Failure points:
Minor: rear cupholder (about useless anyway...); both front access 'flip panels' for VW jack (replaceable if one wished to do so).
Moderate / Expected "Wear items": brakes & rotors (did these at home); new battery; couple of bulbs; rubberized coating on driver's door handle. (And, of course, tires, wipers, filters..... )
Major: Water pump - replaced along with a multitude of items as part of "100k" service (which was done around 80K due to water pump failure).
Radiator: sprung a small leak earlier this year along seam between metal fins & plastic side panels. Replaced with new aftermarket unit.
Suspension: Creaked & Groaned for a couple of years, which is pretty common. Replaced F&R shocks & springs - along with nearly all of the front components as part of an aftermarket kit - when tie rod ends went bad.
Also, car has always used some oil, requiring an additional 1/2 qt between changes. But over past couple of years it has developed a small oil leak - apparently around right side valve gasket (as facing engine compartment) - which has upped oil consumption to a good quart between changes.
Mechanics advice is that this is minor & to simply keep eye on oil level until the NEXT major engine service - presumably around the 150 - 160k mark. Just might still own the car at that point, as it remains a joy to drive...
Good luck in your search / purchase!
I'm trying to find all of the gaskets and crush washers and o-rings, all of these little parts that I'll need, when I replace the turbo charger on my 2001 1.8T Passat. (Engine code is AUG).
It's a fairly new rebuilt longblock engine, and when installed it was with a cheapo turbo which has blown its bearing. So I purchased a new KKK (really Borg-Warner now) turbocharger. The B-W (B-W part is 5303 988 0029, which correlates to VW part number 058 145 703J). I've got the exhaust gasket and the intake gasket, but it looks like there are various crush washers and seals needed (e.g. for the oil send and return lines). Can anyone out there point me to a blow-up diagram, or even just a recommended parts list, for all of these little goodies that I'll need?
Mike
I can buy a 2003 glx 6 cyl sedan with 57k for 9000.00 or
a 2005 gls 4 motion 4 cyl. sedan with 39k for 12500.00. it
is for my kids and one might go to school in new hampshire.
IS it worth the extra 3500 for 4 motion, 2 years newer and
20k less in miles.??..both have leather, roofs, cd's only diff
is electric seats in 2003. please help dealer said he would
wait til tommorow...thank you!
V6 is not as picky with oil as I4 but must use the same oils.
Krzys
Any advice would be appreciated
Also have heard they need a timing belt around this mileage is there anyway to tell if this has been done and how much would it cost is it a do it yourself replacement or does it need to be done at a dealer
Mark
Second: there is coolant leakage around the hoses that surround my oil filter and over time it crusts around the hoses and around my filter, its not alot but should i look at it seriously and what is causing it?
thanks to anyone in advance,
aa
The 4-motion really does not make a big difference compared to FWD and in the Passat, it prevents you from having fold down rear seats.
Also, how will passat take care of engine sluge issue if I bought a second hand passat from dealership and could not approve all oil change?
What about air filter?
Tire pressure?
Wheel bearings?
Stuck caliper?
Stuck hand brake?
I think I run out of ideas.
Krzys
PS One more: different oil?
Thermostat not fully closing?
Vacuum leak somewhere?
At some point, all these can occur and not show up on the OBD2.
BTW, the web is full of stories where one would have hoped that "VW would have picked them up. Personally, I think they rely too heavily on the "there's MIL, so all must be perfect" approach to troubleshooting.
So, i'm no mechanic, and it seems it's hard to find info online (vehicle manuals/diagrams) that would help me become one.
First:
Does anyone out there know where i could get a bootleg FREE copy of the 1999 Volkswagen Passat 1.8 turbo REPAIR MANUAL?
Second:
While i was driving my Passat there was a blow-out of my exahust intake manifold (where the exhaust attaches to the engine). So, naturally, of course my car sounds very loud because of the disconnection. Does anyone know what the exhaust (the part under the hood, near the engine - not under the car near the Cat) is made out of - cast iron ??
I have thought of welding it back, but am leaning towards a replacement of the part.
Any feedback/knowledge sharing is appreciated!! Thanks for your time!
If you were to google "Passat Etka" you might find something that woudl help you.
There isn't any handy dandy one page chart available. I must have spent two hours w. the manual and on-line also. I called the VW dept. that's responsible for manuals, and they don't have any such thing.
Two Questions:
1. Has anyone compiled a chart?
2. Has anyone found maintenance info on severe conditions?
Exasperated and stuck w. my Passat.
Start here:
http://www.vw.com/myvw/yourcar/maintenance/findschedules/en/us/index.html
Can't thank you enough! Gotta save this site... http://www.vw.com/myvw/yourcar/maintenance/findschedules/en/us/index.html
P.
Remove the cover at the top/front of the engine and check the sides of the belt for cracks. ( My cover has a water hose clipped to it. ) I replaced my belt at 105,000mi. It was quite an ordeal and I do not recommend anyone w/o "heavy line" experience even attempting to do it. The valve timing must be right, and the cam belt must not be too tight, or too loose. The whole front of the car must be removed. ( Bumper, headlights, AC condensor and radiator. ) The AC system must be drained of refrigerant and later refilled. I replaced the camshaft belt tensioner, the water pump, and thermostat during the cam belt replacement. The repair manual cost of $100. NOT for an amateur.
Anyone else have this issue?
Advice and approach?
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Has anyone had this problem...And is there any advice on how to resolve this? I'd appreciate any help.
My VW Passat 2000 engine is leaking again after spending close to 1 month at the VW santa monica dealership, they said that they changed 2 times the valve cover gaskets, the camshaft adjusters seals and some other seals and it worked for 3 months, just enough to clear the 10 years power train warranty and then it started leaking again . The 2 valve cover gaskets for instance have been changed no less than 4 times in less than 80,000 miles. I sent an email to VW America but didn't even get an answer. And they want to sell 800,000 cars a year in america?
Conversely, you might want to consider this: I saw a newly released oil cap on ECStuning.com 's website for the v6, specifically designed to relief pressure from the v6 engine.
Now why doesn't the Santa Monica VW dealership technicians don't know this?
They supposedly changed all the seals and gaskets and warranty, kept the car for a month and now all this work needs to be redone. What a waste.
I tried to follow the link you metnionned at ECS, went to vw, passat, b5, v6, fwd all the way to engine couldn't find the part mentionned.
