Mercedes-Benz E-Class Sedans
98 E320: well assembled, but it did not have the solid bank vault feel I remembered from my last MB ('83 240D) many cars prior. It had more of a Volvo-like solidness and road feel as in my '89 Volvo 740. The new V6 had impressive acceleration and feel. Handling was great at higher speeds but characteristically looser at low speeds, my normal driving. Almost no repairs in 3 years/28k miles--fuel level sender and main seal, both handled quickly. Great resale value.
'01 C320: better low speed handling, good turn-in feel, very tossable compared to my '98 E. Several electronic glitches: keys, both front turn signals. The keys took a week to resolve, with a new module in the dash. (It was a very, very early production model, ordered for me and the first the dealer got in--I expect some glitches as a result, and I'm usually an early buyer of new models.) Build quality was good, felt more solid than the '98 E, but although I am just 6'0" and not overweight, the roominess, particularly what I call "wing room" extending the elbows, was limited. 2 years, 19k miles. Fair resale value because the '03 costs the same as the '01 MSRP.
'03 E320: This is what I was after, I think, after 3 weeks of use. The roominess is there, handling is as good or better than the C at all speeds, build quality is outstanding with no noticed assembly issues, and the door has the old bank vault sound. The power application is less linear than the other 2 cars, but I believe it is because the accelerator has more logic in its software to adapt to driver preferences, and since I'm still in break-in I have been driving conservatively. I expect it will change. The electronic brakes have a few traits but nothing that is intrusive or diminishes confidence in them. Again, conservative driving so far. (At the MB "On Track" day in Richmond, a similar E320 was very responsive so I expect it will adapt.) Every feature the C had seems better executed here, including all the display screen options. The quietness is remarkable. This has Michelin tires, the 2 prior had Goodyears and I would recommend you get the dealer to swap out any Goodyears if they still use them. I have not seen any on the lot on the '03's but both were noisy after 5k miles and gave poor wear.
cargo net. All the attachments are installed in the trunk but NO net.
My dealer war suprised when I called. Apparently the 2002 models
came with the net. I know its not a big deal but when the car comes in at over $ 82000 .00 one would think that Mercedes would not be so cheap
-Jay
I still intend to get the invisible bra. You can see the edge of the clear plastic on the car if you are close up but that's better than chips in the paint. It is also supposed to protect the expensive headlight lens from pretty good size rocks too.
Parktronic $1500
Panoramna Roof $1850
Solar Panel $1120
Multi-Contour L $640
Multi-Contour R $640
Rear Sunshade $720
Bi-Xenon Headlamps $1425
Harman Kardon $1150
Climate Confort F $1780
Freight,PDI $1335
Make sure that everything is pretty warm when you put the material on, it makes for a much more effective and simple installation.
John R.
Did not get one cent off. Since they don`t discount they have a better handle on the Mercedes
"market" They have almost total control over used (Mercedes) car prices, as a result they have the highest"residual" value (62% after 3 years)
M.
Appreciate the comments on the Invisible bra. I have researched it as much as I can. There are two main suppliers Invica-shield and Stongard..both use the 3M material. I suppose the main difference is how the plastic is cut but mostly who actually applies it.
I checked with 3 MBZ dealers, a Lexus dealer and a Volvo dealer. They all said that they highly reccomend it. Only one of these actually installed it. The rest just referred customers to the local supplier. It did not sound like they made anything on the referral. That would make their opinion a little stronger.
If you put it on it can be taken off without damage to the paint. However you would be out the $200 to $600 for the shield.
Both do headlight protection as a stand alone and insurance is available for $15.00 that covers lights if ever damaged by road object. This would seem to be a no brainer even if the paint protection was not done.
Let me know if you have any more or different info.
Ed
BTW, if I can get an invisible bra for my wife it would be a no brainer!
I got confirmation that my car has been "on the water" for about 4 days. Not sure what that translates into for delivery. You will have a much faster water time in Virginia.
West Coast must come thru Panama Canal to LA and then, in my case, by truck to the Seattle area.
Not sure if the port shutdown backlog has any big effect on automobiles. At one time I understood that the big problem was containers and that cars were off loaded differently and in a different place.
My only hold back on the bra is the appearance factor. I have seen it on white and light colors but not a black E series. "They" tell me that the wax build up is more apparent in the light colors and can be easily cleaned. MBZ dealers say they have had little or no complaints with the product.
Hard decision, but I also think I will go with it because as you said I know I will have stone chips in my new metallic black paint if I do not do it. I have had many black cars and all have suffered the stone chip disaster.
I am still getting used to the brakes. I have to "learn" the new way. I've been driving an SUV for past few years, so the performance and power are a welcome delight.
We received a great discount and top dollar for our trade. We have purchased several cars from this dealer, and friends and family have also done so. My husband drove all the way to DC because the Chicago dealers could not come close on price for the E or our trade. Anyone in the market for an MB, I highly recommend EuroMotorCars in DC.
I'm worried about stone chips in the Black paint too. I don't know about the invisible bra though. Any good waxes that I can get for my husband to perform his weekend duties?
Sounds like our cars are much alike.
I ordered E500
Metallic Black/Black, E1,E2, Parktronic, CD, Heated Front Seats,
406 Multicontour Seats, Nav sys and the
promotion ($100) split/fold rear seats.
Hope your new E500 lives up to your expectations. Rayscar and I are waiting to hear that "thunk".
Ed
LClark
BTW...Stongard in Seattle quotes about $529. for the full package installed.
The biggest adjustment for me was getting used to the brakes. Since the system handles brake pressure for you as you slow down, you don't need to lift your foot off the pedal as you stop. Once you get used to it, they system is very nice. I have also had a couple occasions to stand on the brakes, and boy does the car respond.
I really appreciate all the wonderful information you folks post here. If you know of other good boards, please add a post with some links. Also, I am interested in the invisible bra discussion for my black E 320. It seems like a good thing to do but I too am worried about how it looks and what happens to the paint underneath vs. the exposed paint. Any experiences would be appreciated. I plan on keeping this car for a long time, so I want it looking good!
Happy Motoring!
Good link is :
http://forums.mbworld.org/forums/index.php?referrerid=5473
Ed
I love the ineterior and the way it goes (like a bat out of hell!), but what is up with the paint??? We were excited when we picked it up as we were the 1st on the block to have the new "E" so I didn't really notice how bad the paint looks. I've had it detailed twice and finally took it into the dealership complaining that something was wrong. "Orange peal paint is a Mercedes trait" is what they told me! Uncecceptable.
Does anyone else feel this way??? I'm bummed every time I see the car because it doesn't have a beautiful mirror finish like my black Audi did.
Good luck. Hope you otherwise are enjoying this car.
Hopefully, you just got a service advisor who was trying to blow you off. The MBz area rep is the one to talk to.
Any dealers/service techs out there care to respond. We would like to hear if this is something that a dealer would be justified in advising.
Other then that, the car is awesome. Fast, accurate and smooth. I am enjoying it more as time goes on.
I looked at the new E's the other day (Black with Stone leather, a white/stone and a Silver/ash). All of the paint jobs appeared to be perfect to me.
Paladin6, hope they take care of you on this issue.
M.
Oh yeah how 'bout 400-600 miles on one tank of fuel(not gasoline)? Its bullitproof. The SUV's and commercial gasoline and diesel vehicles are the problem children in and for the environment, not the diesel passengers car of today.
Currently Volkswagen is the only manufacturer in the US selling diesel cars.
I wish MB would and could bring the 2003 CLK AMG CDI to the US. Talk about a high performance economical sports car!
These engines are even more efficient than their predecessors, and about 30% - 40% of new vehicles in Europe are diesels.
However, there is another twist: The European emissions standards are geared towards reducing CO2, which is something diesels excel in. In the US, the focus is on reducing smog. And while diesels have made quite some advances, they cannot touch gas engines when it comes to particulate emissions.
In summary, fuel quality and emissions standards make it problematic to sell diesel passenger cars in the US, so many manufacturers just don't bother.
I read several articles confirming that the E270CDI will be making it over here in a few years. The 2.7 five-cylinder is apparently a modified version of an engine that has been in use for a long time, so my guess is that it is easily modifiable to take high-sulfur diesel.
It's about 175hp and gets the car 0-60 in about 9.0 seconds. Sounds slow but in the mid-gears, probably as fast as a E320 or faster. Gas mileage is probably about 35-40mpg.
While it is true particulates are higher, I've stood behind an S-class diesel (latest generation) and couldn't see or smell anything. Same with a Focus diesel I rented while in Europe. So I think that this country needs to give it another chance!
The E300td that I test drove, but didn't buy in 1999 was rated at 8.5 seconds 0-60. Not exactly E55 acceleration, but EXACTLY the same time as my 1984 Toyota Supra 5-speed. Here in the DC area, it is not uncommon to see a used 1998 or 1999 E300 command a higher price than a similar vintage and milage E320 or even E430.
My specific request is for a E350tdi Wagon with 4-matic. I'll dump our SUV in a heartbeat.
Yes, there are plans to bring the E270 CDI to the US. However, DC also stated that there is "no urgency" in the matter.
As the EPA has established a sliding schedule for particle emissions, ending with the minimum value in 2007, the E270 CDI would be able to meet the 2004 guidelines, but not the ones for 2007.
At the same time, the EPA also mandates the availablility of low-sulpur diesels. I'm not sure when MB is going to enter this game and introduce the E270 CDI. I would definitely love to see the return of the MB diesels, I'm just not sure when that will be.
Another neat little tidibit is that the cruise control "Resume" feature can be used after the cruise is shut off.
Class diesels in 18 months.
This is a great forum, similar to this one, with a ton of information from other MB owners. Many people from this board there as well as others.
Worth checking out and signing up.
I originally went there on a referral from rayscar who posts on both boards.
M.
http://www.forbes.com/2002/10/28/cx_mf_1028feat.html
One of the many options was the "Parktronic" parking aid.
It is a real disappointment.You only see the front or back LCD lights and there is no audible
beep until one is 10-12 inches away from whatever you are about to hit.
My niece has a Chrysler van with a similar system.
It is far cheaper and works perfectly well. It beeps the minute you start reversing. The beeps get louder and quicker as one gets close to an obstacle. This is NOT the case with M.B Parktronic.
In fact I bumped into a retaining wall the second day I had the car. By the time I heard the beep the car had hit the wall.
Cowl/vent appears to be only decorative - Upon inspection you will find a drain on the left side.If car is left - in the rain or after washing, water will be retained on the right side. Seems to be a design problem.
