BMW 3-Series Maintenance and Repair
17172747677105
  • rhmassrhmass Member Posts: 263
    Thanks, kyfdx and OW, you have confirmed my understanding of the replacement for pairs only. When this dealer starts to do so, I don't have a good feeling as to their honesty. Is there any visual ways to realize the shocks indeed need replacement. After all, it has only 45,000 miles. Can one see the cv boot to determine it is leaking?
    Again thanks for the advice.
  • roadburnerroadburner Member Posts: 17,358
    I'd get a second opinion from a good independent. I've NEVER replaced the OEM shocks on a Bimmer prior to 100K. If you plan to keep the car a long time I'd go with Bilstein HDs- though you should really replace all four if you want to go that route. If you want a decent less expensive shock I'd consider Monroe; they offer a shock that's made in Europe and it has received good reviews from several E46 owners.
    Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
  • circlewcirclew Member Posts: 8,666
    Any shop replacing only one shock is not to be trusted. Roadburner's suggestion to get a good independent shop is the best approach. Imagine one shock with 80K miles and one new one. Perfectly balanced suspension it is not. Doing it twice almost doubles the labor cost let alone your time.
    These are the type of establishments who bring you in twice and really do not replace anything (because it ain't broke) and charge you anyway. Wouldn't be surprised if he oiled up the shock housing and showed you it leaked!
    Need a new mechanic.
    OW
    OW
  • cristialexcristialex Member Posts: 1
    I need to replace the front control arms and bushings and the BMW dealer gave me an estimate of 1100$. I looked up the parts at various web sites and they go around 30-50$ per pair. It seems like a huuuuge difference...Any idea how much should it really cost?
    I checked some sites that sell OEM quality parts; assuming you own an E46, the control arms will run $130-$180 per side. The bushings will $82-$150 per pair. If you are a BMW CCA member many dealers and independent shops will offer 10%-20% discounts on parts and/or labor. Find a good independent BMW tech and you should be able to get the parts installed for under $600.
  • cct3cct3 Member Posts: 1
    Antifreeze reservoir is empty. Car ran hot briefly. I pour antifreeze mixture into reservoir and it seems to pour out the bottom. I cannot see the bottom of the tank. Does this seem to be a hose issue or the reservoir? I know nothing about this. Car has 100,000 miles
    I'd put my money on the expansion tank-AKA resevoir-being cracked. It's a common problem on sixes with 100K or more on the clock. It's a relatively cheap and easy fix. Just don't overheat the engine again- unless you want to R&R the head gasket(and possibly the cylinder head as well).
  • mikewesq1mikewesq1 Member Posts: 2
    I have a 2007 335i sedan. Yesterday I got an (alarming!) message along the lines of "Electric steering wheel lock. Do not turn off engine. Engine may not restart." In fact, though, when I did turn off the engine, it did restart (at least then). Anyone know what's going on with this?
  • kirkrkirkr Member Posts: 17
    I had the same thing happen on my 2006 325xi. It was a faulty sensor. I was always able to start the car until it was fixed. However, I did hold my breath each time.
    Kirk
    Thanks. In light of the car being able to start, that makes sense. I've gotten it to my dealer this AM and should know for sure later today.
  • manualguymanualguy Member Posts: 9
    I got the adaptive headlamps fixed last Friday. The service person said that this was unusual but understandable. The driver side headlamp apparently has to make more small motions than the passenger side . :confuse:
    I dont understand why that is the case. But, anyway, they installed a new headlamp unit and it is working fine now. I am trying to figure out if it better to use the automatic setting on the headlamp or not! I asked the service mgr the same question, and he said that leaving it in auto mode is better and this should not happen again.
    br
    manualguy
  • kyfdxkyfdx Moderator Posts: 237,116
    The driver's side lamp won't swivel as far to the left as the right side lamp, to avoid shining into the eyes of oncoming traffic on curves...
    If you don't leave it in automatic, then it won't swivel.. they are fixed forward..
    "If you don't leave it in automatic, then it won't swivel.. they are fixed forward."
    Well now, ain't that annoying. As I understand it, Xenon headlight assemblies have a lifespan that is calculated more by on/off cycles than hours of operation. With that in mind, I always kept my Xenons off of the "Automatic" setting as they had a tendency to turn on and off all too often (i.e. shady street, tunnel, overpass...). Hmmm, I suppose that means that I could simply switch them to "A" when I want them on.
    Best Regards,
    Shipo
    Of course, when you switch them to "A", you are turning them off and back on...
    I never use the auto setting... I don't seem to achieve any real-world advantages from the swiveling... and since our DRLs are activated, I don't have any need for the automatic part, either..
    When I need the lights, I turn them on.... When I stop, I turn them off.. just like the last 33 years... :)
    (my wife loves the auto setting... go figure)
    As Mr.Shiftright advised me, one time..
    "My front end seems to have a shimmy, and when I go over a bump, I hear a clunk."
    That will get them to check the front control arms and bushings...
  • canman1971canman1971 Member Posts: 61
    My car is going in tomorrow for a checkup because my warranty is about to expire. I'm at 47500 right now. Is there anything I should ask them to look into. I know they are going to do a whole "used" car inspection. (Brakes, suspension, fluids, etc...) But, I was wondering if there is anything special I should ask. They already told me they are doing a oil change. Thanks in advance.
  • bobcat2kbobcat2k Member Posts: 1
    I just got a 98 318i and noticed that when first starting out in the morning a noise, sort of a rumble, comes from around the right front. I actually sounds like something is rubbing the tire. As you go along the sound becomes less noticeable and eventually becomes only a hum. This hum is present only when you tweek the steering to the left while driving. If you slightly turn to the right it goes away completely. The hum continues even when the transmission is out of gear. The car tracks very straight and steady. Was thinking maybe RF wheel bearing, but what do I know? I am puzzled. Can anyone offer some help?
    Thanks for your time.
  • kominskykominsky Member Posts: 850
    Heed kyfdx's advice! Control arms are an expensive repair at the dealership. They replace the tie-rod and control arm as an assembly. I had one start "acting up" at around 49,500 miles and had to drive my wife's van for about a week to be sure I kept the milage under 50K so it would be covered.
    I just got word that they did the front and rear brakes, but nothing else required attention. Perhaps at around 49000 I'll go in and tell them the "shimmy" story. I had those replaced on my 2000 323i, so yeah, I know they are expensive.
    I posted earlier a few days ago that I took my 2002 325xi wagon in last Thursday for routine service (covered by my extended maintenance contract). I was told that both my rear shocks leaking and needed replacement and the cv boots leaking as well (not covered). When the service advisor told me that they only had one shock in stock and proposed to put one in and ordered the other, I started questioning his honesty and didn't authorize the repair. I brought up the fact shocks should be replaced by pair. He gave me some weak excuse such as to save me time for the next visit. The routine service performed included oil/filter change and front brake pad/rotor replacement (included). I didn't use the car until yesterday and felt the brake didn't seem to stop the car as quickly. I thought that might be due to the need for the new front brakes to "break in". Otherwise the car ran well. Then this morning when I started the car, the lights came on: brake, ABS, EML, service engine soon, and the symbol for stability control malfunction. I called the dealer and talked to the same advisor who previously had wanted to replace one shock at a time to tell him the issue. I thought there might be problem stemming from replacing the brake or flushing the brake fluid. He insisted there wouldn't be any connection between those those indicators which are controlled by computer modules and had nothing to do with the mechanical works of the brakes.
    I am bring the car in tomorrow and frankly with my recent experience, I had no confidence in this new dealership (they just bought out the old one). Particularly I have concern with its honesty. Can anyone of you come up with some hypotheses of this problem? The car is only at 45000 miles and have been always serviced by the dealership before. I have only driven 45 miles since the services performed. TIA.
  • dterriedterrie Member Posts: 7
    This is my first post. I own a 2007 328i Coupe (love it). Way back, owned 1980 528i. The car is for son.
    I've test-driven a 2000 323ci at a small used-car dealership. It has 97K miles. Steptronic, Sport and Premium, etc. Very clean inside and out. Tires in good shape. Engine smooth and responsive - compared better than expected. Tested alignment highway taking hands off wheel and car tracked straight. Handling on a fast run around highway exit ramp seemed good. However, going over a patch of rough pavement, the bumps felt harsher than I expected. I've checked enough forum posts to be aware of subframe issues, especially with coupes. The salesman says he does not have ownership / maintenance history on the car.
    He wants $13K. The KBB is $15,140.
    Should I pursue purchasing this car, if it checks out OK in an inspection?
    Is there a way to find out the car's history through the VIN?
    If I can't discover it's history, and the subframe, etc. checks out ok, are there still enough unknowns to make purchasing an extended warranty a good idea (not normally a fan of these)?
    In short, am I taking a big maintenance risk here, or should I be ok, if car checks out?
    I gotta tell ya, based upon the huge hue and cry regarding reverse gear failures in the E46 Steptronic 323i (et al.) models, there is absolutely no way I would drive one of those cars with only two pedals under the dash.
    Were I in your shoes I'd either be looking for a car with a 5-Speed or a 328i/328ci.
    Best Regards,
    Shipo
  • cobra10cobra10 Member Posts: 3
    hi i have bmw 2002 325i and i get the sensor but i dont not were is it
    Shipo,
    Thanks for responding. The dealer is offering a visual and a laser-based inspection of the subframe at least. As for the manual option, my son only knows automatic. My old 1980 528i was a manual and it sure was blast so drop it into 3rd at 60 and floor it on the highway - woohoo as they say.
    So the 328 did not have the reverse gear failure problem? Any feeling as to how likely this failure is on a car w 97K that's been checked out by a mechanic - any signs he might spot that are a 'tell' for this? Or am I just rolling the dice? Would this make buying an extended maintenance contract a must?
    Again, thanks.
    As I understand it, the 1999 and 2000 328i has a different automatic transmission than the 323i models, and as such, the vast majority of automatic transmission problems seem to be isolated to the cars with the smaller engine. Like I said before, there is absolutely no way I'd have a 323i with an automatic transmission.
    Were I in your shoes, I'd be teaching my son how to drive a stick or looking for either a 2000 328ci or a 2001 (or later) 325ci (I've not heard of any significant level of problems with either of these).
    Best Regards,
    Shipo
    My thirteen year old son will learn to drive my Wrangler stick this summer.
    Either that or I'll disown him.
    My (now) fourteen year old son learned the three-pedal dance last summer when he was thirteen. I'm thinking that's a great age to teach the left foot how to do something useful. ;)
    Best Regards,
    Shipo
  • gbrostekgbrostek Member Posts: 9
    You MUST find out if teh automatic transmission has ben replaced yet
    If no, you are within a year of a $5000 or more problem
    Reverse WILL fail on that car, and mine failed at 102,000 miles.
    Good Luck
    Gerry
    I am getting to the end of the warranty period on my 2006 325xi and, like Shipo, I don't believe in extended warranties. You rarely get your money's worth. I am having it picked up (my dealer does this for free since I live 100 miles away) and having the control arms and bushings checked. Is there anything else I should have them look at while it is in the shop?
    Thanks for any help.
    Kirk
  • widriver2widriver2 Member Posts: 36
    My 2002 BMW 325CI has not started 5 different times in the last three months. In three of those cases the car started 10 to 15 minutes later. Once it would not start for 2 days. After the second incident, I took it to the dealer and they could not find anything wrong with the vehicle, nor was there a code indicating a problem. Unfortunately it has happened a few times since. The power seems to work as radio and lights come on. When we we raised the front hood, the engine seemed to make a hiss when we tried to start it, but did not start to turn over at all.
    My car has 53,000 miles and I live in the upper midwest.
    Any ideas?
  • zico97zico97 Member Posts: 6
    Help! I purchased a 2006 BMW 330i and today I encountered a "Remote Control Not In Ignition" message on the navigation screen. The ke will not go in (just kicks it out), however, If I hold it in the car will start. I am very careful about removing the key properly (push in and then pull out). This is the first I have encountered this problem.
    Is this a computer issue, does it need to be reset :confuse: ???
    Thanks for your help in advance.
    You are still under warranty, I believe...either it needs to be reset or the sensor is bad.
    Take it to your local BMW dealer.
    OW
    Yes. Still under warranty. I will take it in to a BMW dealer...
    Thank you,
    Zico97
    widriver2, any response to your issue? I would be very curious to see what the possible issue was...
    Zico97
  • koimankoiman Member Posts: 12
    Does the compound need to be specifically for brakes, I have anti seize compound that specifies many uses including spline and clutch assemblies says its non hardening, non oxidizing , non corrosive non evaporative, no vibration, no loosening. Name of compound is Balkamp.
    I'd get the stuff specifically designed for brakes, if only because of the high temperatures the brake components see.
  • sunilbsunilb Member Posts: 407
    Just a guess, but maybe it's the battery...?
  • cooljc74cooljc74 Member Posts: 23
    When my LG phone was paired with the bluetooth, "Net Search" comes up.
    And it doesn't work when a call is made using bluetooth. FYI my LG phone worked fine before "Net Search" came up. On the screen, everything appears fine when it's compared with my other phone which is paired up.
    I tried to delete my LG and re-pair and "Net Serach" doesn't go away.
    Any thoughts?
    Reset bluetooth software? then how to reset? I haven't found add info in the manual either.
    2001 330Ci w/135K miles...
    My service engine soon light came on. I took the car to Autozone to have the code read. It came back with a lean condition in bank #2. The guy there told me that this code usually means one or more O2 sensors need replacing. Since BMW calls for O2 sensors to be replaced at 100K miles and mine are still the originals, I have no problem replacing them all and have already ordered them from Bavauto.com. However, the printout from AutoZone also lists MAF sensor as a possibility.
    Looking through the Bentley manual, there are codes specific for O2 sensors. My questions are:
    If the problem is really with the O2 sensors, why wouldn't the more specific code have come up?
    Would BMW shop's OBDII reader give a more specific code than a generic reader from AutoZone?
    Is there any other way to pinpoint exactly what the problem is when faced with a fairly vague reading?
    Again, based on the milage of the car and the lack of $$ put into fixing things so far, I have no issue shelling out the gappy to fix whatever, but on the flip side, I have no desire to spend my money unnecessarily either.
    The indie shop where I take my Jeep has a Snap On code reader and it couldn't trap the code that was throwing a CEL in my Mazdaspeed. If I were you I'd get a second opinion from a dealer or a good BMW indie shop. That said, if you are planning to hold on to the car for a while it sure wouldn't hurt to change out the O2 sensors.
    I didn't think so at first because it would start 10-20 minutes later and the lights and radio came on when it wouldn't start. However, I'm now noticing the fan making a strange noise as if it gets stronger then weaker while the car is running. I'm guessing that is battery/electrically related.
  • tnguyen74tnguyen74 Member Posts: 65
    I had a similar problem like yours and it turned out to be a faulty electronic key. The next time it happens immediately try your other remote key and if it cranks up. If not than it sounds like a starter issue.
    Excellent post! I never thought of that! I hope it helps this poster!
    OW
    Last night I popped the hood to check fluids and noticed that my oil filler cap was missing. I changed the oil 2 weekends ago, about 2 days before the service engine light came on.
    Initially I didn't put the two events together, but do you guys think that a missing oil cap could cause a lean condition? Something with the crankcase venting? I'm well beyond my automotive knowledge here and merely guessing... please be kind if I'm way off base! ;)
    Oh, btw, I'm not sure how yet, but I'm positive I will come up with a way to blame my wife for the missing filler cap. :)
    Yup, no doubt about it, a missing oil can can and most likely will cause a lean condition. Uhhh, does wifey know the storm that's headed her way. :blush:
    Best Regards,
    Shipo
    Nice... that's what I was hoping to hear. Thanks!
    As for the wife, I will not blame her to her face since she'll know it's a lie and likely attack. I just need something to tell the guys so I can retain my ~cool~ factor. :shades:
  • jodanjodan Member Posts: 4
    Hello Guys! I have been reading all the posting on this site and I'm very happy that I joined in because it keeps me informed about my car. I have a 325xi '04 with 61,000+ miles on it, I owned the car now and It will be 4 yrs this may '08. I am aware that my 4 yr-service included with my purchase is already done. This is my dilemma, I went to one of the dealership 7 months ago for a regular maintenance/check up as per my indicator on my computer on the dashboard. So the service specialist told me that my car is due for a 14 pt inspection/check and I ask him how much it is, he told me it's going to be $750 for the check, I was a little shock and I just opted for a change oil. I needed an advice for my next service appt due approx. 6 months if I really needed the major inspection or I can just find a good mechanic to check my car. I am planning to keep my car and so far no major problem experienced! Thanks !!!
  • killorhomekillorhome Member Posts: 13
    I have a 2001 325CI w/ 25K. Dealer diagnosed bad PCV & secondary pump light. Can't afford the $1500 the service dept wants to fix. I heard that you can "short out the light". My question: Anybody know how to "short-out" the lite or easy way to fix w/o taping over the light??
    I have a 2001 325CI. a steering angle sensor (part of traction control) is bad. My warranty won't fix (big suprise) says parts not related, Am I wrong? If so, where is the sensor so I can plug in a new one!
    If you're trying to beat emissions (not saying you are) that won't work because even with the light disconnected the problem will show up on the control station's computer. Otherwise, a little tape isn't a bad idea. You'd best be sure you know the actual problem, though, before you drive on .
