Oldsmobile Aurora
17778808283112
  • rjs200240rjs200240 Member Posts: 1,277
    Musclecar97: "On a dark desert highway...cool wind..."
    Losing your hair and that's why you stopped there? Just a guess...
    Mike, once at my local Olds/Chevy dealer a lady thought my car was the nicest looking Impala she'd ever seen. I then explained to her it was because it was an Aurora...
  • HenryHenry Member Posts: 1,106
    But it was funny.
  • 800wattaurora800wattaurora Member Posts: 187
    What's up guys, no one responded to my last message about getting ride of my aurora?
     #4194 of 4197 Well guys?? by 800wattaurora
    Garnes, rjs, blk97,musclecar, henry? Yah, Henry you want my slightly used Corsa.
  • stickking1stickking1 Member Posts: 247
    Hey, sorry about the late post...something about the "server not being able to accept new posts" this morning. Keep us updated on what your plans are. I know I would be very interested in the Corsa and the RSM stuff...depending on how good this month is to me.
    just because of the backfire problem, you want to get rid of it? You have a warranty, right? Take it to a dealer who can figure it out. If they aren't cutting it, try another one. I don't imagine you'd get much for the car if it's backfiring on the test-drive... Plus, what would you get?
  • garnesgarnes Member Posts: 950
    Yeah, I would not give up just because of the back fire. Someone should be able to solve that. You got a lot into that cool car. However, if you do dump it, I want dibs on the heat shield/cold air intake. That thing is cool, and I would not mind trying it out. You got my number. Just call me about it. But I really hope you can work the problem out.
    A friend of mine is in the market for something new and mentioned he liked the ES300. Being the Aurora expert because of you guys, I said that he had to look at the 2003 Aurora and gave the many reasons. Well, he did and really liked it. Sounds like he might buy one. Very cool.
    The interior on the new Aurora does seem a bit more refined than the classic. It's just one heck of a car for the money. That engine is more refined as well. I'll have to show him RJS's Corsa pictures and take him for a ride in my car for sure.
  • fjk57702fjk57702 Member Posts: 539
    Once (not my old Aurora though) I had backfire that was due to sparkplug wires that needed to be replaced. This is something should show up on a test perhaps, but will be worse if it is damp out.
  • blk97aurorablk97aurora Member Posts: 573
    800watt:
    I didn't respond right away because I was sure you'd come to your senses :,)
    How did you determine "No codes are coming up"? The reason I ask is that I have been researching code readers and scanners (ordered an AutoXray 10150 last week). To my surprise, I discovered there are significant differences in the ability of different units to pull up historical codes -- some can, others cannot.
    There are two types of backfire -- intake side and exhaust side. I know from experience that a leaky fuel-pressure regulator can cause one helluva backfire in the intake manifold. So can mistimed camshafts, but that wouldn't be intermittent.
    I'm not sure that popping in the exhaust side is really backfire, but it's often called that. A cylinder misfiring and dumping unburned gasoline into a hot exhaust manifold or cat will cause that problem. I'd be very surprised if the OBDII emission controls didn't pick it up. As mentioned before, plugs, wires, coils, ignition module could be the culprit. I also wonder if a bad injector could cause the condition.
    If you do sell, I'd be interested in the RSM 80mm throttle body and mounting plate since I have not ordered mine yet. I don't remember if you have the RSM strut and shock tower braces.
    I would suggest that youreally look into the backfire issue. It is annoying but should be fixable. Where are you located?
    Secondly, if you do decide to get rid of the car, I'll take the corsa. Heck, I might as well take the whole car. I could keep the mods and drill out the engine to 4.6L. The mods to the engine would most likely fix the backfire.
    Henri
  • hammen2hammen2 Member Posts: 1,284
    Taylor, you're not going to get much of a trade on your Aurora because:
    a) used-car values are low right now
    b) Oldsmobile used car values are especially low
    c) there's something wrong with your car.
    So, taking that into account, you've got to find a competent mechanic to help you out. Not sure if you'd come up to Milwaukee, but one of my techs has a buddy whose business is engine repair/rebuilding.
    I can relate to the hurt feelings/pain when your car is not working right/lets you down. I just went through that with my Aurora after my rear crankshaft seal leak of a month ago. I contemplated selling the car, but, even with all of the incentives, discounts, GMS pricing, GM card rebates, trading in my '98 for a new '03 was wayyy too expensive to consider (I could maybe get what I owe for my '98, and don't have any cash to put down, meaning I'd have to finance for 5 years (4 years longer than my remaining loan) at $100/mo. more than I'm paying now.
    You can't just give up without giving it the old college try. Ask around at work for a competent third-party mechanic/don't just take your car to the Olds dealer ($$$$$), especially if your extended warranty is gone...
    Hope this helps,
    --Robert
    From one of my techs:
    "This sounds like a similar problem like we were having with a GTP at the shop. Wayne doesn't have the diagnostic tools for this. But it sounds like it could be a bad coil or a bad ignition module. We had the same issue with no codes, but yet the car wasn't running right. Although the computer is suppose to pick up problems and turn the engine light on, it doesn't always happen. This was that issue where nobody else but Foster Pontiac could figure it out. I would think a dealer with the right equipment would be able to find the problem."
  • mike98cmike98c Member Posts: 293
    I would also try pulling and examining each of the spark plugs. This might not tell you anything if the problem is to intermittent but it's worth a shot, especially if you pull them right after the car misbehaves.
  • ffreysffreys Member Posts: 12
    Hi all...thanks for the info on the mods pages......getting lots of ideas.....have my first problem with the '95 .......it has an intermittent "chirping" noise coming from somewhere on the front passenger side....I notice it more at slower speeds and when I turn right...dosen't seem to be brake related...kinda sounds like it is coming from under or inside the dash....thanks in advance for any suggestions...P.S. no I am not missing my parakeet!
    Sorry, but I just have to post another rant about the media bias towards german and japanese cars. This was in Car and Driver's long term test of an M3.
    "For one thing, the M3 has the most cold-blooded engine we've encountered in quite some time. The highly-tuned six sometimes stalled at the first starting attempt. And often when it managed to run on the first attemt, it spit and bucked for several seconds before settling down."
    I realize they are posting some critisizm of a BMW, but look at how they do it. They call the engine cold-blooded like it is just some determined professional, and they call it a "highly tuned" engine that stalls and bucks. That doesn't sound very well tuned to me... Think they would use the same language if a Corvette stalled and bucked?
    "The casual driver will also be shocked by the M3's appetite for motor oil. Our car consumed the first quart in less than 1900 miles, and by its first oil change at 12,500 miles - a service interval determined by the onboard maintenance system - this ultimate driving machine had used three more quarts." Then they go on to mention how it requires one of two special brands of 10w-60 that can only be found at the dealer for $9 a quart... They also go on to mention that there have been actual cases of M3 engines failing because owners used the wrong oil. I guess you have to plan all your trips around regular stops at Bimmer dealerships...
    Apparenly if I am shocked by that oil consumption, it is only because I am a casual driver and not worthy of such a tuned machine...
    Then mention the climate control system failing, and the door seal malfunctioning and staining black the leather door trim.
    They conclude by saying "A bit too high-strung in some ways, the M3 has too much sporting flavor to suit many drivers. But if you want full-fledged high-performance sports-car capabilities in an everyday-usable package for four adults, the M3 is a terrific choice." I guess stalling every time you start it, and guzzling oil is just sporting flavor. I can't help but wonder if that's what they'd call it if a domestic car did it.
    They did a less obvious, but still annoying wrap-up of their Acura CL Type-S. They mentioned the fake wood trim looked horribly fake, the rear seat was too cramped for anyone to want to ride in it, power seats whos adjustments just wouldn't work properly or consistently, an airbag light problem (fixed by dealer), a lack of headroom for the driver, a nav system that made climate adjustments difficult, frustrating operation of the manumatic shifter that doesn't allow selection of 1st, lots of wind noise, lots of torque steer, and they noted an ever increasing creaking of the sunroof and body due to body flex (referred to as "squeaking like crazy"). Yet they go on to say "...we got a sense of both quality and value from 12 months of mock CL Type-S ownership." Maybe I just don't get it...
    Well, as Blk97 put it, I think I'm coming to my senses here. Be cheepier to fix it (probably) than to dish out for a new car right now. I did take it to Autozone for there free scan and it came up empty. So probably take it to the dealer for inspection. I do have an aftermarket warrenty off the net which I haven't used yet thru-Platinum warr. Non-transferable after first claim. So sell now with things looking good on paper. To make things even worse, I'm driving along yesterday and I'm rocking along and all of a sudden my subwoofers start flipping out. Melted a voice coil on one JL subs. Bummer, that just happened to me 14 months ago. Have 3 year warrenty for all my system so the good news is Tweeter will replace it again. But, being the gearhead and audio-holic that I am, I thought two things I obsess about are in the toliet right now, I could just start all over again with something nicer and newer. So that where my thinking is coming from.
    Well all the things you guys named are good logical possible solutions for my backfire out the intake manifold, I've replaced almost everything you guys named over the 3+ years of owner ship and 42K I put on my 96 now at 94K. When I bought the car they only bad service dates was for 2 injectors replaced, the rest were all retuine maintance. Since I bought it with 52K I've replace alot, thank god for having boughten that 3year warrenty. Two weeks ago I put in 4 ignition coil packs on me, fixed my stuttering problem, did 100k service at 80K so new plugs wires, had a fuel rail crack 350Mi. from my house, so new fuel rails and I had them put in a new fuel pressure regulator also since this is a known week point. That's all I've had replaced that could relate to my backfire out the intake problem. Now other things I've replaced are recently a radiator and EGR valve, guess that could relate too. Um what else, multi-function switch (clicking under dash) which is happening again now too, another point for the darkside, two power window motors went and about 8-9 foglights blew. I bet there are a few things I'm fogeting about too, like KYB struts. Than factor in all retuine maint. new tires rims my RSM mods which do include the strut tower bar blk97 and my stereo system. This car is the money pit! Not really complaing though. I still love my car. I've been thinking about what else I would want to drive and I can't decide nothing really grabs me out there. So I've been looking on the on the road for somthing to grab my eye and the best thing a I saw was a shine white aurora like mine, that when it hit me, keep it!
    As Robert said it, Going to give it the old college try! Not old for me, turned 22 two weeks ago and I'm am graduation next fall. So my current car thinking now is that there has to be good spark so problem has to be fuel related. Could be clogged injector(s) my dad asked his auto teacher at his voc. school what he thought. First he recomended getting the fuel infectors cleaned or replaced, he mentioned he could clean them out for me, going to look into that. This teacher has worked on northstars before and suggested to me that the air/fuel ratio probabley isn't right/optimal with my mods. He highly recommend that I either get the PCM re-programed to adjust for the extra air i'm shoving down my 4.0. Needs more fuel or get an adjustable FPR and raise the pressure slighly. He told me I could pinch the fuel return line for couple of seconds to raise the line pressure and see if more pressure will stop the backfire. He knew that the aftermarket selection is narrow for these cars, he definitly thinks it's running lean, "you need more fule kid" If you can't find either make larger orifices in the fuel injectors with a drill or something if you can't find a higher cfm injector. . Well with that info, I called my corsa installer shop who is hot rod shop and the owner said his "chip guy" should be able to help me out. He said they custom program every car and have access to the decoding of obd-II. So that's a big one for the good side. I guess I'll just take it to the dealer and pay the $95 inspection fee, hopefully they find whats wrong and it be covered by the warrenty then inspection fee is on them. That would be great, but very doubtful, things haven't been going my way in the car department.
    Thanks for always being here for me guys!
    Are you only getting backfire under WOT? Because at part throttle, you aren't cramming more air in than the engine can handle. I kind of doubt your car is making more power than it can provide fuel for just from bolt on stuff. I have to say, if you are having combustion problems, I'd think a custom ECU would just make it worse... But that's just my two cents.
    "air/fuel ratio probably isn't right/optimal with my mods. He highly recommend that I either get the PCM re-programed to adjust for the extra air I'm shoving down my 4.0. Needs more fuel or get an adjustable FPR and raise the pressure slightly"
    I have to comment here. I think all that stuff is a bunch of B.S! I have all the same mods you do and I have no problems. RJS is using the K&N and has the Corsa, so except for the TB he is very similar too.
    When I ran my dyno's, with the K&N, box mod, and TB I also ran F/A ratios. Guess what - they did not change. I do not see how exhaust would change anything. How in the world does less resistance to pushing out the exhaust equate to "more air coming in"??. The exhaust mod just means more power goes to the crank and is not wasted working to push out the exhaust. Also remember "more air" as far as I understand, really means more dense air. As the cylinder goes down for the fill stroke the volume of the air is the same - mods or not. The difference is how dense - the mass. So I don't see how the exhaust mod helps get denser air into the engine.
    Not to confuse things, but as a side note, I can see how an intake mod makes for a tougher job for the greater mass of air to be expelled (perhaps exponentially related to the density of the air too) thus making an exhaust mod very beneficial when making intake mods.
    Sorry, I would not waste my time or money exploring computer reprogramming, or leaning out the car.
    The MAF can read the air flow. Your car is really only mildly modded - it's not that big of a difference in air flow. The only thought I have on your set-up as it relates to air flow is this: your cold air intake uses a duct that is smaller diameter than the MAF. It only expands to the full diameter at the boot. So, it's possible that the little wire that senses the air flow (it's in the middle) could see higher velocities because the air is channeled to a smaller diameter down the middle. This would make the MAF "think" there is more air than there really is and you would get a corresponding higher fuel feed to match. You'd be richer.
    I'm not saying that this is happening, but it's a thought. BTW - your car did not have these troubles earlier with these mods - right? If it was the mods and A/F, you should have had this all along.
    If you are truly concerned about A/F, I'd do another dyno first to check it before you mess with programming.
    Well those are my thoughts. Maybe I'm off, but I do think there is a LOT of hocus-pocus from people that work on cars, but perhaps don't know or understand the physics of what is happening. Who knows, I probably am missing something, but for now, I say it's not the mods. If the A/F is indeed bad, maybe the MAF is on the blink. That's possible. I've got an extra one that was "recalibrated" to original A/F. Remember the Granatelli? It was reprogrammed to lean the car out. Power dropped. I sent it back to have the A/F set back to original. It sits in the box now.
    Hey, maybe something you changed out at 80k just went bad - it's defective. I'd check all the stuff the other guys have mentioned.
    Actually yes, it only backfires under WOT. Very rarely happens while driving, after the ingnition coils, which is good. But if I rev it hard at a stop, in gear or neutral/park it will backfire. This is the only way I can re-create it. I'll have someone pinch the fuel return line, and I'll rev it, see what happens. Most likely I'm guessing it's a dirty fuel injector I hope. Not a sticky valve spring or warn camshaft or something internal that costs big bucks.
    As for programed ECU if I can get this fixed, I'll definitly see what kind of "chip" these guys can come up with.
    Yeah I read those articles too and could not believe it. The M3 they drove was a PILE. I'm sorry, but the stuff going wrong was fundamental to any automobile. Their experience was enough to terrify any car person that would actually consider owning one. I'll say it again. What a PILE. Yeah, it's high performance - but apparently at the expense of everything fundamental to a working automobile not to mention some "build quality" issues too.
    You should send them a letter. Really. They need to hear this. They will probably issue another "bad gas" excuse like they did for the G35 and some other cars not performing so well (even though some of the cars in the comparison did not seem to be affected by the "bad gas" as much as others - and they offered this excuse AFTER letters came in). Who knows, they may even blame the incomprehensible oil usage on the gas too - after all, they think their readers are stupid enough to believe all the other lame-o stuff.
    The bottom line is that the imports can do no wrong and objectivity is a foolish dream. That's what these guys buy. I guess if I worked there and I was reviewing an Aurora, or an Impala or really anything Olds or Chevy, I'd be slanted too. But I don't think I'd be delusional like these guys are. Also, I believe the people that work at these magazines work in an echo chamber and are basically influenced by their peers. What, trash the M3 for it's obvious failings or the Acura for some cheapo interior parts??? I might get questioned on that. After all, everybody know only the domestics have cheap plastic for the interiors - right?
    BTW, I have no idea if this is true, but I got an e-mail that indicated Car & Driver (Vivendi?) and Road & Track are French owned. Hmmmm. Perhaps yet another reason not to buy these magazines.
  • patpat Member Posts: 10,421
    There are plenty of places all over the web to talk about boycotts and other political issues. Let's just remember that the Town Hall is not one of them.
    Most of our membership appreciates being able to come here and talk about cars without having to think about the very hard things that seem to be happening in the world.
    Was the fuel filter ever replaced? Also have you dumped fuel sytstem cleaner into the car since fpr was replaced? Some brands allegedly will eat right through the diaphram of the fpr. You could hook a gauge to the shraeder valve on the fuel rail and test the pressure at idle and accelerating under load.
    ..in the Detroit News (mentions the end of Aurora production, and includes a pic of one of the chassis at Lake Orion):
    http://www.detnews.com/2003/autosinsider/0304/04/b01-127967.htm
  • nne3jxcnne3jxc Member Posts: 134
    For what it's worth -- and as much as I love my Aurora -- I have 2 friends with M3's. They both love their cars and the M3's -- while expensive to have routine maintenance performed -- have needed very little service.
    I've driven both of them and the are sweet rides. A little small for my taste, but you can't argue with the performance if that's what you're looking for.
    I think Car and Driver got a POS car.
    Oh, and C&D is a very biased car magazine. They do the same biased reviewing when comparing Ford vs. Chevy.
    Yes, that is a good point. The real issue is that when they test a domestic car and there is a squeak or something malfunctions, the hammer comes down - hard. In fact, the hammer comes down for some really subjective things that would be hard to define. The "look" and "feel" is not up to some nebulous standard. The all time best might be the steering wheel being too fat. Oh man. But an import with a glaring material or mechanical problem gets a pass. It's a pattern. I sure hope the other M3's are better - I'm sure they are. Well actually anything would be better than that tester.
    Maybe it was tweaked a bit too much for the tests?? Just a cynical possibility.
    Or almost any G.M. product compared to the Euro influenced Fords. OOPS was that the seat material wearing out on the Ford ZX3? Well as soon as we GLUE the multi-function stalk back on and make a chiropractic appointment for the horrible seat shape (while the car is in the shop for another recall) we can get back to the office and write that glowing review, that is if we don't have to drive to far!
    I thought the all-time best was their criticism of the Aurora in that 7-car comparo. They said it didn't cost enough... All else being equal, if they'd paid $5-10 grand more they probably would have liked it better...
    P.S. I hear you about the ownership. I doubt I'll renew them, but I probably won't renew Motor Trend either. It isn't as bad, but I still get sick of it. In the April issue, they were talking about the Auto shows and this was their bottom line for the Pontiac G6 (likely the Grand Am's direction): "In terms of styling, at least, finally a bold competitor for the Accord. Will the quality, handling, fit and finish be as good?" Finally a styling competitor for the Accord???? Are they freaking kidding? And as far as their little question at the end, it sounds as though they've already answered it in their minds. And how hard would it be to match the Accords handling? Give me a break... It's like they just think up some sentence that might sound thoughtful or impressive and then stick the word "Accord" or "Camry" in there. Don't worry about whether it is accurate or anything... Very journalistic...
    Yep. As much as a lot of it seems intentional (and some is) a lot is probably laziness. They just keep writing the same stuff over and over for their subjective stuff (which is most of it).
    But really, I strongly suspect that the writers and reviewers are indeed import owners. So, they test or compare a bunch of cars and I think it is going to be very hard to admit a domestic car performed or is a nice or better as what you have in the garage. Everybody wants to think their car purchase (especially new ones) is superior in some way. I wish all the staff would disclose what they own as you read the car reviews. It would be interesting.
    Yeah - Accord styling. Where?
    That's why I really don't put a lot of stock into owner surveys - especially for very high end cars. You just spent 60k - and to admit you are dissatisfied with something is equal to admitting you spent 60k on the wrong car. That's not going to happen much.
  • sinatra2sinatra2 Member Posts: 65
    The only time I ever pick up an auto mag is in the Doctors office. I have not purchased one in years. Usually the best reviews are from owners. That is why forums such as this are so valuable if you are thinking of a particular car. The best way to test drive (that is if you are in a major center) is to rent one for the weekend.. well worth it even if it does not have all the options you want. You can get a general feel for the car and have a few hours to examine for quality. Not only that you can put it through the paces .... taking it to the limit without worring about blowing a gasket.
    cheers
    You have a point regarding using them for reviews of "normal" cars.
    But on the other hand, a Road & Track or Car & Driver review is the closest most of us will ever come to getting behind the wheel of a half million dollar Ferrari, or some other incredibly priced example of automotive lore.
    (Can you believe that they are actually PAID to drive cars like that? Man, I'm in the wrong job.)
    LOL..................no I didn't pay to drive a Farrari.I guess I meant was auto mags are great for "fantasy trips" yet if you are buying I would rather rely on my own or the forum's (such as this one) objective opinion rather than some paid off and highly influenced journalist.
    So much depends on what you are looking for in a car. I have subscriptions to a few of the magazines and generally most of the writers like sports cars best. I think this bias has made the "sports sedan" the ideal. The BMW 3/5 series sedans are the standard for sports sedans. FWDs just do not handle quite a well, but in poor driving conditions (ice/snow) I like FWD.
  • mcclearyflmcclearyfl Member Posts: 149
    There was a captivating article in the London Times this weekend. One of the Times' motoring correspondents explained why he and his peers rarely panned outright any vehicle. The expose was written with tongue firmly in his cheek, but there appears to be much merit in his claim that automobile reviewers are actually rather poorly paid (certainly in the UK), and rely on manufacturers to provide them with what little pleasure their meager salaries would otherwise not provide! This includes trips to exotic locales to test exotic and not-so-exotic models (automobile models, that is). Why bite the hand that feeds you ?
    Of course writers are not the only ones to be less than candid about a vehicle's failings. As a past member of the Maserati fraternity I am only too well aware that almost any reference to the many inadequacies of those cars will result in an outpouring of protest in the discussion groups.
    Chris
    fjk57702 hits the nail on the head by stating that the gold standard for most writers is the BMW 3- or 5- series. These are very competent rear wheel drive sports sedans, but they suffer from many disadvantages that are very obvious to people who buy other brands.
    With this mindset how can these writers possibly appreciate a large American car such as the Aurora? Fortunately we do!
    Chris
    Actually, Car & Driver, in a comparison test (some time ago now), had a DTS which did not do well as a "sports sedan", but they said that it was a great highway car and handled much better than Cadillacs of older vintage. I thought that they went out of their way to point out that the Cadillac was a very good car, just not a sports sedan.
    Automobile (sometime back now) did a test of the Seville and Deville (DTS). They said that it was as good or better than an S-class Mercedes.
    The Aurora has made it into a number of comparison test too, but always with the sports sedans from europe. As a result it has not fared well with the much smaller cars.
    The differences in handling may not be much. I owned an 84 Corvette that I picked up used. It handled very nicely on a good (new) highway, but on poorer highways the ride was rough and you had to really work to keep the car on the road. I sold it and then later on picked up a used 86 Corvette (with the Z51 suspension package, which the 84 did not have). This car was much softer riding and did not handle quite as well. This not to say that the 86 handled bad. On less than perfect roads it was much easier to drive. The tuned port injected engine had a lot more performance than the 84's throttle body injectors.
    Wow. So many great points from a lot of different people that all support each other. Interesting.
    The Aurora was a great replacement car for the Olds 98/Olds Touring Sedan/Toronado. It was also a Buick Electra T-type replacement. I really think that Oldsmobile/GM marketing was not sure where they wanted to go with Oldsmobile. They wanted a "new direction" and so the Aurora did not have the Oldsmobile name on the outside of the car anywhere. I think they were thinking that they would rename the division or move it into Saturn or something. Or perhaps they thought making the Aurora a "mysterious car" would help sales.
    Yes, that is certainly what happened. I think somebody could probably write a book about Olds failing and how it is one of the biggest corporate blunders of all time. Just MHO, but Olds had a much better line-up than Pontiac, Buick, and Chevy. Much better, and they still fall. I guess a lot has to do with marketing. GM is clueless how to sell their cars. The previous "Toyota Aurora" stories give a hint. Most people I deal with have no idea who makes the Aurora - still.
    I went over to the library to see if I could find an ad for the 1995 Aurora. I remember seeing ads in various magazines, but don't remember details. Anyway I found an ad for the Aurora as well as the Riviera. Perhaps the details are very telling. There is a picture of the car (in both ads). In large print the Aurora ad says "Aurora". In the fine print there is the usual stuff and says that the Aurora is made by Oldsmobile. But you have to read the ad to find that out. The Riviera ad has in large print "Riviera by Buick". There is no difficulty finding out that the pictured car is a Buick.
    I think that both of these cars sold very well during the 1995 model year. But I think that the Aurora connection to Oldsmobile was downplayed and may well have resulted in the misconception that Aurora's are some other car (toyota/lexus/infinity ...)
    Thanks. The Intrigue too. That 3.5 V6 is pretty impressive. That has to be one of the flattest torque curves I've seen. It seems to produce close to it's max 230 lb-ft everywhere. Great engine. Yet I don't remember this being mentioned. I do remember these weird Intrigue commercials with some alien like humanoid looking it over. Hokey stuff like that doesn't do it for me. You gotta convey the facts. Tell the public why your engine, interior, styling, whatever - is better. Show it in action.
    The Intrigue ad that I remember was a TV commercial where the Intrigue is racing a train. I don't really recall any more details though. The 3.5 was a nice engine but the 3800's torque curve is also very flat. It doesn't last quite as long as the 3.5's so there is a little more horse power in the 3.5's. The new 3.6 is going to be a much better engine. I think they should have combined Olds with Saturn somehow. They probably needed to get rid of some of the Oldsmobile dealers though.
    I agree that's what they needed to do. If you look at the Classic, there is a "family resemblance" to the older Saturns (i.e. front end/headlights). Saturn would have then had a minivan (Silhoutte), SUV (Bravada), a decent mid-size car (Intrigue), plus a high-end car (Aurora). I think GM had too much invested in the Saturn name/franchise, plus was too afraid/gunshy on the Olds name, that they would have/should have moved the Olds models to Saturn. Makes sense to me, but no. Biggest problem I have with Richard Wagoner's tenure at GM (killing Olds completely)...
    --Robert
    The 3.5 is quite torquey. Funny how that point is missed when comparing it to other sedans. Only the lack of peak power is noted. I was reading an article in Road & Track about the Alpina Z8. They noted how it is the first Alpina to make less power than the BMW version, but that it has a much broader, fuller torque curve. They went to a great deal of effort to explain how that is actually of benefit 95% of the time. What I don't understand it how it suddenly isn't even a factor when talking about an Accord that makes 240 hp and barely 210 lb-ft of torque (at over 5 grand). One would think the more pedestrian the car (an Alpina Z8 is hardly a grocery-getter), the more this idea of useable torque would apply... Again, maybe I just don't get it.
    You all have some very interesting points. It is true that auto mags are good for the thrillers about twin-turbo Corvettes and million dollar Ferraris.
    Interesting about the Aurora ads too. I'm sure back in 1994 there were a reasonable amount of them, but what about subsequent years? I'd bet even by 1996 they dropped off a bit, though I don't really recall. I do know that I can only recall seeing one single ad for the new 2001 Aurora in Motor Trend. In fact, I specifically remember seeing it because the styling was exciting, and I'd always thought the classic Aurora was pretty cool. I was a pretty avid car mag reader then too (back then I read every article of MT, C&D, and R&T). I can't recall ever seeing a television commercial. I don't count those sorry "people are still buying Oldsmobiles, so apparently it isn't as stupid as it seems" ads because they are soo terrible and don't focus on any particular product. What the heck were they thinking with the "wonder why you see so many Oldsmobiles on the road?" commercials that showed the Bravada and Aurora? I bet most people were seeing them for the first time in that commercial...
    The new 3.6 liter V6 will have 252 ft-lbs of torque at peak with 90% (or more) from 1600 to 5800 RPM's. The would be 225 ft-lbs, nearly as much as the 3.5's peak torque.
    Most people do not know what torque is, they also don't know what horsepower is either, but understand that more horsepower should mean better performance. Except that it does not always mean that. For example, I think that the 2.8 liter BMW 3-series would out perform the 3.2 liter C-class Mercedes. This new 3.6 should be an interesting engine. How the CTS performs will be a good indication of how good the engine really is.
    Anyone see the specs for the just introduced Mazda RX-8? Holy Cats! 1.3L of Rotary displacement giving the horsepower of an Aurora (250) and 160Lb Ft of torque. Plus real nice styling and -- wow! -- those fold-away "suicide" 3rd and 4th doors.
    Look here if you haven't seen it:
    Mazda RX-8
    I don't think I'll trade the Aurora for one, but I might "pretend" and take one for a spin....
    I briefly glanced through an article that included this car. I don't think you can compare it to a piston type engine. Apples and oranges.
    They can rev extremely high. That HP comes at some nose-bleed high rpm and still no torque at probably some very high rpm as well. But it's still impressive for that little engine.
    I still say that where and when the power is available is as important if not more important than peak numbers.
    My only question is why make it only 1.3 liters??? Is a 3 or 4 liter rotary prohibitive for some reason?? I have no idea. There must be some reason or else we would see 500 HP rotary engines all over. Time for one of you gear head experts to check in here with some info about rotary engines.
  • larryfllarryfl Member Posts: 214
    While I'm certainly no expert on the subject, I did own an early '80 RX7 for a while.
    At the risk of being busted by the "off topic police"... my early 7 did have a mediocre accel until about 4K RPMs when it hit neck-snapping momentum until redline. I think the later models enjoyed a flatter power curve. It's also extremely easy to over rev those engines (no up/down piston movement) and they're equipped w/ a buzzer if you do hit the redline.
    Finally, the phenomenal power to size ratio is one of their advantages. Small under hood area and much less weight.
    That's all. We now return you to you're regularly scheduled Aurora board....
    Well, I took my car in for the emissions recall. Just a PCM reprogram. I'll have to see if that misfire has gone away. I suspect that was part of the catalyst warm-up process. Maybe enough people complained about it that they figured just easier to fix.
    Anyway, they had a Final 500 there. I parked near it so I could make a solid judgement of the color. It was cloudy and drizzling, though, so not much sun. My car looked substantially lighter in color than the CE. It looked really dark and brown. Like a reddish brown. I like my color much better.
    I've mentioned in the past my car shifts just slightly firmly. Well, it was smooth as silk on the way home. I had noticed in the past that after the first dealer (I went to a different one this time) had "scanned" the computer, that the shifting was smooth again. I then suggested to them that they reprogram the PCM because perhaps it wasn't dealing with the "learning" properly. They just ignored me. I'll see if it starts to come back now that the PCM has actually been reprogrammed. It wasn't a big deal, though.
    While I was waiting, I noticed they keep all the sales-staff training videos out. I asked if they minded if I watched one. I watched like a 20 minute presentation on the 2002 Aurora. They also had 1999, 2001, and 2003. Plus a comparo video for 2001. Man, would I love to have those in my library...
