daytime running light module would probably come with instructions on how to connect, if it is from honda. or you can set up a simple relay and voltage reducer system that would turn high beams on at 60% once the engine is running. it would require some wire splicing though.
INKY
also use:
http://robrobinette.com/tire_diameter.htm
Inky - I live in MN, only a few days a year above 90, many below 0. The thin oil may be better suited for me? I didnt find specific reasons why Honda switched. Can you give me a bottom line? Thanks
2001 best in class, offset head-on crash test by IIHS much improved over 2000
http://www.hwysafety.org/vehicle_ratings/ce/html/summary_small.htm
2001 Civic gets better gas mileage than 2000
DX & LX w/4-Cyl. 1.7L Engine & Manual Trans.: City 32; Hwy 39
DX & LX w/4-Cyl. 1.7L Engine & Auto Trans.: City 30; Hwy 38
DX & LX w/4-Cyl. 1.6L Engine & Manual Trans.: City 32; Hwy 37
DX & LX w/4-Cyl. 1.6L Engine & Auto Trans.: City 28; Hwy 35
New Civic puts out more power
2001 CIVIC LX (HP 115; Torque 110) 2000 CIVIC LX (HP 106; Torque 103)
New Civic gains:
185/70-14 tires, 13.2 gallon fuel tank, Cassette on AM/FM,Trunk Entrapment release, Front spoiler, Latching child safety seats anchors, 12.9 cu ft cargo capacity, Silver satin metallic color option
While losing:
185/65-14 tires, 11.9 gallon fuel tank, Front armrest with storage, 11.9 cu ft cargo capacity, Teal Iced Pearl color option
2001 CIVIC LX ES1551PW Sedan 4D (5-Spd.) (w/o Side Air Bags) retail $15010
2000 CIVIC LX EJ657YPBW Sedan 4D (5-Spd.) retail $14930
I'd say that's quite an improvement for only $80 more retail.
If you have a family with a kid or two these upgrades are a blessing:
longer range, quieter and softer ride, safer child seat anchors, kids can get out of locked trunk, go longer between oil change maintenance, and extra cargo space.
I'm just saying all those things along with new sharp design are great improvements for $80.
I'm not talking to 5% who wants to buy the next Honda version of SVO Focus, I'm talking about rest of us who live in the real world... commute 10 miles each way in the gridlock, buy grocery, take the kids to daycare, wanting a safer car with good gas milage - and Honda reliability.
-Trevor
www.HandA-Accessories.com
anyway, i noticed the new trunk release handles on new hondas. how many of you parents have tought your kids how to use them, and have you tried to find it in the darkness of the trunk. from what the handle looked like it would only glow in the dark for couple of minutes. it is not like it is lit up, which is what i would do if i had a kid. get a white or blue LED from radio schack, solder in a resistor and wire it to the battery. that way the handle is always lit. the only reason honda and other car manufacturers are putting these things in their cars is because some idiot half baked parent didn`t lock their saturn`s trunk when went home. and when the kids were playing hide and go seek, some kid decided, "what a good place to hide, no one will find me here." well, no one did until next morning. then the parents sued GM, even though i don`t think it was gm`s fault, gm settled out of court. honda is just covering its back. how many 5 year olds would know to push,pull or turn that handle when they are scared and panicked in the dark?
Kyle
The back lights are too small or something like that....
Kyle
Also for scooter62, I just received a case of AMSOIL 5W20. Will use Honda filters and do my own change every 5K at least while it's under warranty. Since Honda says 5W20, I'll follow their lead, but I definitely want a synthetic in there. I have a 1990 Probe that still runs, but got cam damage from being started and driven after being parked outside in 26 below weather overnight with regular oil (Castrol GTX) in it. It rattles when cold, has some hesitation, but I got 183,000 out of it with no major problems.
There is a problem thought, very time I go over a bump or dip, a creaking sound will occur from the front driver's side suspension. Just had it checked by a Honda Dealer and they told me Honda HQ got lots of complain for the same problem and is looking for a possible recall to fix it.
I searched the Web but I couldn't found any information about this problem. Anyone else had similar problem??
What should I do now?? Wait for the recall or ask my Dealer give me a new one (most likely they wouldn't)??
In the meantime, try this [worked temporarily on various Toyotas that have had this problem in the past]:
Get a can of spray silicon lubricant, and give all of the accessible suspension bushings a shot of it. The prime suspect in the Toyotas was the bushings for the front anti-sway bar, but anyplace where the suspension moves against rubber or plastic connections is suspect. This may or may not temporarily solve your problem, but it is worth a try.
In checking the TSBs for the '01 Civic, I do note both the TCM problem, as well as the well-known problem of radios going to "code", and the oft-noted difficulties with fuel gauges and sending units. All of these are clearly known to the factory, and thus known to any dealer. You may have to push them sometimes in the direction of an existing TSB...they can be accessed at the NHTSA website.
The sales people I've talked to have told me about some new shift logic in the trans that stops the gear hunting, but I'm not sure whether or not that's just sales speak.
Anybody have a clue?
Jim
Thanx
Chad
i am new on this board and want some help from members like how to get a good deal from dealers, actually i have done some home work about civics and other sedans and finally settled down for 2001 civic lx auto with dual side air bags, as i am thinking of not spending more than $15000 ok some help needed.
good luck
Tip 1:Get your financing in order from your bank or other places. The dealer will try to beat it and you could possibly get a better APR.
Tip 2: Try to get a quote from the dealership online or over phone. When you visit the dealership the dealer will start at the MSRP. You can at least show him the quote to lower his starting point.
Tip 3: Go to carsdirect.com and see for what price you can get the car. If they want your business, they will have to beat carsdirect.com price. They did in my case.
Tip 4: Be wary of options. They tried to sell me floor mats and mud guards at $189.00 each. I said no thanks. I could get them online for around $70 each.
Tip 5: Research any options you want before you go to the dealership. You can buy many options after market at a much cheaper price. For example:
I just had my car alarm \w keyless entry installed from Best Buy (free installation).
Tip 6: If you are uneasy about anything during the process or feel pressured (I felt extremely pressured) tell them you want to think it over because you do not make decisions in this condition. (That's what I said)
Tip 7: DO NOT SIGN ANYTHING unless you are ready to make the deal. Nor leave a deposit.
I am also from NJ. Good Luck!! I love my Honda Civic unfortunately so does everyone else. They are all over the place.
You can order accesories from hparts.com
Also, how does the Honda CD player, the one which fits under the stock radio, sound?? Does it produce enough bass, treble, good sound?? It costs about $250 from HandAaccessories.com, but I would rather spend $200 at Circuit City and possibly get a more powerful unit.
Who's the expert on this topic.... I want to hear from you !
NewCiv
i just bought 2001 civic lx sedan with side air bags for $14,700.00 +taxes+document fees($300.00)=$15,890(they gave company mats free) at planet honda.they said they will give me security alarm and keyless for $300.00, i said i will call them if i need.can u give somebody like is that deal is ok,and how much
keyless& alaram costs outside.thanks all you for your support.
venubabu2
That includes keyless entry,passive alarm,flashing lights,illuminated entry and back up battery plus installation. It is a Black Widow alarm and best buy guarantees it for the life of the car. Also it chirps as oppose to the horn sound. I believe (but I could be wrong) the honda alarm sounds the horn.
That sounds like an excellent deal providing the car is automatic. Congratulations!!!
Do I need to apply the hand break after parking every time?
Usually I don't have such habits to apply the hand
break for the car with auto-transmission. I only
left the transmission at "P".
But somebody told me that it may damage the transmission. Is it true?
Thank you for advice.
