I will post again after I have the new parts installed on Wednesday.
twoof1; thanks. I just hope this fix is more permanent than the "permanent" fix they told me they were doing last summer... :-(
Happy birthday brave.
I got my pedal replaced 2 weeks ago, it seems to be working fine in So Ca (90's everyday). I think I was about the first one who posted with this problem last year. Finally over!!
Be sure that they need to order (if not in stock) an adapter plate for the replacement.
Good luck
Dan
• while driving since 4,000 miles my drivers side seatbelt tightens up considerably so that the lap belt portion is REALLY tight. In fact, i have to get some slack and then it creeps and tightens its way back to the uncomfortable zone.
Between that and the constant clicking should i just get in replaced under warranty? they've already greased it up for clicking but it didnt change anything.
Oh and for the record:
1985 - BMW 3.0si (dads old car)
1986 VW Scirroco ("Mars Red" / Orange)
1989 Subaru wagon
1992 (while living in japan) toyota 'sprinter' -
like a camry
1994 saab 900se (8 years)
2002 bmw 330xi
stg
Anyway, I recently noticed a grinding/clunking sound coming from the rear passenger side of my E36 (40K mi.). It seems to be most prevalent when I first start driving and at slow speed. It sounds loke a CV joint problem but I'm hoping I'm wrong.
I've kept current on maintenance (dealer and independant) and would expect that a worn boot would have been picked up at my last inspection, a Type II at the dealership.
Any insight you could offer would be appreciated. And I can keep the wife in her place toboot.
P.S. Happy birthday brave. Saw you over at FAQ's and it was good to "hear" a familiar "voice."
Anyway, I'd get into a dealer. My dealer is awesome though so that's easy for me to say.
-Colin
Thanks and best wishes to all, especially proud new owners!
Ed
Easy install at http://www.bmwnation.com/ARTICLES/diy/bmwut/bmwut.html
Good luck!
Best Regards,
Shipo
IIRC, changing out the shock mounts isn't supposed to be too big a deal - assuming that to be the problem - and the hot set-up was supposed to be to replace them with the heavier duty shock mounts from a M-3
For what it's worth.
I have the natural brown leather with the light interior. My UGO plate is black. I rather like the look. It goes with the other black in the interior (dash, floor, etc).
-Paul
I am not going to sound very intelligent saying this, but I would:
1. Check closely the suspension, there must be a worn component that probably needs replacement.
2. How about ball bearings?
orkwis - good question, I'd like to know the answer to that too. I am thinking, you won't necessarily use all 400-watts on your home stereo either but it will sound better at 20 watts, no?!?
I dont really know what the plate does,but make sure they ordered that for you. It needs that to complete the pedal assembly installation.
I had dead spot before also on fwy driving at around 3500rpm. I am not sure if it is related to the pedal. The car just feels a lot smoother now, no more rough(jack rabbit)start. I hope this is the end of this problem.
I live in the L.A area and its been 90's and up everyday. It seems to be working great now.
Dan
I live in San Diego Country, CA and I looked for the best deal all the way up to Irvine, Riverside, Long Beach and LA areas but the best deal I got was from Harloff BMW, Encinitas, CA. For those in SoCal, the number is (760)753-6301. Ask for Hank Young, or his extension is 103.
BTW: happy belated birthday. I get to 40 in 3 months, funny that I still think like I did when I was 16!
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
orkwis: Speed rating is closely tied to handling characteristics. Most Z-rated tires will never be driven at 150 mph (isn't that the Z-rating?). But, they are typically made of a different rubber compound than lesser rated tires, have a different tread pattern, and have stiffer sidewalls to provide more grip on dry surfaces in fair weather. As such, Z-rated tires typically ride harder, make more noise, and have lower wet/snow grip than H-rated tires (again, because of the rubber compound, sidewall construction, and tread pattern). For most people, I think H-rated tires are fine (I got the base tires on my 325i). For performance oriented drivers, or those that race their cars, Z-rated tires are preferred for added lateral handling, not increased speed.
Is that an antiseptic enough explanation so as to avoid starting the tire flame war again???
I am loath to start the G35 discussion again, but...Nissan is making BMW and everybody else look really shameful in the horse power game these days. And they make very nice V-6's, too.
Altima, Maxima, G35,...alot of punch for the buck. I expect Nissan to cut into BMW sales in a big way in the next two years, which should help us see the 200 HP barrier broken in the base 325i.
Just for the record, I am elated that Nissan has raised the HP bar, just like Toyota/Honda raised the reliability bar, and Audi/VW raised the interior style/materials bar. Its really no different than what BMW has done in the handling department. 5 years ago, cars like the G35 and IS300 didn't exist in Japanese design. Its good for all of us consumers.
the camry's v6 is 3.0L. the base 3er has but 2.5L, thus I doubt it's going to get to 200HP very easily-- and even if it did, it would be not-so-useful high rpm power.
so I suspect you're mistaken. I think the big engine needs to move beyond 3.0L (besides the M3) before the standard powerplant is any larger or significantly more powerful than today's 2.5
-Colin
Yes Nissan is making everybody look at HP, at the expense of gas mileage and pollution.
As previously posted by another purchaser, when I went to the dealership to pick up my car, my brains nearly spilled out of my head! Comments on the first week... well, most of you already own bimmers so, you know...
The car represents an evolution as my first two cars were also had a straight six:
1972 Datsun 240Z
1974 Datsun 260Z
1986 Honda Accord
1981 Alfa Romeo Spyder (still have it!)
1989 Acura Legend
2000 Toyota 4runner (my wife's)
2002 330i
Thanks again,
msj330
In the spirit of sharing, I have Z rated tires and heard some squaking (not here) about tire noise with the higher rated tires but I really do not notice increased noise level. I will say that I feel totally comfortable at 100mph with my tires, Bridestone Potenza S-03 (Pole Positions), and I think some of that has to do with knowing my tires are qualified for the speed. Winter tires is another story in the noise department but for the traction and safety would not go any other way.
I think Motor Trend(don't remember) did a excellent comparo with the Lotus Elise. This is not a high HP car but it was made for the track. It has the mannerism of a go kart. I really want to know what do people expect in their BMW.
That is not to say I wouldn't mind faster bigger stronger engines. But the arguement bigger is better, is not necessarily the fact.
Many here have said that the 330 would be nice to have, but they are still trying to master the 184hp of the 325's I-6.
My Saab's lowly 2.0L Turbocharged 4 banger pumps out a meager 185hp (15 less than your magical 200hp mark). The torque peaks at around 1950RPM and the car gets out of its own way when I need it to.
I'd pay for bmw's reputation of an ultimate driving machine, and i do it again never thinking twice about those other wanna be's.
See their product offering list at http://www.dinanbmw.com
Best Regards,
Shipo
1. A BMW is a good value. Not only because of handling and performance (since that is of subjective importance to each individual), but because of the amount of performance, luxury, and technology (which can't be understated: DSC, brake assist, steptronic, all those air bags, suspension and steering design, etc.). When you think that you can get all that, plus prestige, for under $30,000 without having to buy a 4-cyl (or turbo-charged) car, now, that's a good value. When you look at the technology of an Acura TL, or the performance of a Passat V6, they really don't compare, and IMO are not better values.
2. Nissan engines utilize larger displacement, and are slightly less efficient in delivering HP.
3. Camrys and the other cars we are discussing don't handle or feel like a BMW, and are therefore less fun to drive fast.
4. Europeans have different needs, desires, terrain, incomes, and driving styles than Americans. If I had to pay $4.00/gallon for gas, drive on those skinny city streets, and make my living in their marginal economies, I'd drive a 1.8L manual as well.
4. We don't necessarily need BMWs to be more Americanized (except for that interior storage issue, come on!). That's what Audi is for.
What I don't agree with:
1. In most cases, more horsepower IS better. Just like more wattage in stereo equipment, or having more money. The only relative penalties are in fuel economy (minor in the case of BMWs I6's) and insurance costs. I wager nobody on this Board who has a 325i would refuse a straight up trade for an equally equipped 330i of the same model year. "Ah,...no thank you, I am afraid of that extra power at low RPM..."??? Get outa here!
2. Nissans and other performance oriented Japanese cars make very good use of the extra HP. Especially in RWD models. In Nissans (and I know, I have one) as well as Acuras, Toyotas and Hondas, that power is usually available in low RPM situations (where most Americans drive, most of the time).
3. BMWs are becoming more Americanized, like it or not. Check the differences between the last two generations and the E46, and the demise of the 318i in America. This is a reality. You can sit on the beach and command the tide not to come in, but you're still going to be all wet.
4. I predict (note: "predict", not guarantee) that the next generation (note: not the 2003) 3-series will have a base I6 engine of 200 HP (probably a 2.8L), and the upgrade model will have 250 HP (who know what displacement). It will be slightly larger and heavier, and will have better cup holders (for what they're worth). And BMW will sell even more of them worldwide (which, last time I checked includes America), just like they sell more E46s than the last generation.
Your Z3 is equipped with a Limited Slip Differential due to the fact that the engine (I-6) puts more power than the chassis can cope with. The underpinnings of your Z3 are based on the E30 3 series.
The E46 does not "need" LSD due to the fact that the platform was developed in conjunction with the more powerful I-6 engines in mind.
I hope that helps you out.
Anyway, I see the Z3 as something obviously sporting. Some people do buy Z3s just for daily use, but they as a whole expect more sporting performance than a 3 series and lighting up that inside tire exiting a corner just isn't all that sporting.
And I've driven a 330 with DSC-- the hand of God isn't very subtle with the traction control IMO. I had a lot more fun just switching it off and didn't spin the tires much and NEVER got out of shape.
-Colin
Yes Nissan is making everybody look at HP, at the expense of gas mileage and pollution. "
For what it's worth, the 3.5 liter 260hp V6 G35 gets better EPA fuel economy with a slushbox than the 3.0 liter 215hp I6 IS300 does with either a slushbox or a manual. And the IS300 even weighs less. Displacement and weight are not the end alls when it comes to fuel economy.
Sure the G35 doesn't get the epa mileage of the 3 series, but it's not like it's some 16/20 mpg car with smog coming out of the tail pipe. It's not the scourge of the earth or anything. Yes it could have less hp and better fuel efficiency if tuned right, but that sort of thing isn't going to happen as long as gas is cheap in America and the CAFE standards are low.
Mike
good handling... check.
telepathic steering... roger.
reasonable comfort... got it.
enough power... yep.
light weight... uh-oh, this one appears to be a problem. a 3000lb 330Ci would be nice. "Build it and they will come."
Speed ratings on tires also have a lot to do with the tire's heat dissipation properties. To be able to avoid overheating @ speed is typically a "Sports car" type of requirement, so sidewall stiffness and traction tend to follow from there. You also tend to end up with a compound that's lousy at cold (read: Winter) temperatures.
On HP, I'd have to say "more is better" like Vic Elford would have said about the Porsche 917-30-001 (IIRC, he told the engineers that he wanted enough power to break the wheels loose at 200mph+ on the Mulsanne Straightway. They gave him 1,200HP), but within the real world, its only within the context of equal cost, equal reliability, equal MPG, equal this, equal that, and the one that I'm going to emphasize, namely equal vehicle weight distribution. It doesn't really do you all that much good to add +50HP if it also makes the car nose-heavy and thus, poorer handling and slower through the corners. In any event, its not like most USA drivers have sufficient driving skills to handle the amount of horsepower & performance that even a mere 325i delivers. But we do like to drag race, so we feel we have to have that straight line power.
-hh
I have to say that HP is not everything, but it is something. Additional HP means smoother and more effortless acceleration at any level whether you intend to go 0-60 in 6 seconds or 12. I am in the market for a new BMW, but I am seriously considering waiting another year since the 2003 is virtually unchanged. There is nothing wrong with the current 330, but the car does not exist in a vacuum. The entire market segment has shifted with the '03 model year and BMW cannot ignore this (and I am sure that they have not). Look at what happened to the 318--for those who own one, it may still bring satisfaction, but no owner of an E46 330 would be able to stand that car for more than about 10 minutes.
Does anyone speculate about a mid year change?
Will the 330 ever get a 6speed manual? The G35 raises the bar -- the coupe will have 275HP and a 6 speed.
What will 2004 hold?
Should I wait or should I just pull the trigger and get an '03 330? All opinions welcome.
