THANKS!
Thanks for any input.
Best Regards,
Shipo
Thanks in advance for any help.
the dealer said it is an electric problem he has been trying for a week and now he has sent the diagnostic test to Germany as he has no idea to what is happening
any one had similar issues
See if any of this info helps:
The hook needs to be pushed down but be careful, it is easy to break it. I believe they make repair kits that the dealer can sell you if you need to repair the broken hook.
http://www.my330i.com/mod2.php
DL
DL
For the last several days I've been relying more on the autostick to try and increase my mileage, and also watching more of that little gauge under the tachometer (is that right?). In the drive mode, it seems more under stress. I try to keep it in the 5th gear, as much as possible. Now, I'm getting a reading about 21.5 city driving. Am I making progress, or am I just fooling myself? Can't stand having to fill up the gas tank so much.
New problem: I went to wash the car today. I asked if someone could check the tire pressure, because it seemed a little bumpy. Well for one, the $30 logo theft-deterrant valve caps fell off somewhere.
Second thing and most importantly -- the guy noticed two large bubbles in the right front sidewall. I didn't hit any curb on that side. He said it could burst on the road, if I wasn't real careful. I recognize that. The dealership was closed by the time I drove home.... I have a big appointment on Monday. Don't know what to do.
Sears tell me a Continental 205/50 R17/ 93V rated tire costs $200!!! They don't carry them in stock.
I don't think I want to get another Conti. I went to tire rack to read the reviews, and noticed that other bmw people have had bubbles in the sidewall. Someone told me this evening, I might even be able to have the tire replaced by the manufacturer. BMW Assist asked me whether I hit a curb....
The tire pressure was 35 pounds. I think one of the dealerships added a little too much air to all four tires, anyway. I usually keep them at about 33. On the other hand, I know it can be tough to really know unless it's dead cold. I can't quite do this myself, though.
I guess the only thing I might be able to do is find a tire store open tomorrow that might deal with Continentals and see if they'll take care of the tire? Or, should or could I just replace it with something else that's comparable, but less.
Gosh, I can't imagine having to spend so much on a new tire when the car only has about 15,900 miles. I only put about 3, or so thousand miles on it, since I got it.
Thanks!!!
I checked and the BMW site claims 19 mpg city and 26 for highway for a 325xi with automatic transmission. So your 17 mpg are in the ballpark of the "couple of miles" below EPA claimed value. You talk "5th gear" and then drive mode; I'm assuming your lil' red wagon is automatic. No, you are not fooling yourself by looking at your mpg gauge (of course, without distracting from looking the road).
On the tire issue I 'd suggest remove your questionable tire with bubbles and replace it with the spare. That'll give you peace through your hectic monday. Then check your paperwork to see if you bought a road hazard warranty than you could enforce through your dealer or through the tire manufacturer. Sometimes one signs a lot of documents without realizing the value of them. Even without it, approach a Continental tire distributor and bring the tire. Explain that you did not curb the tire (er..could it had been at the carwash?). I have read in this forum that complaints against tire manufacturers are difficult to win -not impossible-, they seem to apply too many loopholes. My opinion is they make the claim process so cumbersome that seems designed to wear you off. Personally, I had to cancel a road hazard warranty after I discovered too many fine print gotchas... BTW last I checked your Continental 205/50R17/93V tire lists for $109 at the Tire Rack,plus shipping & handling. If all else fails, you may end up having to order your tire.
As far as your stem valve caps, I also have the ones with the BMW logo. I tight them with a plier so no one can remove them manually (a.k.a. steal). These caps are important, try to replace them before dirt clogs your stem valves. I check my air pressure only once a week, on a sat or sun morning, like you say, with the tires cold. I bought a little air tank that I fill for free at any tire shop (Firestone, Walmart, etc,). If you haven't used your jack be careful. BMW jacks are famous for not being quite stable. Mine collapsed the only time I had to use it. (grrr..) I 'd suggest you either call Assist or take it to a gas station to avoid yourself the effort. Good luck.
1) Fill up.. just until pump shuts off automatically..
2) Reset trip odomoter to zero
3) At next fill up, repeat 1), then note
mileage on trip odometer and gallons of fuel purchased.
4) Divide mileage by gallons of fuel.
You can't estimate... I have a car with a 15.3 gallon tank, that never takes more than 12.5 gallons..
You live in New Jersey, right? They won't even trust you to pump your own gas, so I know this is all new to you...lol
Good luck,
kyfdx
I think the only problem is the calculation method (Call me Kreskin).
THANKS AGAIN!
Tony
Thanks again!
TSL
Nick
Dee
But, you aren't bugging us..
I spent the entire day looking for a continental tire for the wagon, which has the "sport" package. Gosh, I wish I never got involved with low-profile tires. Not only are these babies expensive, but they're very, very tough to find.
Some dealers of Continental won't include road hazard insurance, because they know about the blistering in the sidewalls over little bumps and potholes.
Continental won't cover the tire, despite the fact I've only had it for about 3,000 miles. I took it to one of their dealers, and it was claimed that I must have hit a pothole. However, I was driving on the tire for 2 days, before I could get it checked out.
In any case, I've looked online about the tires. I'm disappointed with Tire Rack. By the time you're finished, it's just about the same as a BMW dealer.
If I go with 2 tires, instead of 1, with an AWD, can I get away with a different maker? Someone mentioned getting two Goodyear Eagles, but just two cost $440! I hear that they are better tires.
Believe it, or not I've found only one place that is a chain. They only have one of these tires in the entire state!!!
I hear the conti's are on backorder. I was thinking that I may want to switch over to a better tire, by this point, but at the most, I could only really afford 2, and that in and of itself, would be a stretch.
Thanks much for your thoughts!
Cargal
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33716&item=7963070285&rd- =1
My son has a 318ti of the same year. He received a letter from BMWNA about two years ago telling him that there was a few cars with premature demise of the cat converter, so they extended the coverage for 8 years and 100,000 miles. Since the engines used in both ti and i models are the same, you may be covered as well,
if your car's mileage is within that limit.
I was actually quite impressed with BMW's taking the responsibility to extend the warranty even we knew or heard nothing of the problem.
Does anyone knows if it is OK to got to 225/50/16 instead?
The first time, the car had 49K miles and they replaced a seat cushion sensor, under warranty.
The second time, the car had 51K miles and they said that the resistance is set too high and they have to replace a wiring harness at a cost of $500!
As they reset the light and I forgot about this, I didn't get the work done (the part had to be special ordered).
Now, the car has 53K miles and the light just came on yesterday.
My question is-- should the dealer take care of this for free since I initially brought it in under warranty? If they try to push me to pay out of my pocket, do I have any recourse with BMWNA?
As a last resort, is this something that an independent shop can do?
I'm a bit skeptical that the seat belt cushion was at fault to begin with.
