But the rest of the car will be a wreck before that. It will need fixing on a regular basis, although that can be done with enough $$$$. At some point youll be spending so much money on repairs and losing the use of the car that it will make more sense to just buy a new one.
My brother in law, who has his own repair business, claims he has never seen a Toyota engine throw a rod as long as the oil was kept in the engine.
Next thing on my list of maintenance will be to replace the water pump, whether it is needed or not.
My questions are:
1) Do I need front end alignment? If so, will it correct the inside wear of front tires?
2) I have heard that there is very little adjustment that can be done on Echo's front end. Will the aftermarket alignment kits available from Tirerack be worthy to solve my alignment problem on my factory tires/rims?
3) When I move the two rear tires to the front, do I need to balance them?
Simon
But YES I would balance those rear tires before you put them on the front!
Please check out the following site for alignment kits:
http://www.tirerack.com/suspension/products/alignKits.jsp
They rebalanced the tire too, so a little bit of vibration that had developed in the steering has been totally smoothed out. :-)
Once the balance weights slipped on one of my tires. It just went round and round the tire. I only noticed the vibe when I went 60 to pass a truck. Usually I go only 45. Took me a week to figure it out but they found it in the shop right away.
I hit a short iron marker thing in the parking lot which has messed up my bumper real bad, there is a big dent on one side.
Does anyone know any place in NJ where I can get this fixed?or some site/shop where I can get a new bumper if need be?
I am a bit sceptical about going to the dealer as it might cost 2 or 3 times more:(
Any suggestions?
rick
rick
rick
But if you are asking if you damaged anything, no, I don't think you did.
What "maintenance" did they do on the transmission?
More and more the mechanics I see are rip off artists. My wife recently took a car to a mechanic to have a single fuel injector changed. The guy said she needed new windshield wipers and charged her $40! I mean WTF he was told to change an injector and he pressures her to get wipers too! PLUS he said the car need new spark plugs (not so they only had like 12k miles on them) and for this he would charge her $70! Those plugs probably cost him like $1 each and take ten minutes to install. If you yourself dont know anything about your car and its requirements you are completely at the mercy of these people. Its not a pretty picture.
Because this is a VERY uncommon system to have on a CAR, I am very suspicious about the ability of even Toyota trained mechanics to PROPERLY adjust (or even check) the ECHOs valves. CHECKING the adjustment is definately within the abilities of the home mechanic. If you can change the brake pads on front wheels of your car I would say you could tackle the checking of the valve clearances.
In my experience the system for adjusting the valve clearances on the ECHO is very stable. It was not unusual for my motorcycles to go over 100,000 miles WITHOUT a valve adjustment. I suspect the same will hold true for the ECHO. BUT every once in a while there IS an adjustment necessary. What you are looking for are tight clearances. That is, the gap between the cam lobe and valve follower is LESS than specified. This can cause the valve to remain slightly open when combustion takes place and result in a burned valve and the engine will need a valve job. If even ONE valve gets burned that will mess up the engine. Now, the other thing that can happen is a clearance that is GREATER than specified. This will result on some valve train noise, but will not harm the engine unless carried to extremes. So if you check your valve clearances, you are looking for clearances LESS than normal. If you find that, then you want to adjust it.
Here is what I recommend. For the vast majority of ECHOs out there, the current adjustment will last the life of the car. Even if the gaps get larger over time and the valves become noisy, that shouldnt be a problem. Its a pretty sound stratagy to leave it alone. BUT there will be a small percentage of ECHOS that get tight valves and need valve jobs. Certainly if you are at all handy, you can CHECK the clearances yourself. If you find a tight valve then you can have Toyota adjust it. (Or sell the car if there are other problems). This might cost like $700! I dont know. There can be a lot of labor involved. And I have a feeling these mechanics dont have a lot of experience doing it because so few ECHOs were sold and almost no other car I know of uses this arrangement.
Personally I myself will be checking my adjustment at 60k miles. At the current rate I am driving my ECHO, that wont happen until the car is like 11 years old! If all is well otherwise with the car at that time, I will check it myself. If it needs an adjustment, I will do that myself also. (although I will need parts from Toyota and who knows if they will have them then!)
In any case if anyone checks the valves I would like to hear about what you find. I can also offer advice on what course of action to take. Good luck!
Apparently, some of the oil passages in those engines were made too small, allowing insufficient oil cooling and causing too much disparity between oil temps higher and lower in the engine.
This sludge thing is very old news at this point, and never affected any of the 1.5s.
I am going to take the first step this week and find out parts and labor costs. If it isn't too much, I may go ahead in the next few months. I also in the future want to get a set of the factory 15" alloys for the new Yaris and stick 'em on there to replace the generic 14" steelies mine has.
TRD also has a clutch pack for this model, to replace the super-light stock clutch. That's a long-term possibility, although I wouldn't do that until the car had at least 100K miles. The rims will probably wait until at least 100K too, so I can use up most of the tires that are on there now.
One step at a time. The only thing that seems urgent for the time being is the suspension.
There are some aftermarket kits (Eibach makes one) but I want to go with TRD for the warranty and because they do the best job of modifying Toyotas, in my experience.
The dealer wants $550 to install it and do the alignment, and if they do it the whole thing will have a 1-year parts and labor warranty.
If she gets back to me tomorrow and says they have it, and it's not just a computer glitch, I think I will go ahead. I am not trying to turn the car into a sportster, but rather just to bring the suspension up from "seriously floppy" to "decent". This car is great in so many other ways, it's a shame Toyota decided to go so lame with the stock suspension.
TRD also used to make a clutch kit for this car, and that is also disappearing because of the discontinuance of the Echo. However, they do have one for the xA, which is virtually identical in terms of powertrain, so I wonder if it would fit.
I wouldn't do anything about the clutch until it failed, which might be (hopefully) a few years out yet (just coming up on 80K miles).
The next thing I want to do is put some of the factory 15" alloys from the Yaris on my car, with some 185 tires, or maybe even 195s. I figure the cost of a set of four rims will run up near $800 or $900, so that's at least a year out (as is the necessity of replacing the tires).
You might want to take into consideration the fact that the car might be nearing the end of its economical service life by the time you do all these mods!
I will do the rims next time it needs tires (or maybe a little before), which will be 100-120K. Again, I am hoping that mileage is NOWHERE NEAR the end of its service life.
As for the clutch, the plain and simple truth is that if it lasts as long as I hope it will, by the time it needs replacement, the TRD clutch kit will no longer be available anyway. If it needed a clutch before 150K, I would probably replace it with OE parts. If I get beyond that mileage and the clutch begins to wear out, knowing me I will probably just sell the car and get something new.
I will probably still go ahead with the larger factory alloys for the Yaris and larger tires next time the tires need replacing. I have to find a way to fill up that cavernous wheel well with more than just tire. :-)
A woman who lives in my complex has an Echo and has Michelin Harmonys on her car - she says she pays attention to such things, and they have been very quiet and have lasted her two years so far. She says she drives a lot. I might go back to Michelins if I buy another set of tires for this car.
I suggest buying tires with an index (UTQG) of at least 500, good for about 60k to 70k miles or more, depending on the type of use.
