Check out the latest from the Edmunds Editorial Team
Have you recently used your tax refund (or are you planning on using your tax refund) toward the payment of a new or used vehicle? If so, a reporter would like to talk to you. Please reach out to [email protected] by Tuesday, March 19 and the Edmunds PR team may connect you with the journalist.
BMW 3-Series Maintenance and Repair
1169170171172173175»
  • tlw6tlw6 Posts: 15
    thanks for the reply, and it just showed my ignorance in these issues.
    to try to clarify what I said, when the car was towed to the (second) mechanic, he checked the pressures on 2 (or 3) cylinders that are closest to the radiator and 40 or 50 psi were shown on the meter. I don't know how the cylinders are numbered. I would hope that those are #1 and #2.
    when I called him after a few days, he said that "valves 3 – 6 are not closing." I don't know which are considered "#3" thru "#6." If #6 is closest to the radiator, then what he told me over the phone were not consistent with what I saw on his pressure gauge.
    How are the valves numbered? thanks in advance again.
  • chewy2chewy2 Posts: 19
    Might be best to find a shop that specializes in BMW. This might mean going to a dealer. If you live anywhere near Silver Spring, MD, try the namesake dealer - BMW of Silver Spring.
  • qbrozenqbrozen Posts: 25,339
    I can only think maybe he means they aren't seating properly. But, honestly, that's just an assumption based on a compression test. A bad head gasket or worn piston rings will also give low readings.
    '18 BMW 330xi; '67 Coronet R/T; '14 Town&Country Limited; '18 BMW X2. 47-car history and counting!
  • fourthbmwfourthbmw Posts: 9
    edited August 2013
    My 2013 335i has very black soot at the exhaust tail pipes. The dealer service said its OK. They said if anything was wrong there would be indicators and codes for review. However they couldn't explain what is causing it. It doesn't look good to me and some of my friends noticed it and said it has a rich mixture and can damage the engine or catalytic converter.
    I called BMW North America and I was told they only help with car features or personal issues and that I should go back to the dealer and have them check it out again. CATCH-22.
    Is there anyone who can verify ond/or explain what causes this black soot. Do I need to go to the dealer and check all the 335 exhaust pipes to see what colors the exhaust is, than if they are different than mine I am back to where I started. I am concerned because I am planning a drive to Colorado to see my son and do some sight seeing. (see America trip).
  • I have a 2013 320i with a strange problem. This has happened 3 times so I have finally discovered the pattern but not the cause: our church parking lot is under some major power lines. You can actually hear them buzzing when you walk under them. When I park in a certain place in the lot the elevation puts my car within 50 feet or so of the lines and when I start the car the radio will have lost all of its station presets. After a restart or 2 they will return. Is something not shielded properly or is it just the proximity to the lines? Anybody else ever have a problem like this?
  • 5539655396 Posts: 529
    I'm thinking it's haunted. May have to perform an exorcism. Seriously, you may be onto something, although it doesn't seem like that should do it if everything is properly grounded and shielded. I would think that RF would be more likely to affect it.
  • I had that problem and was told it was the ignition reduction shield and my radio went useless.
  • srs_49srs_49 Posts: 1,394
    It's very difficult to shield against 60 Hz interference in the scenario that was described - parked under or near a high voltage transmission line.
    In that situation the primary method of interference is magnetic coupling. To effectively shield against a 60 Hz magnetic filed you need a thick steel (greater than 0.1 inch) enclosure. Typical automotive sheet metal, .080 inches thick (guessing here), would only reduce the magnetic field strength by 90%.
  • xeyexeye Posts: 168
    I discovered some odd behavior this past weekend apparently caused by the Engine Start/Stop function in my 2013 335i xDrive. After a walk using my Droid Razr to listen to Pandora One via satellite using earbuds, I returned to my car and pressed the Engine Start/Stop button without the clutch depressed to go into Ready mode so the time display would illuminate. I did this while Pandora was still playing.
    When I pressed the button again to go to Off mode, Pandora instantly stopped playback! It was as if I had pushed the Pause button on the smartphone. I was able to repeat this behavior three times consistently. There was no wired connection between the smartphone and the car. The Bluetooth connection would probably have been established, though.
    What gives? Why would the Engine Start/Stop function be putting out a signal that would be picked up by the Droid Razr and interpreted by Pandora? Has anyone else experienced this phenomenon? I have been on Bluetooth calls when shutting down the engine with no interruption to the call.
    xeye
  • nyccarguynyccarguy Stamford, CTPosts: 12,914
    hey there xeye! Good to see yourself still hanging around. Tasman Green/Oyster 2011 335xi, right?
    Once you enter the car and turn it on (start button only, no clutch) the phone automatically pairs itself with the car. When you turn the car off, the pandora turns off too.
    The car knows when you are on the phone and that you might want to continue your conversation outside the car.
    2001 Prelude Type SH, 2015 Infiniti Q40 AWD, 2017 Honda Pilot Touring AWD
  • I stop using Pandora on my PC, as it screwed it up and I think that it's affecting your Droid somehow. Do you have a GSM or CDMA signal?
    Thanks for the feedback, all.
    I am, indeed, still around, but I am now in a 2013 Black Sapphire Metallic 335i xDrive Sport w/Leather Dakota Black/Red highlight. I went to the dealer in early May this year just to 'look around', and wound up driving out a few days later in the new ride. If you spot one of these with MA license 'STLTH', that might be me. The only items I miss are the H/K stereo and the parking sensors as I did not custom-order this one. About the only package this one doesn't have is the M 'lipstick'. The really REALLY nice thing is that I didn't have to wait, agonize and track the RORO all the way across the ocean for 8 weeks!
    Someone got a sweet Tasmin Green/Oyster CPO with about 30,000 miles!
    My wife traded in her 2008 328xi for a 2013 Fiat 500 Abarth, also great fun to drive. On start-up, it sounds like two Harleys strapped together! Our neighbors love us. Her license plate is 'LUIGEE'.
    I am very impressed by how BMW tweaked the car between the '11 and the '13. I was a little skeptical when they came out with the 3 lines, but someone put a lot of thought into the ergonomics of the newer version. Flipping the switch between Comfort and Sport with pressure on the GO pedal never ceases to bring on a big grin!
    On Monday, I will be taking the car in for service as I think I've lost half of the horn sound. It sounds more life a Nissan Versa than a BMW. It's embarrassing to honk the horn!
    Good to chat again. I will try to post a pic soon.
    xeye
    Nice ride! I'm sure your car is lightning fast.
    I am currently leasing a 2011 328xiA & love it. I've got a total of 30 months/50K miles to enjoy it. It goes back 9/22/2014. I have driven a new 328xi (base model, loaner car) and didn't particularly care for it. It sure was a lot faster than my Titanium Silver/Black 2011, but severely lacked the steering feedback & "buttoned down" handling I crave. I got my car in March of 2012 as a leftover with a subsidized lease & lots of cash incentives. The current body style is going to be out of my price range when my lease is up.
  • I wanted to replace my broken trunk lid for my e46 2001 station wagon trying to search also for how to video but so far nothing. maybe this forum can help me out. just purchace 1 online and their not cheap about $80 ouch! any help or advise will b much appreciated.
  • I am looking purchase a 2010 BMW 328i convertible with 47,032 miles. My real hesitation is the maintenance cost. What should I expect to spend every year. How often are non scheduled parts needing repair? Any advise as I look for a convertible?
    i was told once that the average maintenance cost is like $1500/year for bmw.
    Unless you cheat and find a good and reasonable repair shop. That is the ONLY reason I went back to European after owning a Saab and Audi many years ago. And, I bought used, contrary to the norm of bailing out before the warranty ends. The certicication just ended on our 08 528i w/50k and I'm waiting for my first and last expensive surprise. Also have a Z3 which is a much better fit for my comfort zone. Not so complicated. I don't need headlights that go up and down plus side to side. Just something more to go wrong and enhance dealer profit.
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaPosts: 63,843
    I think that estimate is about right for an out of warranty German car in good condition. Of course, that $1500 a year estimate has to be averaged out over a few years. Some years you're luckier than others. Also, this estimate does not include catastrophic failures, only maintenance and "expendables" that all cars need.
    Also, many owners find ways to cut costs--either by using a good independent repair shop, and also joining the BMW club (https://www.bmwcca.org/index) and taking advantage of member discounts as well as excellent repair and maintenance tips found in the DIY forums.
    Of course, you will find BMW owners here at Edmunds who are very helpful and easier to access than joining a club.
    MODERATOR --Need help with anything? Click on my name!
    Share Your Vehicle Reviews Here
  • kyfdxkyfdx Posts: 110,793
    My dealer runs an oil change special for $79 on my model, most of the time.. So, I try to take it in every 6 months... then, they come back with a list of what the car needs... and, I take that to my independent (all makes) and they save me about 30% over the dealer's quote..
    My dealer is very good.. My car was CPO, so they worked on it until it was 6 years old... they don't up-sell... so, if they say you need it, you need it, and my independent mechanic confirms it.. The dealer has so much more experience with my model car than a general independent could have, so it's nice having them scope out the problems. My independent is a very good, as well, so no issues having them do the work I request...
    It works for me.. I'd say about $150-$200 per month for repair and maintenance... on average...
  • My new 328i sedan trunk tail light lens continually pops out. Besides being pissed about this quality control issue on an expensive new car, the dealer has been unable to solve the problem. The dealer says they use an adhesive to secure the lens. I cannot see any adhesive on the repair. I have heard that this is an issue on the 2012-2103 F30s. Has anyone had this issue and what was done to fix the problem?
  • busirisbusiris Posts: 3,490
    I spend a fair amount of time on a couple of BMW-specific forums, but this is the fire case I've seen anything like your issue.
    I'm thinking you may have a dealer issue moreso than a BMW issue. I don't think BMW did anything radically different in the taillight lens dept. on the F30 than the E90 model.
  • I have a 2007 335i hard top convertible, 109K miles. The battery light was coming on so I took it to a local mechanic who does BMW service. He has good yelp reviews and I just moved here. He replaced the battery and "registered" it. As I drove off the lot I hear a noise I thought was an airplane overhead. 6 blocks later I realized it was my car and turned around. Before I got back the water light came on (temp was fine). When he opened the hood the auxiliary fan was blowing. He hooked up the diagnostic scanner and it gave a water pump indicator as well as several other indicators. After a long discussion he admitted the battery didn't need to be replaced but since that's what I asked for that's what he did. He agreed to put the old battery back in and try to figure out what's going on.
    I can't find anything on-line about what might be going on, but common sense, a decent knowledge of cars, and putting together some things he said is hinting at a couple of things. Could he have registered the battery wrong? Could he have used the wrong battery (there are 2 potential batteries for this model and I don't believe they are interchangeable)? Could either of these 2 things either be causing a false reading on the scan, or have messed up the electrical system? Has anyone had a situation where the battery was replaced and the electric water pump blew as a result? Any other ideas?
    i don't see a connection unless he blew a fuse somehow during installation. The 'wrong' battery would relate to size, not voltage. Or, if the car ran without sufficient coolant, it could damage the pump; or if the car's cooling system is not filled according to BMW procedure, that could damage the pump.
    A battery light would not necessarily warrant a battery replacement, so really, in hindsight, the car should have been scanned first, and codes extracted, and then the charging system checked, before anything else was done.
    hard to say what happened given the info you provided.
    I agree with MrShift. 12 volt car batteries are all the same voltage, and since registering the battery is done to tell the car's charging system the optimum charging characteristics, its doubtful a new battery by itself caused any issue.
    Frankly, I'd be a bit skeptical about any mechanic that would simply replace a battery without doing a load test first, if for no other reason than to prove the battery was bad rather than a fault in the charging system.
    So, personally, I'd have doubts in this shop's competency level, based upon your comments.
    As for your problem's cause, its difficult to say from the info provided. BMW water pumps seem to have a higher failure rate after around 75-80K miles, and many owners replace them around that benchmark mileage as a preventive measure.
