Mercedes-Benz C-Class Sedans
1113114116118119140
  • hudson232hudson232 Member Posts: 5
    I am hoping that one of you folks has an answer to a problem that is driving me crazy. On my 2000 MB 230K (4 dr sport), which I leased new, every time I start the car up, especially in the morning, I am smelling a distict anti freeze odor (chemical smell) out of the front dash vent. On humid days, all of the windows fog up the minute I turn on the air/heat. If I'm driving, I am temorarily without a clear sight of the road. I brought it to the dealer, who said the air con drain hole was clogged, and that they fixed it. Unfortunately, the problem was not solved. I am considering buying out the lease ($18k) at the end of the term, but still not sure. Can anyone give me some insight? You guys saved me big time on the dash rattling (sun visors) and the fuel warning light (faulty switch) back in 2000. Pls help me again. Tks, John
  • jrct9454jrct9454 Member Posts: 2,363
    ...sounds like the heater box itself has a small leak. This would explain all of the symptoms you describe. Unfortunately, I don't know how to prove it to a dealer, or what you can do to convince them to look, or what testing they would do to verify, but your description is word for word what we experienced on our "Beater" early '80s Ford that was a third car for a number of years. The local Chevron station mechanic [!!!!] made the diagnosis and the fix. And I'll bet he still doesn't charge $90 an hour...
    I think this means that the heater box [which contains the circulating cooling fluid, which is after all the heating medium] is leaking just enough engine coolant into the air system to give you both the smells and the unwanted extra moisture. It's probably a very small seepage, or you'd see other symptoms [like coolant loss and such]. See if you can get a dealer to give it a check.
  • 404c404c Member Posts: 146
    You have a pinhole in your heater core, most likely, as jrct9454 says.
    Tell the dealer to do a pressure test on the cooling system. They should pump it up to maybe 30 psi and then leave the car for a while if the pressure does not begin to drop immediately. The test equipment is like a high-quality bicycle pump that has a pressure gauge attached to it. It attaches to the radiator cap. All decent garages have one (if yours doesn't, they are idiots, go somewhere else). There should be ZERO pressure drop over that time. If there is some, that proves that a leak exists.
    Then the question is: where is the pressure drop occuring, but your sense of smell tells the dealer what to change. Plus maybe the interior will smell of coolant by then. So, because the car's under warranty, they should put a new heater core in, no questions asked at that point.
    If you were out of the warranty period, I'd be tempted to try a Rube Goldberg solution before busting my a** changing a heater core (they're usually awful). The Rube solution calls for you to get a rad sealant such as the General Motors brown tablets, grind 'em into a fine powder and put it in the radiator. It just may work. I cured a moderately leaky radiator gasket on my 180,000 mile 1989 Peugeot that way - the alternative was a new rad or an expensive rad tank seal change, on a car that's worth $14.99 or thereabouts. This solution has held for 2 years and 40,000 miles.
    You should sort this problem out before the car is out of warranty though. If you were to pay an M-B dealer to do it you'd be into the big bills. And as I wrote earlier, if you did it yourself you'd use all of your blue vocabulary up, and then some, changing the little swine.
    Good luck,
    Mike T.
    2002 M-B C 230 K
    1966 Peugeot 404 Coupé Injection
    1989 Peugeot 405
  • paul_ppaul_p Member Posts: 271
    I had the same type of issue years ago on a 1970 Mercury Montego MX Brougham. The heater core split causing an awful fogging and smell in the car. After replacing the heater core (not too bad to replace as there was no A/C in the car) all was fine.
    Mike I believe your approach with the sealant may work, but I would be worried about plugging up something else that was designed to stay open. No problem on a '73 Chevy as I've done in the past, but as an owner of a 2000 C230 Sport myself, I'd be hesitant to try that approach on a newer car. I agree that is a good last-ditch effort alternative.
    My advice, bring it to the dealer and have them do their job - testing the cooling system and subsequently replacing all defective parts. They should do this without question if you bought the car in the US and have not yet reached the 50,000 mile warranty expiration mark.
    Good luck, and I'll be interested to hear how it goes as with the same year and model, I may be faced with a similar problem in the future.
    - Paul
    ...I have the distinct impression that this is a very rare problem indeed in any MB. First time I've heard of a heater box leak in any Mercedes, assuming we are right in our collective diagnosis {how could this much collective wisdom be wrong??}...which may be why the dealer didn't start there, notwithstanding our unanimous verdict on the culprit. We shall see...
  • mac320mac320 Member Posts: 147
    The smell of antifreeze has everyone thinking; otherwise, if it is something else, using the A/C right up to shutting off the car and then using the blower the next morning when the windows are cold probably could fog the windows with the residual moisture.
    And, when moisture is left in the system all of the time, that probably could cause bad smelling air from bacteria and fungus. I heard in the past that at the start of winter when temperatures drop, people get colds, and it is not just coincidence that drivers turn on their car heaters for the first time in months at that time, i.e., bacteria in the car heaters can cause colds.
    I don't know if this is true, but a cottage industry in health claims due to bad air in buildings has sprung up over the last 3-5 years and I suppose there must be some science behind all this.
  • lg5lg5 Member Posts: 6
    Let's talk numbers...
    above car with C3, cd changer, sunroof, htd seats in metallic paint: $34,990 includes dest charge. Sound fair or not fair to anyone..??
    ...says the MSRP for this car is somewhere in the order of $36,445, with a nominal invoice of $33,941, so yes, that sounds like a reasonable offer to me. Everything depends on local context, of course - a competitive marketplace makes all the difference, so where you are can mean everything when it comes to price. In SoCal, for example, it isn't hard to get a car for $500 over invoice on C240s, but with 4Matic being so new, who knows?
    thanks guys for the insightful responses. I have 35,000 miles on the car with the full warranty. I will make an appointment w/ my service tech and now and will more confident when I sit down to explain (again) the problem. it has been my expericence that they generally are very cagey about offering opinions to a problem you explain to them, almost as if they are told not to acknoldge any problems up front. I will let you know. John
  • 2003c240deal2003c240deal Member Posts: 1
    All Instock New 2003 C 240s $3000 Off MSRP*.
    That's considerably less than TMV!
    www.calstarmercedes.com
    818-246-1190
    *Does not include government fees or taxes.
    ...I just went to CarsDirect's website, plugged in my [NorCal] zip code, and got a $2600 off quote for an '03 C240 sedan with automatic, metallic, C3, and CD changer. This is in a market that is considerably less competitive than Southern Calif.
  • plintonplinton Member Posts: 3
    All,
    I'm looking for a dealer/parts department that discounts MB OEM parts. A particularly onerous pot hole damaged two of my rims on a recent trip to NY. So now my barely broken-in 2002 C320 (with only 9,000 miles) has a vibration that I cannot live with.
    I'm trying to avoid paying full dealer price for replacement wheels. If anyone knows of a dealer (in the DC area or who will ship) that sells parts at cost-plus, I'd appreciate the referral.
    Paul
    ...some will be new wheels, some will be takeoffs - all will be less expensive than the dealer:
    http://www.stockwheels.com/index.html
    http://www.aaarims.com/index.html
    These will involve shipping, of course, but will still save you money over new stock. AAA last month had an "overstock" special on W203 sedan wheels - check the overstock sale part of the website to see if they are still available - the price was under $200 a wheel, including shipping. [I'll try for the direct link here:...]
    http://www.aaarims.com/cgi-bin/overstock/web_store.cgi
    Also, if you are an MBCA member, there are other discounts available from various MB dealers.
  • rainersrainers Member Posts: 50
    #5767 of 5768 replacement OEM wheels for 2002 C by plinton Oct 28, 2002 (01:33 pm)
    I know where you get some for 150.00 each. Email me for help. Rainers@minn.net
  • nachiketajoshinachiketajoshi Member Posts: 3
    Hello fellow MBers:
    I asked earlier about buying a factory-warrantied lemon from Ebay. All responses were negative. I took your advice and did not buy it. However, I still think it is a good buy if you want to keep it for a while (since selling a lemon is a bit difficult than selling $0.10 lemonades ;-)
    Anyway, instead, I ended up with a clear title 1999 C 230 Kompressor. I like it so far (the first month), but have some questions not seemed to be discussed here before:
    1. Previous discussions show that to hang the front license plate, one needs to get 4 holes drilled in the front bumper. My questions (a): what do I expect to pay at the dealership for drilling and mounting bracket? (b) would any universal size plate bought from autozone do?
    2. The dreaded snow tire question, which is debated to death, but I would appreciate a simple answer: (a) for Omaha, where about 3-4 storms of 4 inches plus in Winter are expected, does a reasonably cautious driver need snow tires on this rear wheel drive vehicle? (b) do you put any stock in putting sand bags in trunk as a secondary option to mounting snow tires? (No, snow chains are out of question for their hassel).
    I answered the first part of your question on the other board...
  • twofourtwofour Member Posts: 6
    Does anyone have experience with tirerack.com and their C class or any MB? I want to buy a set of four (4) snow tires mounted on steel (non-alloy) wheels supplied by them. I am concerned about proper offset,bolt pattern, fit and balance. Their wheels are considerably cheaper than MB's but it could be a waste of money and much hassle. Any input will be greatly appreciated.
    ...they take great care on all of those issues, but of course steel wheels have a little more risk of vibrations [mostly due to runout] than alloys, but not much.
    If they say a given set of wheels will fit, they will. We have used them [wheel/tire packages] on Hondas and Toyotas, with only one wheel/tire needing to be rebalanced on a road-force machine to get runout corrected. And TireRack paid for the rebalance...
  • dvancaodvancao Member Posts: 13
    I bought alloy wheels and snow tires from them last January.
    They know their stuff. I ordered it through the web and latter on the day, a sales guy called me to confirm that is what I wanted to ordered and if I had any questions. It came mounted and balanced, OEM M-B center cap and bolts for these wheels. All I had to do was take off the M-B wheels/tires, put these new ones on and torque the bolts (very important). I recommend you get the alloy wheels. They look better than steel wheels, with or without wheel covers. The winter tires work great in the snow. I live in Minnesota.
    This is what I ordered.
    Wheels: Mille Miglia Bello 16x7.5
    Tires: Dunlop Winter Sport M2 in 205/55-16 (OEM Size).
    Total cost: $1,000
  • nedzelnedzel Member Posts: 787
    with Tirerack was not good. I ordered a new set of summer tires and four wheels. They did not properly balance them and did not include the wheel locks that I paid for. Cross shop with your local tire/wheel store. The difference in price might not be all that great. And my local tire store will balance the wheels once a year for free.
  • e320wagone320wagon Member Posts: 13
    On my c320 there is a wire frame inside the gas filler lid that is meant to hold the gas cap while you are filling up. Our 2001 e320 has a similar frame, and the cap is a snug fit in it. But on the C the frame is too large, so the gas cap just balances there, and usually falls out.
    I am wondering if my C has a "non-USA" frame in it. Can anyone comment on how their gas cap fits in its filler lid frame??
  • mleskovarmleskovar Member Posts: 171
    Mine works the same as yours e320wagon. It looks like a little bending by hand would fix it though.
    ...works fine on our '02 C240.
  • mbgambga Member Posts: 11
    Any words of wisdom, things to look out for when having this done? For example, a friend has it done recently and was initially told tire rotation was not included, but did throw it in. I will be using a different dealer, so maybe I won't have that problem.
    I have some minor problems: front center cup holder won't fold down and loud noise when retracting the rear shade (sounds like the motor isn't cutting off until well after it is seated). My gas cap frame is okay, by the way.
    I assume they will take care of these things, but wondered what others experiences have been. Thanks.
    It was news to me. A German car enthusiast told me you cannot tell except for the VIN number: if your "C" was assembled in Germany, there will be a letter "A" or "F" followed by six more numbers at the very end of the VIN number, whereas the Brazilian-assembled "C"s will have one of three different letters
    Apparently, even though some "C"s are assembled in So. America, they're considered 100% "Made in Germany" because every part comes from Germany (I don't know where the Brazilian "C"s are painted). By comparison, in the production facility in Alabama where MLs are assembled, only the most expensive elements for the ML come from Germany, like the engine, drive train, electronics, &etc., whereas the body parts are made in the U.S.
    I read recently that German workers cost 50% more and are less productive compared to U.S. workers. Using Brazilian labor probably offers an even greater economic value than US workers.
    Once "C" body parts are made in Brazil instead of just being assembled like a Heathkit radio, MB will have a competitive product to offer West Coast buyers, i.e., a better made "C" at a lower price. I hear the Brazilian-assembled "C"s are actually better than from Germany . . . but, I'd want a discount.
    We've had this discussion many times in the past - scroll back a few hundred posts for more details.
    Yes, the Brazilian Cs are made from knock-down kits, which means no parts are fabricated on-site. Don't know about painting, but I do know that assembly standards are the same worldwide. Why a "discount"? Good thing Honda, Toyota, Mitsu, Subaru, Nissan, and yes, M-Class owners don't feel the same way...
    All right-hand drive Cs are made in South Africa - I rather doubt UK buyers have much bargaining power derived from that fact.
    If you have waited 10,000 miles to have the tires rotated the first time, you've probably already gone too long. Now they have a "set" to the belts, and you run the risk of vibrations and noise. Could be OK, depending on which tires the car has [Michelins are less prone to these problems than Pirellis or Continentals], or not...
    Just be prepared: make sure the car feels right before driving too far from the dealership. This is also a discussion we've had before, most recently on one of the other C-Class boards. Tires that go much beyond 5k-7.5k miles are at risk for problems if you try to rotate them; this is one reason MB no longer wants to pay for it...BMW has dropped it from their service recommendations altogether, because they know that waiting for the first service is too long.
    I do all our tire rotations myself in the garage at 3000 mile intervals...many tire stores will do it for you for a minimal or even no charge, but make sure they use the correct bolt torque and use a real hand torque wrench, not a gun, to tighten the bolts.
  • richjenkinsrichjenkins Member Posts: 55
    Hi all - Been away for a while...but back.
    "Otto" (99 C280) has been reasonably reliable lately. Needed tyres at 36K, replaced OEM Goodyear RS/A's with Michelin MXV4+, very nice ride. My windscreen wiper shuddering had me stumped for a while. Tried Rainx, Bon Ami, etc etc but nothing. It was finally cured by using a Bosch Microedge blade bought from local discount parts store -- no more skip! Elec sunroof still occasionally sticky after a rain - but usually clears up.
    Ok, question for you guys out there; been daydreaming about the perfect car -- you know Mini Cooper S, new E class, Diablo, etc, when I stumbled on the fact that the '03 C 320 comes with -- drum roll -- a standard 6 speed transmission!
    This would make it (for me) the perfect car. I knew the C240 came with a six speed but was ever hoping for bigger engine with a standard shift...
    Is there anyone on the board with a standard shift, either 240 or 320, that would care to comment on it?
    Would be curious about:
    - clutch uptake
    - shift feel
    - throttle response (not, strictly speaking, subject to auto vs. standard but sometimes I notice the throttle is a little too slow sometimes on the slushbox)
    Thanks in advance all!
    rich
    As long as you're talking about the "perfect car" an also about a "C," and also about responsive shifting, you may want to consider also the C32 which has the more active automatic shifting system that switches gears faster and won't upshift when slowing on curves.
    And, for the most "perfect car," that probably would be the upcoming E-Class Kompressor-AMG (nearly 500 hp) with the same active shifting and also with semi-active suspension.
    The main complaint about the manual is a real notchiness between gates. There have been a few problems with synchros in the lower gears, but statistically, no more than automatic trans problems.
    I found the notchiness to be noticeable on the car I drove, but not a show-stopper. It is certainly not in BMW's class, never mind Honda's, but still OK.
    Keep in mind that in this car [as opposed to a 3er], the manual will make the car a harder sell at resale time. How much this matters, as usual, depends entirely on how long you plan to keep the car.
    John - Hello, nice to hear from you again. As always, sage advice.
    Car before Otto was a 92 Accord EX 5 Spd, driven 98K. Before that was an 89 Accord LX 5 Spd, driven 103K. And before that was a 85 Civic Lx, driven 106K...you get the idea(!). After moving back to the states in 98, and finally having the wherewithal to buy one of these Silver Arrows, the only real thing I had to swallow was the automatic in the W201 C. Great car, and even the autobox was not so bad after all. But now with the manual in the C320, plus all the other bits etc its starting to look better and better. I drove a C180 (?) last year in Germany from Avis on a business trip for 600+ km. I personally did not notice the notchiness (frankly, my first time on the Autobahn kept my attention I can tell you:) just a reasonably smooth shifting 6 speed.
    Mac - Yes, please, would not have any problem driving the C32 (I suppose!) its just that I'd have to separate from north of $50K of my hard-earned bucks to get one...just a little out of my league. The E class will remain out of reach for a long period of time.
    Current outlook from she-who-must-be-obeyed is that I need a car to go 10 years; hence the interest in a 6 speed for an Otto replacement. So resale value is less of a concern for the 6 speed. The reason for thinking about replacing Otto is (strangely enough) driving a new Mini Cooper S (we have an old Mini) in the summer; what a hoot. Woke me up to how much fun it is to "drive" the car vs. letting the autobox do it for you.
    Thanks Guys, really appreciate the comments...
    rich
  • mbnut1mbnut1 Member Posts: 403
    I doubt that one would ever be available to test drive for me given it's low market appeal, however I would expect that if it were geared properly it would be much more satifying to drive than the C240. The principle reason being the C320's increased torque. The C240 with the 6 speed felt too much like an economy car in that it required a lot of revs to get anything out of it and then the engine seemed to run out of breath at the upper end. IMHO the C240 is much better matched with the 5 speed automatic where the power is delivered much more smoothly. I would expect / hope the the C320 could be lugged more effectively than the C240 like my past 190E 2.6 and current 1.8T A4 and the BMW 325.
  • ek01ek01 Member Posts: 37
    Hi folks. Any thoughts on the C240 4Matic wagon's power for highway driving and merging. I am comparison shopping for a wagon and found out that this is in my budget. There are none in the Toronto area for a test drive. Thanks.
    Fred - Yes, I agree, it is going to be hard to find one to drive. Was at the dealership here in Orlando this afternoon wandering around (as you do) and did not find a single standard shift C240 from the dozen or so that were on the lot:(
    rich
    For me, a C 240 station wagin with 4MATIC would be just fine. I don't expect a car like that to be fast or even quick, so I would not be disappointed by the >10 seconds it would take to accelerate from 0-100 km/h. If you'e expecting an Audi Quattro stage rally winner, forget it, but if you want a good-looking all weather vehicle with adequate performance it should be fine.
  • newhampshirenewhampshire Member Posts: 7
    I have a manual C-240 and I know where you can test drive one as well. There is a dealership in Burlington, Vermont named "The Automaster". Because of Vermonter's general preference for manual transmissons, they routinely stock C-classes with 6-speeds. They are a Porsche, BMW, Mercedes, Honda dealer. A great place to cross shop cars like the BMW 3 series and MB C-class. I was happy with buying my car there. The sales persons name was Aaron Root.
    I have owned my 6-speed C-240 for over 1 year, and before that I drove a Porsche 944 maunal. My commentary would be this.
    The C-240 does have a noticeable notchiness between 1st and 2nd, but it is nothing that a good driver can't handle. Otherwise the gearbox is incredibly precise. You can very quickly and easily feel where the next gear is and there is no sloppiness like japanese gearboxes. The clutch is firm and provides some feedback... not even close to the amount the old Porsche gave though. Spend some time in Germany and you will quickly realize that almost every car sold there is a manual, the engineers know what they are doing.
    The most interesting thing is the interaction between the ESP, Traction control and the 6-speed. They don't seem to interfere... one could imagine the traction control applying the brakes on ice thus causing the engine to stall because of the manual. This has never happened to me and I have tried to confuse it many times. Another wonder of German engineering I suppose.
    I really like the 6-speed. Sitting in 6th gear at 3000rpm and 80mph is quite nice. Fuel economy on the highway is 29.6 mpg over 380 miles at 72 mph average. Of course a quick jaunt through the twisty back roads is equally appealing. I can say that stop and go traffic sucks more than a 35 gallon shopvac, although I did commute through Boston for a year.
    As for the people who are worried about resale value, I say that is bunk. The 6-speed is $1200 less than the auto initially... and if you invest that money for your 4 years of ownership even conservatively (8%) you can "afford" over $1600 of lost resale price... or somewhere close to %10 of the resale value. Do you really think the difference is that big? And remember that if you find the right buyer, they may view it as more desirable to have a stick...
    I wish the 6-speed was available in the C-320 when I bought. I think that car is a huge value at 34K.
    On another subject. I always try to find a way to check up on the honesty of a dealers service department. For instance if they are suppose to rotate the tires, mark one of them with some chalk on the inside wall. After the appointment see if the tire has moved. You can also do some other things like check the levels of all the fluids immediately before you take the car in and then repeat it afterwards. Keeping service departments honest is very difficult... it helps if they know that there is a chance that they have an educated consumer on their hands.
    Please share with us the conservative 8% investments that you speak of.
  • Kirstie_HKirstie_H Administrator Posts: 11,149
    A journalist from a wire service is looking for comments about heated seats - do you really love them, or really hate them, or really hate having to pay for them in an option package? Please send your thoughts and daytime contact info to jfallon@edmunds.com by Tuesday, November 12 at 2pm Eastern.
    MODERATOR /ADMINISTRATOR
    Share your vehicle reviews
    They're not needed until it's cold, of course, but on those occasions, when I've used them, they're quicker acting than the car's heater and largely eliminate the need for the car's heater. I'm sure the family cat would enjoy spending 8-10 hours a day in the heated seats, but surprisingly, my wife doesn't care to use them at all.
  • mmoskoitzmmoskoitz Member Posts: 10
    My wife and I bought our first car with heated seats, a 2001 Mercedes C240, off the lot with the heated seat/headlamp washer package. Wow, what a joy. A warm seat bottom and back even on a cool day feels great. My father always claimed that leather seats were too cold in the winter. Not anymore. I was so thrilled with heated seats that when I recently bought a new pre owned car for myself I only looked for inexpensive used luxury cars, like my 1999 Saab 9-3 SE, that featured heated front and rear seats. It seams that while leather has gone as far down market as the 2002 Mazda Protégé 5, 2003 Toyota Corolla LE and the Hyundai Elantra GT, heated seats still haven't followed.
  • ciracira Member Posts: 37
    John, you warn "but make sure they use the correct bolt torque and use a real hand torque wrench, not a gun, to tighten the bolts." I had my tires rotated at Town Fair Tires and they gunned all the bolts. What's the problem with doing it that way that I need to be aware of?
  • highrise_condohighrise_condo Member Posts: 16
    The owner's manual for my 2002 C240 has instructions for "Audio system tone level selection" where you can set the tone levels for Driver, Speech, or Ambience (page 179). It states that you press the "AUD" key to access the tone level setting menu. However, my "AUD" key on my non-Bose system only allows individual bass, treble, fader, and balance settings. Am I missing something? Does this apply only to the Bose system? Or is there a problem with my radio?
    BTW, I've had my C240 with C2, auto, and CD for 13 months. Except for an axle issue the day after I took delivery, the car has been 100% problem-free. It has been flawless. I am more satisfied with this car than I ever thought possible.
    ...overtorquing lug nuts to beyond specification can lead to damaged rims and warped rotors. Undertorquing can lead to lost lug nuts and worse.
    I tighten mine with a hand torque wrench anytime a wheel comes off the car and then recheck the torque after 100-150 miles to ensure the are on correctly. I do it at times right in the dealer's parking lot after a service.
    Is improper torquing the end of the world - IMHO no. But one set of rotors too soon easily justifies the cost of a torque wrench.
    Good Luck.
    Just had my tires rotated and balanced on my '00 C230 by the dealer today at 6,800 miles and what a difference - thanks for the advice, John! On the highway, the car rides quieter and handles better. Even with the $40. charge (not included in scheduled maintenance), it was well worth it. I will continue to do this every 6k as it seems to be a good investment of maintenance $.
    The "free" car wash by the dealer was great too, and I got to drive a '02 C240 as a loaner. Due to the design and familiarity I still prefer my '00, but I can see areas where there have been definite improvements to the car (i.e., tilting steering column - not only telescopic, digital speedometer, MPG gauge, etc.).
    - Paul
    Well, Rob has answered the question. The problem with the guns is that they are rarely set to exactly the recommendation of the manufacturer, and worse, do not always stop when they're supposed to.
    Most common result is overtightening, but the worst possible outcome is uneven tightening - almost certain warped rotors and vibrations will be the result.
    I too follow the regimen that Rob talks about - I never drive the car away from a service in which the wheels have been disturbed without using my own torque wrench on the spot, and then follow up with a retorque [as recommended by all car makers] sometime during the next couple of hundred miles. [ A side benefit is that you KNOW you'll be able to take a wheel off in an emergency - some shops have been known to tighten them so much that you literally can't generate enough force to move the bolts if you are a small person. ]
    Thanks for the tire rotation advice. I have an unrelated question. Does anyone know if you can maintain the digital speedometer readout in the dashboard display on restart? Mine always resets to the odometer display on engine shutoff, then I have to scroll back to the speedometer display when I start the engine. Is there a way to lock it in place? Thanks for any advice.
  • greg129greg129 Member Posts: 2
    I have @11k miles on my C320 wagon and I have had significant quality issues that has surprised me. I bought the car for the quality reputaion, I thought anyway. 1st I was astonished when the first day the car sputtered and then the main computer module went out and the car stalled. Then the power seat modules went out, door lock knobs came off. Center shift trim came off, lighter got stuck in hole. This is not what expected from a Mercedes. Based on what I have seen so far, I would not want to buy another. Anyone else have these issues? I was told that Mercedes quality has taken a dive, their quality cost for repair of triples the past 3 years. Is this true?
    You seem as surprised about build quality as the rest of us who bought our first MB. The only words of advice I have is once the bugs are worked out the car is rock solid. Working out the bugs is frustrating, time consuming, and not in keeping with today's quality standards. Talking to other MB owners the nigling repairs are part of the package. Constant references to Japanese quality standards don't help any. MB hasn't figured out parts vendor realationships yet like the Japanese have. I prefer the MB comfort, solid ride, power characteristics, safety and handling above all others...or I would buy a Japanes car if detail to quality was more important. So far my warranty repairs haven't been show stoppers...just irritants.
    We haven't thrown in the towel yet..just expected more quality from a $41,000+ car. I speak with other new Mercedes owners an they too have these problems. Wish MB would listen more. For now I would not buy another. Return buyers are the heart of a franchise. Perhaps time might change my mind.
    Hi all - unusual question perhaps, just wondering if anybody had heard anything regarding changes for 2004 model year C class.
    Quick internet search revealed nothing interesting, just wondering if any of you Benz watchers had any info.
    Question is related to "when" for W203 C Class purchase; info I've found to date indicates W204 will come along in 2007 or so. So one could expect a mild face lift or styling freshening, and possibly engine tweaking in the middle of the product cycle (2001-2007).
    thanks all...rj
