make me mad. Either way, that tire passed two more times at the Dealer before it wore out. The Dealer has an incentive to keep you happy, especially if you lease.
Side view mirror: It turns out I did have the mirror adjust over to the passenger side. Once I moved it over to driver's side, it tilted again. It's something useful to know.
I've taken my cars to the local Munroe (which is probably no better than Jiffy Lube) for years. My Maxima runs perfectly after about 12 oil changes there. An oil change is an oil change (I've done many myself) as long as you use a good filter, fill it to the right level, and it doesn't leak when its done. A monkey could almost do it. Other than the mess and inconvenience, I'd continue to change oil myself. What,...you guys think the oil changers at BMW are brain surgeons? They're probably the young guys that just graduated from lot attendant, and aren't good enough do real mechanic work, yet.
I'll take my BMW to the dealer until the free service and warranty runs out, then its back to Munroe, where an oil change costs $25, not $125. This free service is one thing that makes the car a good value, and allows BMW to do CPO with confidence.
The only other thing to consider is that the oil-change light on a BMW needs to be reset. I don't think this can be done by anybody but a Dealer. Can anybody help on this? If it can't be reset, then we may be stuck paying the price forever.
Naturally I check my 325xi wagon at the same time and found it about 5/8th full. At its one-year service (12,600 miles), oil level was at 1/2 between MT and full. Seems like the 330 uses more oil during break-in than the 325.
BTW, what are your dealers doing?. The dealer listed $34.97 (charge to warantee) for the oil change using the BMW branded filter, synthetic oil and adding windshield washer fluid. I heard another person, who's car was out of warantee, get charged the same thing for an oil change. At that cost and a car wash thrown in, I'll take it back to the dealer in a heart beat.
1pierce,
You can purchase a simple tool for about $50 that will reset your oil light. You can even make one with a couple of wires and bits from Radio Shack. For $150, you can even get one that will read OBD codes. Try Peake Research. I often hear people changing the oil, but not reseting the lights, then during the Inspection I or II, they have the dealer reset the light. Some say the car will go right past the Inspection point mileage without turning on the light.
One other thing: I don't know about you guys, but my left front wheel is always the dirtiest on the car, my fronts are always dirtier than the backs (due to brake dust), and my left sides get dirtier on average than my rights. Probably because the car passes oncoming traffic on the left side. As such, I like to rotate my wheels so that they wear and take abuse evenly. Of course, I care more about the cosmetics of the car than many of you road racers.
The debate is always lively here, and very fair-minded. That's what I like.
Sounds like his experience was as much his fault as the oil changer's.
Jean
That guy was LUCKY he got his engine replaced.
Its called personal responsibility, people,...take some! OK, I admit, that was a little harsh.
anyone ever experience the same problem? Anyone knows the cause of this? Thanks.
Well, I guess he is a decent attorney (yeah, he is a lawyer and he argued on it himself). He does have problem with those common sense stuff, though.
1pierce:
We could definitely use more of those all around.
Now back to our regular programming...........
As for future changes, I would not bet on any engine changes until the Valvetronic system makes its way over here on the I6 engines, which, the last I heard, was going to be something like 2004. When that does happen, my guess is that the 3.0 I6 will produce something more like 270 HP.
Best Regards,
Shipo
Tire rotation - OK, a set of 4 tires costs say $600 and you get 25K miles out of them. That's 2.4 cents a mile. You rotate the tires and you get another 5K miles out of them. You just saved yourself $120 but paid about the same to rotate the tires every 6K miles. And pray you don't get warped rotors and or upset the balance of the car.
Magazine rankings - who cares? Automobile magazine is readying a comparo between the IS300 and the G35 for SECOND place because they say the first one is reserved for the 3-series. C&D already mentioned that the G35 does not measure up to the 3-series when pushed hard. But the G35 has all that extra horsepower. Great! the Mustang SVT has 390 HP and it is about the same price, if not even cheaper. Does it look, handles, sound, smell the same? Does it make you as happy driving it?
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
After two days, I noticed the infamous brake dust on the wheels. I'm about to order Klasse...
Do you folks use all-in-one on the car, too? How should it be applied (e.g., after a regular car wash), and what material should be used for application (e.g., micro fiber, terry-cloth towel, etc.)? Also, what about frequency of use?
Ive had service a few times at my non purchasing dealer inspection, fix a flat ect, and it had been fine, these are not loaner car situations , but wait 45 minutes.
1pierce: only those oil changes and Insp 1 and
2 are gonna get your a loaner, at least a BMW loaner.
tire rotation: Discount tire will do it for free, however i dont like the marks left on the wheels from rebalancing.
DL
Rotation: Numerous posts about why is not worth to rotate tires on BMW, particularly since they do not recommend it. I will like to add that the 50/50% weight distribution is another factor against the need for rotation (compared to a nose heavy, FWD car). Also, remember that the rocket scientists at BMW will charge you an arm and a leg for a tire rotation, you know all the SKILL and TECHNICAL EXPERTISE involved in doing it!, so beware.
Loaner: I will advise you to read the fine print, the dealer from whom I lease mine, will only guarantee a loaner for routine covered service and NOT for warranty work, so again beware (hey they still gave me a great, (ok good) deal $1500 over invoice and low money factor).
Oil change: So you (or not you but other people) think BMW is much better than your local lube? Until recently, I used to change the oil on our cars myself. The single time my wife took our accord to this nice, shiny friendly smiley dealer (who even gave a loaner, wow, Honda, loaner wow), they forgot to replace the filler cap, which fortunately, was laying on top of the motor (I got lucky, something bothered me and as I opened the hood (after driving back 10 miles), I saw it) So for the 3rd time, beware (I know, Honda certified mechanics are not as skilled in changing oil as BMW certified mechanics, so this particular experience cannot be extrapolated, yada yada yada, fine, JMHO).
Use your free service at BMW of course, but after that, as long as you can reset the light and use the right oil, anybody, anywhere can do it. (Again, there is this dealership in Kansas City, beautiful place, good coffee and Danish, free soda (or pop depending where you are from), cute receptionist, it might be worth the trip)
I don't know, but if a car causes me so many problems, probably I would not buy it again.
I hope your beammer is providing you with many smiles on the road to overcome those dealer visits. (or perhaps the recepcionist are your dealership is also cute (:-)
In my book, that is a no-no.
I will give it a chance next time. Competition is great, lowers the price of the cars, increases the incentives, forces the companies to improve on each other.
I love the G35, the IS300, the A4. I am a car enthusiast.
Please, GIVE US MORE GREAT CARS, so you guys can debate about them, car magazines can sell more comparo issues, and we can buy our next one for less!!!
Hey, thanks to Nissan, BMW will probably increase the HP of the engine in the future without increasing the price. add more standard futures, so I can lease a better BWM next time. Thanks Nissan, thanks Infinity, I LOVE the G35!!!!!
Tchau for now, VK
-nobee
