I have a 2000 BMW 323i, stick, sport pkg. My advice to you: BUY TWO! That's how much I love the car. I was an Acura driver before, but the German engineering can't be beat. I have 26k mi on mine, and all I've done is change the oil at 15k as prescribed. No rattles, no problems. The very best car I have ever driven.
My suggestion: get the 325i with a sport pkg - you will get great seats, sport steering wheel, and very handsome alloy wheels. The suspension upgrade is great too - sporty, but never too rough. I like your idea of tannin red - should look great with silver. I have sand interior with steel blue and am very happy - I wanted to get away from the dark black interior.
You may consider the 330i with more power, but for the price the 325i can't be beat.
Don't be fooled by the glitzy bells and whistles of the Lexus. It is a good car, but I truly feel that BMW will deliver the day to day driving experience that will keep you smiling.
Good luck. No, I don't work for BMW - I'm in investments.
Greg
Is the red leather you have called tanin? I didn't realized it was that bright of a red. I just ordered a 330Ci with tanin leather. The brochure had it as a much darker red. Not that I'm not happy with my choice but this make my 330 even more flashier than I had first anticipated Yeah!
Any input woudl be welcomed.
Thanks for giving me the encouragement I needed to make me order the 325i. After seeing the photos of the red leather interior of Jeff's car, I'm definitely going to go with the red. I'm going to place my order tomorrow or Tuesday -- and I'm also going with Greg's suggestion of the sport package.
Thanks again to everyone who posts messages on this board -- I'm learning a lot!
By the way, Happy Mother's Day to any of you Moms out there!
Chloe
You can also ask some real bmw mechanic what's going on (bimmer.org, unofficialbmw.com forums); I'm just speaking from volvo experience.
Red interior is somewhat less desirable, so if you're buying, you'll be loosing some bucks when you decide to sell. If you plan on selling like 12 years from now it won't make much difference, but if you'll be selling in 4 years, that's about 1000$ less than a black interior car. Of course, if you're leasing, it doesn't matter at all
he's not going to be able to see oil smoke at that rate of burn... *maybe* at startup, but unlikely, because so much other *gunk* is coming out of the pipe then... so while your suggestion of how to "look for" signs of burning oil is a good one, i think in this case it would be along the lines of looking for a needle in a haystack....
3/4 qt every 4000 miles is well within spec... he doesn't have a snowballs chance in a very warm spot of getting a drivetrain replacement...
also, from a bmw perspective, it's recommended that you don't sit there and let your car warm up... fire it up, go on your way... if it's *real cold*, it's probably not a bad idea to let it run a few seconds to let the oil get circulating (the vanos in mine sounds like a coffee can of rocks on startup when it's under freezing )....
-Chris
shiftright the host
Anyone have any experience with what breaks and how much it costs to fix for a BMW this old?
What is the actual sensor mechanism that governs this? Is there any point even checking the oil level manually?
Also, what about other things like brake wear? Normally that will be taken care of at the service interval, but I am reluctant to go 17,000 miles without the BMW mechanics even looking at the car.
I'd appreciate any advice here, and also any comments from anyone who has had servicing done ahead of schedule (and paid for it) and whether the servicing garage said that it was just as well the servicing was done.
Regards
Best Regards,
Shipo
but demo had 8,000+ miles on it (i guess thats considered used...)
otherwise how has you experience been??? im thinking of 330Xi as a commute car and for new england winter driving as well...
Thank you very much for your swift replies and information.
Much appreciated.
Regards
1. In the 3-series with the manual transmission, is there a fix for the rear "clunking" noise when the clutch is disengaged?
Also, I have this annoying problem with the front brakes that is noticeable when the brake pedal is tapped abruptly. The steering wheel will jerk to one side, which can be felt by the driver and seen by anyone watching the steering wheel. I took it to the dealership and a technician was able to reproduce it; however, the dealership mentioned that BMW is aware of the problem and has no way of fixing it because a resolution would interfere with the DSC system. Seems pretty messed up, huh? Personally, I think it is a warped rotor (some pulsation in the steering wheel) or a stuck brake pad (may explain why the steering wheel would jerk to one side if one pad is partially engaged). For a car that has 7K miles, the rotor should not be warped!!
2. So, by second question is: Is there a fix for the brake/steering wheel problem?
Any response pertaining to either of these questions would be greatly appreciated. Thanks. Sorry about posting it again-->spell check changed a few words.
Only one problem though. I have just passed approx 1800 miles of fun and noticed a slight change in performance. It seems not to have the same pep as it did just 2 days ago. Not bad, no obvious misses at idle or at speed, in fact hardly noticeable, but I can tell. This wasn't a new tank of gas or right after any change of anything. I filled up again anyway (with premium of course) but no change. The quick response that I felt as soon as the accelerator was touched now seems uninspired. Up 'til now, this car coaxed me to drive fast. Now it feels like "it" needs to be coaxed. I have contacted the dealer who said to bring it by for a test drive with a maintenance tech. I have a feeling that he will say that it seems normal to him. Does anyone have a clue? Help, I miss my baby!
Chip
I'll keep you posted.
Best Regards,
Shipo
Overall, I am satisfied with job that they did; however, the technician managed to knick the rims again!! Well, it looks as if I will have to take it back to the dealer for more rim touch-up around the area where the bolts go. Well, the service manager had offered to send the rims back to get it refinished after the incident occurred the first time after a rotation and balance. However I figured that as long as I am under the maintanence program, the same knicks will occur when the service department rotates and balances the rims next time, so getting them refinished will not get me anywhere.
DC
The clunk occurs when shifting from Park to Reverse. It doesn't happen all the time - 60%.
I took it to the dealer two times.
The first time they did agree that the sound is weird and that they can't fix it. They told that they'll contact BMW and get a specialist for fixing it. I never heard from them or BMW.
Then I filed a complaint from www.bmwusa.com
They asked the dealer to schedule another check up
for the car. This time they just refused to
acknowledge the problem. They said that all the
325s make that sound and that BMW states that it is a normal behavior of the car.
Have any of you guys ever faced this problem?
Has anyone been given a successful remedy for this noise? Please email me with the same.
madhu_nair@hotmail.com
Thanks in advance for any advice.
Madhu
T.B.C....
2 beats per second (like a whua, whua,whua whua)
Subtle at first but very annoying when highway cruising at about 80 in 5th gear. Can't get away from that RPM range there. Dissapears when below or above that range. My wife even noticed it.
Help!
Can anyone objectively compare BMW and VW from a build-quality perspective, and are there many lemon Bimmers? Thanks for the opinions.
Clearly the engineers at BMW were trying to convey some information to the operator by displaying "CodE", but what? There is no reference to this diagnostic message in the owner's manual. I realize that I will have to take the car in but I would appreciate some heads up as far as what to expect.
A lot of little things wore out in the car including the driver belt buckle which I just replaced, but the engine is still doing just fine and never needed work. I has taken a litre of the recommended oil 10w50 every 3800 km for as long as I can remember, less when I was using synthetic oil.
My Passat was one of the best cars I had ever owned, having said that, it was not without some initial problems. In the first year I had to have the following items replace under warranty:
- 3 fog lights (heat stress cracks)
- 1 right rear power window motor
- 1 rear window defogger switch
- 1 instrument cluster
During the life of the car (>80K miles) I had to replace the following items at my expense:
- 1 fog light (heat stress cracks)
- 1 battery (it exploded, what a mess)
- 2 sets of rear wheel bearings (one per side)
Given the fact that I drove those miles mostly in and around NYC which has some of the nastiest pot holes this side of the third world, and that the Passat never developed any unscheduled squeaks or other noises, I would say that the structure of the car was well built.
I now have about 27K miles on my 328i and have only replaced one little tail light bulb on each side. I could have had these done under warranty, but the whopping $4.00 it cost me to buy the bulbs my self saved me from a trip to the dealer (not that my dealer is bad, I just have a very tight schedule).
To summarize, I found that the VW was very good, while the BMW is nearly perfect.
Best Regards,
Shipo
changed the gas, new intank fuel pump, new fuel pressure regulator. the temp sensor, oxygen sensor and coil read ok according to specs. (i even substituted the temp 2 sensor with a 400ohm resistor , normal at 175 +degrees. no change today the 4th time it now only starts but runs rough and smokes black. only able to idle not drive now. is the ECU (the brain) the problem?
airflow sensor and speed sensor would not act like this. i have good spark. fuel pump pressure normal ~34 psi.
i am usually good with changing and reading the specs on my cars. HELP please.
I currently own a 2001 E46 325i manual with a sport package. I have never driven anything as fun as this. It has about 8,000 miles on it. I have already replaced a fog lamp and had to have the break master cylinder replaced as an internal seal malfunctioned. Other than that, it is very stout.
From my perspective, both vehicles are great. It all boils down to your personal preference. I personally can't stand front wheel drive. If I enjoyed front wheel drive, I probably would have gone with the Passat (I did test drive one and it was fun). It definitely has much more value for the buck. You can pick up a fully loaded Passat for what I paid for my "stripper". Now, if rear wheel drive is your thing, like it is for me, the BMW is the only way to go. This car is absolutely on rails. It does tend to have more over steer than I would have expected for a car like this, but I am very glad I bought it.
Finally, I do think the Passat is of a higher over quality than the rest of the line. It is the flagship and I think VW goes to extra measures to ensure it is of high quality.
In the end, i don't think you can go wrong with either car. Best of luck!
In the end, I don't think you can go wrong with either car. Best of luck!
I have described this to the service advisor where I leased the car and he has never heard of this problem before. He said that maybe the cars software needs to be reset.
I hope someone can give me some advice. -Thanks in advance,
