Mercedes-Benz C-Class Sedans
Took a bad stone chip on front windshield (low on passenger side). Had www.novusautoglassinc.webatonce.com come to my office on Friday at noon and he did an excellent repair in 45 mins. Cost $60.
Drilled a very shallow small pilot hole in the marble/star crack chipped glass, filled it with urethane, then used a tool to spread the urethane into the star cracks, and another fancy tripod with a threaded plunger to apply pressure to the urethane to fill the hole and cracks, then applied a hardener resin, used a UV light to cure with cellophane covering the mark. Peeled away the cellophane and used a razor blade to scrape away the excess. Final mark is a touch bigger than the head of a pin. (BTW he just replaced an ML front windshield at $900.)
I highly recommend "Alex" from Novus for anyone in Jersey that may need autoglass / stone chip repair. My MB dealer referred him to me.
Leather seats - 1400
auto - 1300
The car will need tires in few thousand miles. Any suggestions on makers, ratings, sizes?
Quote for C240: "CFC-free automatic climate control with dual temperature controls. Electrostatic dust filter. Humidity sensor."
Quote for C320: "CFC-free automatic climate control with digital dual temperature and airflow controls, plus illuminated vent adjusters. Electrostatic dust filter. Activated charcoal filter with smog sensor. 4-Way sun sensor."
Dat
Since I am using only one key, it is not necessary for me to have the "Key Dependent" setting on, because the 320 has its own capability to keep three seat memory and temperature settings without key dependency. However, if there are two keys being used, although the settings on the second key are saved in memory, they will not always be with the correct memory number. This means, of course, you were correct having "Key Dependent" enabled, but in my situation either would work.
Miki
Miki
I had to speak to the service foreman at the dealer today on another subject, and he installed the knob without charge.
It looks wonderful and feels wonderful and I love it! If you remember, I was going to exchange knobs from a former 320, but decided against it.
Miki
1. prices
2. delivery schedule
thanking you in advance
Costco Wholesale stores are offering a $50 dollars off for Michelin Tires. The sale is on from June 18 through July 1st only. Besides, a coupon is needed and you could ask for it at customer services before making the transaction.
I received this info in the mail and I thought of sharing it with you..
Cheers
http://www.michelin-us.com/us/eng/tire/promo/index.html#
Well, someone had posted scanned copies of the option sheets for the 2002 C320 and C1 was not standard. Maybe MB changed their mind. What base price did you pay for that 2002 C320? Also, why won't it be delivered until October, if deliveries start in July, do they have orders backed up that far already?
NICE order! (I live in Nassau County, NY).
Am "just about" to order a 2002 C-240 (C3/C6)
and am in two minds about either Helms or
Westbury. Any positive/negative vibes about
the 'Queens' dealer you worked with?
Gerry
(murray@acm.org)
Sorry to hear about your accident. That's always been a problem w/ new cars. Same thing happened to the MDX, ML, and X5. Parts were all used for production.
Let us know how it goes.
Helms is a nice dealer too but I've never done business with them so I can't comment. As far as Ralleye Mercedes in Roslyn is concerned... NAH. A bunch of snobs and they look at the C class as a POOR MAN's CAR. I may be exaggerating but just visit this dealership and you'll know exactly what I mean.
Dat.
Regards - Sandy
Dat -- Good luck with your new car. If you have the C1 package, your exit feature should work. Be sure to check out if you have it enabled by using the multifunction steering wheel button per your manual.
Miki
Drew
michhalla - I did set it to steering/seat setting and it does work (opens up), but then it would not set it back to my seating position. I should play with some more though.
Dat.
does anybody heard something different or do they have any idea about 2002 pricing ?
thanks in advance
Drew,
I always have to buy two of everything.
Miki
So far, that car amazed me of how much gagets it has through out the car. I am glad to have the Nav. It eliminates having to have maps in the side compartments. It is very accurate! The car is quiet and respond quite well. Also, I did get the full extended warranty for four extra years for a discount! Overall, I am very happy with the car.
I was very concern about some of the post I've read earlier about some of the problems. But, so far, I am knocking on wood. Everything is perfect.
The key remembers the last setting it used. If no one changed the settings, then just pushing the little button below the 1-2-3 button should bring you back to the proper seating position. Do this after you have turned the ignition key to the right or started the car. Also remember that if you make any adjustments while driving to the seat, side mirrors, headrest, be sure to press both memory buttons on the door. First the top one and then immediately thereafter the bottom one.
That said, it does not always work perfectly
Miki
I've been reading "Part 6" since March and have finally caught up to the end, just in time to pick up our new C this Saturday! It's a 2001 desert silver/charcoal leather C240 auto, C1, C2, C4, C6 Sport, CD changer. Ordered 3/30, built last decade May, arrived Baltimore 6/6, arrived Lancaster, PA Wednesday! Paid MSRP -- well maybe $100 off the changer! -- hadn't read enough of this forum yet to try to leverage it in for free! Dealer is Lancaster County Motors in Lancaster, PA.
We also have a '97 Explorer, and are replacing my '95 Eagle Talon ESi. We are super-excited about owning this super-safe, super-advanced, little sports sedan. My two small daughters and my back are looking forward to having four doors. and my non-stick-driving wife is looking forward to another car she can finally drive! My first new car was a '89 VW GTI 16V, and I've been waiting impatiently to drive another German-engineered vehicle.
We shopped (and eliminated in this order) the VW Passat, Audi A4 2.8 quattro, BMW 323(x)i, and the C240. (We toyed with the Lincoln LS, but never followed-up seriously.) The combination of safety equipment, cool features, luxurious appointments, and drive was unbeatable, IMO, in the category, and with the Sport package I think my driving urges will be well met. My radical performance driving days are past (until my sportster!), but I don't expect our new C to disappoint.
Well, I'm eager to join the discussions here -- after reading all these messages I feel like I know you all: Drew's accurate answers, Michala's Tale of Two C's, Dennett's (wife's) magma red, zmeenow's enthusiasm for his early model, kmurphy's frustration and disappointment with his problem car, the mysterious appearance of the flags (to me, they were there all along!), and jrct9454's excellent experience with flat-spotting and precision alignment -- just to list a few. And no slight intended to all the rest of the posters here to what has been, when read end-to-end, an awesome resource for new and prospective MB and C-Class owners!
Hope to continue here for quite some time!
Tim
P.S. Pardon me for the lengthy post -- I've been saving up since March!
They still occur between 30-40mph, however after 20 minutes of driving they subside.
I'm sure the vibrations are still caused by the tires, because it's a different type of vibration. I'm the lucky one...I have the only C with an extremely sensitive suspension.
I give my dealership credit, they're willing to keep trying until it's fixed.
Other than the tire issue, the car has been flawless. I love my C!
Once I get to the highway all is well and then no more vibrations until the next morning. It does not seem to be any worse (or better) even after a few days of the car sitting. There must be some magic number of hours that cause the flat spots to occur. It would seem more than 10 hours based on what I have seen.
I also got mild occurences of the same thing on my 2000 E320 (that has Michelins). My C has Pirelli's. Both cars with 16" wheels.
JR
then you have the c320 which is essentially the same car. mercedes is just as silly as bmw charging a million more for 47 more horses. the 325i is 5 grand less than the 330i but they are the same cars and now we have the c240 and the 320. i call it marketing genius. i am not saying these are lousy cars but the pricing approach is absurd.
vtech
- Learn to ignore it. As you have noted, once the tires get sufficiently warm, they get round again. With the carcass construction of most Michelin touring tires, this process doesn't take long, as long as you haven't gone 4 days or more without moving. My general rule of thumb is 8-10 miles at freeway speeds in mild ambient temps.
OR
-If the car is garaged [secure overnight, in other words], then adapt the JMR patented solution: buy two [I actually use all four, but the front tires are the key] cheap floor jacks from a discount store. Attach some cheap toweling or shop rags to the saddles [rubber bands work fine; this helps keep wear down on the car's jacking points]. As soon as the car is done for the day, jack up the car just far enough to get the tires clear of the floor. Make sure you hit the jacking points under the car that are used by the techs at the dealership to put it on the rack - if in doubt, ask [don't want to punch a hole in the floorpan]. This process for all four wheels takes about 2 minutes at the end of the day, and another 2 minutes before the car is ready to go. For me, this has become as essential as checking the oil...we are retired, and have most life essentials [bank, grocery, drugstore, coffee, video, pizza, etc] within walking distance, so the car sometimes doesn't move for up to 7 days, or occasionally even more. I can tell you this works...but only if the tires in question were actually round and straight to begin with, which is one reason I favor Michelin so much.
JMR
C240, Brilliant Silver/Charcoal, 6-speed manual, C1-4, Bose, Xenon, CD-changer.
Paid MSRP, free was the all season floor mats and an extra CD cartridge.
michhala - #3432 - Yes, the exit feature works now, but I don't think the seat moves forward enough to be back to my setting.
Dat.
So glad you did not "de-lurk" and plan to continue with the forum. Lots of nice people here as you already know.
Miki
Dat -- Even when you hold down the lower memory button? Are there two key users? If so, are you set for "Key Dependent"?
You can also disable the "Exit" mode and use the door control to move the seat back and forth as you need. I chose to stay with the "Exit" mode enabled and tough it out and get aggravated and have something to complain about. It's not easy being me
I still find my two-week-old Obsidian 320 finicky as far as the memory function, but not as much as my Black purchased in Dec. I also found that my Black's memory behavior improved as it aged
Miki
Has anyone heard/found a bra for the 01 c classes?
However, I discovered that it only happen when I press my left foot on the brake while using my right foot to accelerate. I believe now that this might be a feature rather than a problem. There might be a sensor on the foot brake which will not accelerate the car as long as the foot is held on the brake even slightly.
When I release the brake, the car acted normal.
Like to here from others with the same issue.
Exit feature - When I shut off the car the wheel/seat opens just fine. When I start the car, steering wheel and seat move back, but the seat does NOT move far enough to my setting. So I just push and hold down the seat memory recall button until it stops, then it's to my seating position.
Extended warranty - I did buy the one year/100,000 miles extended warranty. Since I drive a lot, I needed the mileage more so than the extra year, so I double the mileage warranty for very little money.
Dat.
rag
Tell your salesmen it's too much. Tell him also if he doesn't reduce it you will publish his name in this forum and what he is charging.
My suggestion is, you call the factory dealership in Manhattan or MBCC directly and ask what the present bank fee is. An inflated bank fee is just another way for the dealer to make more profit at your expense.
I just took delivery and have two questions:
I have always changed the oil on new car at 1,000 miles, but the dealer insists that until the oil change light comes on (8,000 miles +), I don't need to change it. Has anyone done any research into this?
Also, are there any wax/polishes that are especially formulated for black paint?
