Found an LS cluster on ebay
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1833569668
By design?
Hey! I can be a GM dealer service advisor!
The car was pulling to the right and I was getting a slight pulsating sound when braking.
Also there was a vibration under the car.
The tires were making a wop wop sound too.
The alignment was way off and they did a rear alignment also.
The tires are damaged from the bad alignment and nothing can be done until I replace them.
The rotors were slightly out of round and were turned. If it doesn't help I will get new ones.
One of the baffles is loose in the muffler and was causing the vibrating sound, They have ordered a new muffler.
Anybody heard of that one before?
Tire air pressure should be checked for safety and also to ensure tire durability at least twice a week. Air pressure should be checked with the tires cold or when the car has traveled less than 3 miles.
4 wheel tire aligment should be done whenever the steering wheel is off center or the car pulls either way at speed. It is also recommended to perform it once a year or every 12K miles.
The muffler problem is very unusual but it can happen. It is a good idea to have the dealer inspect the underside of the car on every oil change stop to prevent damage of that nature from taking place.
It sounds like your problems are more maintenance related than the fault of the car itself, IMO.
Unless you wrestle with the ignition, I don't see what could be causing it to fail on you so many times.
Not a common problem.
Garypen: Who are you?
Next week, I'm driving up to Dublin (Bay Area) to visit a friend whose daughter is graduating from high school. This will be my first long drive in my Impala.
Who or what is a TEO?
I Taught the purpose of this forum is to talk about cars and the Impala in general.
Geez!
Not to worry, I won't be back.
I surfed through tirerack.com yesterday, and looked at three tires:
Firestone Firehawk SH30
Yokohama AVS dB
Bridgestone Turanza Revo H
Any thoughts on any of these tires? I know the Yokos are supposed to be quiet, and from what I've read they're good tires. I'm not so concerned about snow use, but mainly want good handling, quiet tires that perform well on wet surfaces (which seems to be the biggest problem around here).
I truly believe that preventive maintenance saves a lot of money and headaches down the road. So $50 a year spent on an aligment seems like cheap insurance to me.
Unless there is an inherited and confirmed design problem on a car or serious defects in materials and workmanship, in my experience, most cars do not eat tires or frequently experience aligment problems unless that aspect of the vehicle's maintenance has been totally neglected.
A lot of people wash their cars on a weekly basis and perform timely oil changes, yet they barely check the tire's air pressure, let alone check the balancing, perform rotations or do aligments.
I agree with drivinisfun about maintenance on tires. I've had a lot of problems as of late with tires developing that "rump rump" bad wear pattern noise. I wasn't really careful about alignment, rotate and the like. I am now. I never did much for some small economy cars I've had and it didn't matter. Now that I've been driving bigger cars it seems to matter a lot more. Rotate them and keep things aligned. I'm a convert.
I hate tire noise!! It drives me crazy.
I think he thinks he is being clever.
Ignore it and keep doing what you are doing.
Teo was our resident impalaphile but is no longer posting here.
Whoever designed the airbox should be taken out and shot.
It took me 15 minutes because I was afraid I would break something. Needless to say it was a tight fit and I really had to pull the assembly back and push the the throttle body convolute hard to get the thing out of there. Putting the new one in wasn't much fun either.
Next time it will take 3-4 minutes.
Some shops here in the metro phoenix Az area will not charge you for the alignment if they do not put a wrench on the vehicle. Some, probably not many.
We had 46k miles on our 2000 LS when it went bye-bye and never had it on the alighmnent rack. Just near 40k miles on the OEM Goodyear tires with no unusual wear.
Ok since some folks feel an alignment is due yearly , how many of you have changed your fuel filter??
About every 25k miles is when i change the fuel filter.
Also....how many of you have checked the spare tire air pressure lately? Our spare usually lost 5 psi a month somehow.
I noticed unusually many Impala on the roads while being in NH. Much more, than I saw them around our city the last summer. Most of "NH" Impala were in LS trim. In CT I see more often the base models.
I even told my wife, that Impala LS must be good for mountain roads.
Aligned only when buying new tires, checked in between, always on spec and our little burg is pothole city.
Also, I replace fuel filters every 30,000 miles or about eight to ten months. Have done this for many, many years. Can't believe the manual has no recommendation. Service happy dealers can't be amused, especially when this change is a wise one. I bet many people don't even know there is such a thing as fuel filter!
I have never been big on rotating the tires until I got the LS. But I NEVER leave the center caps on - the techs would MAUL them - I leave that to my careful hands. Every 2 oil changes is when I rotate.
Have a safe and great trip.
I wouldn't leave those spark plugs in there for 100,000,000,000 miles, or whatever they rcommmend, either. Every other year, at the most.
Don't forget your oxygen sensor(s) as well. I'd replace them at 30K miles.
Others want everybody to agree with them, and find it insulting, or even take it extrememly personally if someone were to disagree with them. How boring that must be. I also don't understand it.
The former take pride in their individuality and uniqueness. The latter take joy in being part of a group of like-minded individuals. I'm proud to be the former. I'll bet most here are too.
Prime example is the last oil change. Simple lube job turned into cleaning injectors and throttle bodies because of carbon.. how many have proactively had that done??? Exactly.
Well, I said before that I didn't notice a difference in the perofrmance since the cleaning, but I lied. Much better throttle response and torque is like the day she rolled off the lot.
Scheduled maintenance just doesn't cut it if you want the Impala to be healthy.
Spark plugs??? O2 sensors??? There are spark plugs in them thar engines???? Jeez, gotta refer to the manual.
cheers!
BG also makes throttle body and injector cleaners that spray before and after the throttle body, respectively.
BG products are generally only available from shops that use the products, not retail from auto parts stores. Perhaps Night Owl knows of an online supplier?
glad to have you on the board drivin'.. unfortunately, sarcasm is taken as malicious conduct in your eyes - I will try to use it sparingly.
DOH! Impala....
I appreciate the welcome.
keep the discussions going...
IMPALA
http://money.cnn.com/2002/06/06/news/companies/gm_incentives.reut/index.htm
Were Impalas flying out the dealer lots?
Why else offer retail consumer incentives?
However, car sales fell substantially in the spring, after GM reduced rebates from $2502 to $2000. Possible, it affected even Impala.
Additionally, GM coordinates pricing of different W-body cars.
You have to be really careful with the sarcasm online. Internet message boards (and e-mail for that matter) lacks the non-verbal cues (body language, tone of voice, etc) and it is easy to misinterprate messages. I can see how drivinisfun thought he/she got blindsided with gary's response. Driving didn't know the history behind Teo and gary's *ahem* quick wit.
