http://community-2.webtv.net/dman4ford/00IMPALALS/
http://albums.photopoint.com/j/View?u=223638&a=1656230&p=36656496&Sequence=0&res=high
Another option is using a heat gun or hair dryer and use dental floss to "floss" between the emblem and the paint. A little bit risker, though.
McDill is correct about not being able to chip an Impala. They do make re-programmers that overwrite the car's EPROM. The benifit is you can tune the power curves without pulling the chip and risking damage. Also you can restore the factory defaults any time you want. The down side is that they don't have one for the Impala yet! Hypertech didn't have one in the works as for July '00. I guess it's time to ask again.
-0-60 mph, 6.6 secs
-1/4 mile, 15.6 secs at 91 mph
-brake 60-0, 142 feet
Not a lot of difference. No wonder the Police forces are testing the Impala! At least in terms of stopping old C3 Corvettes. The C5 is another story.....
LRCobra
The next morning I got up anxiously waiting to drive the new LS and when I looked outside I almost fainted - there was four inches of snow covering the car - it could have been my former car - Lumina LTZ. The roads were a mess but the traction control was flawless as was the AS system. Later in the day, in a warm garage, I cut out from 12 ml clear plastic forms that fit on the floorboards in the front and the back. It took about 3 hours to cut the plastic to fit but I am assured my rug will be clean during the Spring, Summer and Fall when it is removed. No more black marks on the rug beside the door. I used quarter inch staples to attach the plastic to the floor. I put it over the original mats because they also act as a sound deafener. Then on top of the plastic I put gray matching pant saver rubber mats.
When I picked up the car the air bag light was constantly on - why didn't they notice this during the initial servicing. The car was very dusty even in the dark, but by the morning it didn't matter any more. I switched the computer to Litres and kph. I have the infamous amplifier and so over the next few days I will be testing various CDs and then when I find the right one I will compare it to the cheaper sound system found in other Impalas.
The heated seats are great it was 10 degrees F here tonight = around -7 C. The steering is very responsive, more so than the Lumina LTZ which BTW has the same tires as the LS.
Sorry for the long post, but having a new car makes one want to share. Regards and happy New Year.
It seems I cannot paste the picture please let me know how to get a .bmp or .jpg into a post. Thanks
Frank
(My apoligies if I've posted this more than once - I've got a bad connection and can't get things to go through well tonight.)
On another note, I've read that there are 2 key problems that people point out about the 2000/2001 impalas:
1) something about the radio amp?
2) Aluminum engine cradle problems?
Can someone please explain what sounds or what to look for in order to find these problems?? My car was made in 04/00.
lacks a clear coat and that's why it looks different.
IMPALA RADIO forum has all the info on the amp problem.
History, development, instructions, bypasser comments.
BYPASS instructions are reposted here in IMPALA XI at
#303 and #312 - if the numbers haven't changed.
As far as the interior is concerned, my only gripes with the Impala have been the 'chintzy' and cheap glove box latch assembly (Rattle madness)and the underdash black plastic panels (On both driver and passenger side)that house the footlights...these are a prime example of GM's cheapness (And therefore bad reputation)when it comes to screwing interior components the way they should be. If you bent down there, notice that these plastic panels are hold by two very flimsy and useless plastic clips....the rest of the panel is completely loose!!, nothing holds it and is prone to rattle and/or pop out of place completely on top of your ankles. I was amazed when I saw this...I couldn't believe it! It looks like they ran out of budget money to finish and hold these panels properly in place. GM seems to 'penny-pinch' when it comes to put a stronger, better quality glove box latch or a few cheap screws or fasteners to hold some under dash plastic panels (By the way I like them but if they only were properly fastened).
The center console (For Impala LS and base models with front bucket seats)has also a tendency to rattle and creak overtime. Fortunately, GM spent some extra $$$ to add 8 visible screws (6 7mm screws and 2 10mm screws)to hold the entire center console assembly in place. Make sure you re-torque these screws every six months to keep the console nice and firmly in place and also add some WD-40 or other lubricant to the plastic joints to minimize squeaks due to 'plastic against plastic' rubbing noises. There are two 7mm 'hex' screws on each side right at the console joint directly below the center dashboard at the height of the accelerator pedal and the other six screws are located inside the console storage compartment. To gain access to these screws (4 7mm and 2 10mm hex screws)simply remove the coin holder (Carefully)and then the rubber 'mat' at the bottom of the compartment..and voila! there you have your screws! You'll need a ratchet drive tool specially made for very tight spaces. There are 2 7mm screws located right under the cup holder cavity and are very tricky to get at unless you have a small ratchet drive tool.
As a 'funny' side note, if you look under the console compartment rubber mat you'll see the part inscription 'TEO'...I was cracking up...too much of a coincedence!
The dashboard is very well assembled and haven't had any rattles or squeaks coming from this area. It appears to be that the "Magbeam" bar (The Magnesium structure that runs the width of the car and holds the entire dashboard assembly) to work wonders and at least ensures good stiffness and torsional rigidity for the life of the car. The plastic trim that holds the headliner (Around the roof pillars, A, B, and C) is kind of cheesy as well and the adhesive that holds the plastic against the headliner fabric seems to be very sensitive to temperature changes. I just have a couple of spots where you can see that the factory adhesive is giving up....if anyone knows about a good automotive glue for this purpose I would really appreciate any suggestions (Not a biggie but want to prevent gaps between the headliner and the roof pillar plastic trim)
As for the rest of the interior, the car is reasonably very well put together and good fit and finish. The door panels are very sturdy and they don't have the unpleasant "Breath in and out" effect when raising or lowering the windows as noted in many current domestic and foreign cars.
GM needs to fire some 'bean counters' and start to spend the extra $$$ to better bolt their interiors together...the Impala is a much better "GM" product no doubt about it, but they have to do better in this area if they want to regain lost market share...just my opinion.
The Impala is a great car and if properly cared for you can squeeze as many as 200K+ out of it. I have enjoy this car far much more than all my rather stirile and 'boring' ex-Honda and Acura products.
Hunter39:: I would appreciate if you can send me a pic or a diagram of the screw placement to hold the black plastic panels under the dash. I need to make sure about the correct placement of the holes that I need to drill to add the screws and prevent damaging some under dash component in the process.
Happy new year to all and Happy new Millinium (Now it is for real! The 21st Century!!!)
, no skipping cds or anything like that. The only major difference I've noticed with this unit is that I need to put the volume up to about 1/2 before the sound is good. On my other car (97' Taurus LX) I only need to crank the volume on the 'mach audio' system 1/4 of the way.
Another issue about the Impala I've noticed is the engine mount body welds? What is that about? What production period does this problem occur?
Did they resolve the problem yet?
Shamino
Anyway, there is not a safety issue involved as there is not hard core proof or evidence of a safety issue because of this problem.
Go to the beginning of this "Impala XI" topic and locate the post (Or got to the Maint/repair forum and locate the "Impala Popping noises" topic for the remedy and part numbers for the cradle bushings.
Found cradle mounts loose, insulators allowing exessive movement :
Correction: Replace insulators, ( 8 all together )
Qty Part # Description
2 10402880 Insulator 9.023
2 10402881 Insulator 9.023
2 10402882 Insulator 9.023
2 10402883 Insulator 9.023
One other thing that I have heard people complain about that I had also was the blower making a high pitched noise when set on lower speeds. I took mine out, turned upside down and put WD40 on the bottom off the motor shaft and let it sit for a few hours. Put back in car and 6 months later, no high pitched noise yet, . Dealership probably would of replaced it, sometimes you just have to do it yourself, .
To post a message, you must first Login."
Also noticed the problem with the headliner staying attached around the sunroof. Looks like it needs some new adhesive, something that will bond and stay stuck in hot and cold weather.
Traction control has worked great the past few weeks. It never snows much in Oklahoma, but it sure has this year. The car is sound, mechanically, and will get its first oil change this weekend at about 2500 miles.
doesn't it???
My car turns 1 year in my garage next week. No problems, but I'm starting to
hear the DIC (driver's information center) and rearview mirror rattle. Just slightly
but it might bug me enough to take it in with in the next few months.
Hope everyone had a great new year's eve and no one was held up by gun point
at their favorite bar.... Just joking Don.
Cookie.
Your insights on the impala have been very helpful!!! I never paid much attention to the headliner and the trim coming loose until I read the previous posts!!!
On my car, the trim in the right rear near the window is loose. As well, part of the trim on the pillar on the driver side is starting to come off a little bit.
I am not sure whether the liner on the sunroof is suppose to stick right up there?? Or is it on purpose they have a bit of a gap between the base of the sunroof and the liner? I know the question seems like a stupid one..but I've never had a sunroof in a car until my Impala.
If I bring it into a dealer, will they fix it free of charge?? I just have about 12000km on the car.
I just don't understand why GM would do cost cutting on the fine details that make the driving experience that much better!
On a completely different topic, I was wondering why automotive journalist almost always rate Japanese or other imports cars as higher quality and better in every category?? Seems like these guys always find the slightest faults in a North American car, while Japanese cars always seem to be "perfect."
One last question I can think of at the moment...anyone know whether you can order the police package upgrades (minus the flashing lights on the roof) for our civilian impalas??
Cobra
Right now my only problem areas are the 'joint pieces' that are coming off slowly (The piece that joins the upper B-center pillar trim and the plastic extension that runs on top of the door against the headliner and then extends into the forward A-pillar trim). I have the problem on the front driver's side and the rear right door joint piece. I think the factory adhesive is either very weak or they don't put enough of it to join and hold these trim pieces together. Anyway another example were GM prefers not to spend the extra penny for better glue or trim. Anyway, I'll put the glue in the morning and I'll let you know on the results.
Unfortunately, I don't think you can buy an Impala with the Police Package. As far as the engine goes, the 3800 V-6 is the same exact powerplant on both Civilian and Police version, so no extra benefit there. The transmission, steering gear and suspension are beefier for the abuse these cars must endure. Perhaps at some point the 9C1 package will be available on civilian cars...but I don't care for it. Give me a 2003 5.7L V-8 Impala SS instead!
out and buy a new (unique) driver tho... my across the street neighbor has every
tool in the book. But he'd have what I need.
Thanks for the tip!
"Ideal for bonding and minor repairs of Vinyl molding, interior trim, plastic and metal ornaments"
My Impala LS doesn't have the sunroof, so I am not familiar with the way the headliner attaches to the edge of the roof's opening. Non-sunroof equipped Impalas haven't had any headliner related problems as sunroof fitted ones appear to do. However, I think the 3M glue will work in re-attaching those Velcro strips back in place with no problems. It's worth a shot (Only $3.99 for the 1oz tube) to try to make the repair yourself as dealers are not very reliable (Or careful enough) when it comes to minor interior trim repairs.
The good thing about this glue is that it is resistant to heat, water, vibration and fuels so it makes it adequate for interior/exterior applications such as these.
Don't worry about making a mess since the adhesive is clear, dries clear and only requires a thin coat to bond (If you put a thick coat of glue it will just weaken the bond creating a glue mess). Give yourself plenty of time to perform the repair to minimize the chances of messing the headliner fabric with glue.
Last, keep in mind as Platour stated, that these adhesives are Temperature Sensitive. If you try to repair your headliner on 10F weather, the glue will not cure properly or at all. If you have a heated garage and can manage to set the ambient temperature above 70F, then you should be able to do it with no problems. I have never lived in "Snow Country" so to me the idea of copying on a daily basis with freezing temperatures is as foreign as the Chinese language (I love snow just for skiing!).
Anyway, our current temp here in Miami is around 57F is still to cold (Based on tropical weather standards)for me to go out and put the adhesive but later in the day the Temp is expected to rise to 70F and with the sunny, clear skies, it will be just perfect to do it.
Tonight the temp will drop to around 42F which is freezing cold for us (We have already broken 50 year old records just this week alone), so you guys up there must be having "Fun" dealing with the artic 'blizzards' and power outages.
I'll let you know how the 3M adhesive works.
Thanks for any help you can provide.
I have a set of mudflaps to put on when it gets warm enough to wash all the slush and snow out of the wheel wells. I tried a dry fit of them last night, but there was too much snow under there to get a good idea of how they fit. It appeared as though they would fit my 2001 with no modification, but until it is clean and dry under there, it is hard to tell. I bought them from gmpartsdirect.com, I can not remember the exact price, but it was less than $27 each, including shipping if my memory is right. Anyone looking for mudflaps might want to check there, they will probably beat dealer prices. Wish the weather would improve so I could get them on the car already.
This has been a lousy winter already. We have had 3 snow/sleet/ice storms in 3 weeks this December. Usually the snow does not last and melts away in a day or two, but the temperatures have been about 15 degrees below normal and it has stayed on the ground. This is only my second Oklahoma winter, and the worst part about it is that they do not have the equipment to take care of the roads after a snowfall, so the whole area is crippled. I spent 40 years in Iowa, and have heard from family of their lousy winter, a record of 32 inches of snow in December and a new record low for average temperature of 13 degrees, and just to make Christmas memorable for them, a low of –18 on Christmas day. I sure do not miss that stuff anymore, this little nuisance snow we get is bad enough.
when I accelerate at speeds from zero to 20 mph. Since the car takes off with such a
jolt, it actually makes it difficult for me to have a smooth ride when driving local...with
many starts and stops. Stops and starts can be smooth in a vehicle....but I have not succeeded
at this kind of control in the impala. I have been driving for 20 years and am a little bit frustrated..
Does anyone know if the accelerator can be adjusted in this vehicle (in a manner that
would allow some softness in low speed acceleration)?
I may also consider some modification to the brake as well....as it would be nice to have
these 2 key items be in sync in terms of their responsiveness to pressure. They seem very
far apart in terms of how you apply pressure to them...and how they respond.
Traction control on the Impala has proven to be very beneficial for the limited use I've had of it here this winter; my driveway sits at about a 30º angle (sloping away from the house), and so far I've been able to make it up and in the garage when it was covered with snow. I didn't risk it when it was pure ice, though - didn't want to take the chance.
