Mercedes-Benz C-Class Sedans
Drew: F1 [and most similar sequential shift auto transmissions, which are showing up everywhere - Ferrari uses them in production cars, and one is available for the new C-Class coupe, though not for North America] cars use a regular clutch and gearbox combination, with the clutch electronically actuated. Pressurized fluids are involved in some applications, while others are purely electronic [depends on how you want to engage and disengage the clutch - different preferences and philosophies at work]. And there is often NOT a clutch pedal, per se; instead, they will use a hand clutch on the steering wheel so each foot has only one pedal to work with at all times [which can be necessary when you are starting to spin and need to keep it cooking, but need also to briefly go to neutral, AND need to brake, all at the same time...this is why these guys earn the big bucks].
Eventually [20 years hence?], I think there will be but two transmission choices everywhere: CVT, and electronic sequential auto-manuals. Once the 42 volt electrical systems come online in the next decade, this trend could accelerate.
I read the owners manual several times and still can NOT get the flip down button of the head rest to work. I have tried it with the head rest in the up and down positions, nether one works. What am I missing or doing wrong? Yes, the key is in position 1 or 2.
One interesting thing. The car is running and the radio is on. Turn off the car, key position 0, radio is still ON. Take out key, radio is OFF. Push power button on radio, radio is ON. Get out of car, close door, lock/secure car, radio is still ON!
Neat feature, but can drain the battery!
Dat.
I read somewhere in the owner's manual that interior lights, and I believe other electrical functions, will turn themselves off after 20 minutes. If this feature works as designed, our batteries should be protected. Keep us posted on what the problem turns out to be.
Check the URL below and see who makes what for the C-class. Alot of companies involved!
http://www.autonewseurope.com/cutaways/mercedesc-class.htm
On the rear headrest question - I only used the feature rarely on our W202 C, and now that I think about it, only when the car was on the road. Never had the occasion to try it on our W210 E...does sound as if the owner's manual deceives, which would hardly be the first time, incidentally. My '94 C's book had a couple of real whoppers included at no charge; fortunately, the one about correct wheel torque was so far off that you knew it had to be wrong...
As an owner of a 1999 C230 K Sport, I have witnessed the sudden jump in acceleration from 1st to 2nd gear and I have always thought of it to be normal due to the engine cold temperature. But again I also experience the same slugginesh at various speeds and when the car is warmer.
I took notes from your posts and contacted my service manager who scheduled me for service next monday. He stated that he is familiar with the problem and that they needed to retool the transmission "clutches and fluid sensors". He added that the work should take at least two business days and it is under warranty. A loaner car has been reserved for me too.
If anyone is interested in getting a copy of my letter to the service manager that I have sent just email me. I admit I have literally paraphrased and even rewrote your technical comments to make my case as my car is still under warranty for another 20 thousand miles.
Cheers to all
Johnny
As for the radio, nanky is almost right again. The radio will turn off, but only after 30 minutes. The manual does say this on page 171.
Thanks for the help.
Dat.
I could have Bought Mobil 1 10-30W from Pric Club much cheaper but it is not consistent from the dealer. I want to use the same oil.
http://www.imagestation.com/album/index.html?id=4292518339
Oil Change: hoppyeng, great pics, but you are really going to way too much trouble. The factory suggests that the engine oil be removed by vacuum through the dipstick tube. It works great, no getting under the car, no R&R panels and you actually get more oil out! I used a 'Topsider' on my C240. This device was purchased for about $40 at the local guy store. Yes, these W203's do have dipstick tubes, just no dipstick. It is near the firewall just right of the center of the car.
Gary
The car I couldn't drive but that visually impressed me the most was the C320 Estate Wagon. Now there is transportation that has it all, roomy inside, compact outside, excellent performance (based on the sedan), and a visual delight. All curves, no boxy shape for this one.
I hope this helps, if you have any other questions please ask.
Bubba
"... my friends all drive Porches, I must make AMENDS..." J. Joplin
I find the 3-series' brakes a bit touchy compared to the C-class. Perhaps it's because I'm used to the longer travel pedals of MBzs. I know that some BMW owners that I know feel the exact opposite way, saying that the MBzs that they test drove (the SL500 in particular) felt slow...of course it's not slow if you actually measure the 0-60 times.
The C320 wagon is definitely stunning and I really look forward to being able to test drive one when it arrives very soon. What interests me is the C320 4-matic wagon in particular. Interestingly, my salesguy told me that in their recent product training sessions, they were all told that there is a good chance (for Canada at least) that the 4-matic system may be introduced as a late availability option for the 2002 model year, specificially around Spring of 2002. This would be similar to what happened to the E320 4-matic when it was first introduced for the 1998 model year, and it would also be in tune with launch date of the C and S-class 4-matics in Europe.
Drew
do you ppl in the age group of 22 to 30 purchase this car or they choose the BMW 3-series over it? my buddy told me that the C-class is for middle age ppl
hm...i am perplex
http://www.mercedesshop.com/diy_oil_change2.htm
hey the average age group buys the car THEY enjoy driving ... no matter what the age!
IMHO
Well...Mercedes has the "smart key", but I bet that is not the answer
smart key!! mensa!!! gremlins!!i loove it!
Regarding the brake test; the portion of the course for the brake test was to accelerate to about 45 mph and hit the brakes, panic stop, set off the anti-locks, smoke the tires type of stop. The Cs all seemed to stop in a shorter distance than the BMW, there was no measure of the stopping distance, just a seat of your pants kind of thing, but I came away with more confidence in the M-B.
Hey guys, I'm an old codger, 66 - retired four years ago, but I just don't like a Buick ... Can I get a special dispensation or something so I can continue driving my new toy ... Please???
Bubba
Regarding the braking, perhaps it has to do with Mercedes' Brake Assist. A while back Motor Trend TV (I think) reported that the E55 outbraked the M5 by a notable amount in the 70-0mph test because of Brake Assist being able to apply full brake boost quicker and more consistently than a normal driver. This may be why you felt that you had more confidence + the entirely possible shorter stopping distances than the other cars.
From my experiences in repeat braking maneuvers, I can say that it really does work very well in panic stops. I was stopping my M-class SUV in a shorter distance than many of the BMW cars in the class. I was actually quite amazed by this! The instructor had never heard of Brake Assist and was impressed with the capabilities of the brakes as well. I have no doubt that the C-class would perform extremely well in this same maneuver.
If you're interested in what I'm talking about above, you can see a video clip by clicking here.
Enjoy the drive,
Drew
This does not make me "crazy" and is not distracting. I will mention it to service at a future date, but I am not in a hurry to have a windshield replaced. I would be interested to learn if this is normal or to be expected.
Miki
Gary -- You made the right decision to not tell your friend
Miki
I read today in CAR where MB is experiencing MAJOR quality problems. Having had two VOLVOs both with MAJOR QUALITY issues which drove(pardon the pun) me to M-B, I was hoping for something more.
Don't get me wrong, great riding and driving car, but these issues are causing concern. Anyone else experiencing these types of problems?
I see a lot of patience and forbearance among this group, but then I am also seeing a lot of first-time owners, who may not have the same expectations of the marque as do folk like me. It is no secret in Europe that MB has the enthusiast publications nipping at their heels over this issue. They simply have to get a better handle on the performance of their subcontractors, especially the electronic suppliers. It's also obvious that they are not doing the extensive preproduction testing that used to be taken for granted, in the name of being competitive and getting products to market sooner.
None of this is to say that the world has come to an end - these are still very desirable cars with a heritage that no one else can touch. But at the end of the day, the new products have to uphold the traditions of the heritage, or it ultimately is valueless. I think current management has a lot of work to do - too much distraction from Chrysler and Mitsu and trying to be a global heavyweight and too little sticking to the knitting.
all in al, the car has met.. and in more cases exceeded my expectations.im also aware that others have had,at the very least annoying problems... occasionally more... i hope everyone gets them selved.. and can enjoy their cars!
miki... i do have compassion!!
>miki... I do have compassion!!
Gary -- Indeed you do You exercised amazing self-control by not telling your fanatic friend that his BMW windshield had distortion. 'Twas very admirable.
Miki
My two help aids:
1. When looking at the car, I avoid looking at the chips, and concentrate on enjoying the total shiny and beautiful appearance of the total car (this is the hard part).
2. I will call the dealer-recommended mobile paint company that comes to the house to fix the chips (this is the easy part). Since the cost is the same for all chips, methinks I will wait for more to appear -- and they will, just as sure as the sun rises and shines. I also think the dealer will do it for me at this point, too.
Miki
Miki, my condolences...as you know the first chip or ding is the toughest, but at least you're taking it in stride! ;-) I haven't had a single chip on my M-class' hood, knock on wood, thanks partly to the hood deflector. However, I've had two pin-sized ones on the front bumper.
Drew
I am happy for your good luck and lack of chips (knock on wood), but I don't know about hood deflectors. Are they just for the M-class?
Miki
Now for some good news, I am getting 26.4 MPG on the average!!!!
Indeed, am waiting patiently for my 4th return to the garage to have the transmission fixed so I can exercise my rights under California's lemon law and have them purchase my car back from me.
You're not alone my friend. The C320 is a piece of junk; although let's keep that to ourselves because we wouldn't this kind of talk to reduce the resale value of our paperweights (something which I'm sure is on your mind as much as mine).
I am interested in the C-320, however, i hear it has some bugs to be work out...so maybe the next year model will be a bit cleaner?
Miki
Dallas, Texas
You may want to consider the invisible bra for your C. While it won't prevent all chips and it won't deflect small pieces of debris like a hood deflector can (by changing the air flow slightly), it could help. The cost may be worth the peace of mind to you. I think the most important thing is to find someone who has experience, and hence can do a good job applying the material. Probably shops that deal with expensive cars will be preferable.
Xpel offers a few different ones with varying areas of coverage for your car (Avantgarde = Sport pkg, BTW). They also offer relatively inexpensive headlamp protection film kits as well. A good idea, especially if your car has the expensive HID Xenon headlamps:
http://www.xpel.com/paint/product.asp?make=Mercedes&image1.x=8&image1.y=12
You can also find the nearest installation centre here:
http://www.xpel.com/forms/installform.html
I hope this helps!
Drew
My advice to you is to look seriously at the 330xi (yes, the body styling is dated, but BMWs are generally well made cars) or wait for the 2002.
If you still like the C320 so much, I have one to sell you, it only has 4,000 miles on it.
Bubba
