I took it to the mechanic and had a full diagnostic done. He checked coils, spark plugs and all the other problems that previous people has described and everything checked out okay. The car did not display any error codes and the service engine light never came on prior to taking the car to the shop. However, the mechanic did replace an air flow sensor and it seemed to run fine when I took it home yesterday. The mechanic also mentioned that there could be some carbon build up on the injectors and I should run some fuel cleaner in when filling up the car with gas for the next couple of fillings.
This morning, the engine was doing the same thing as it did prior to taking it in. I called him again and he told me to wait until the service engine light to come on and in the meantime put fuel cleaner (Techron by Chevron) in the with the gas for the next couple of stops. He also told me when he checked for codes, he resetted the computer and that I need to drive the car for a while so the computer had a chance to do a full cycle and be able to check everything to make the appropriate adjustments.....
Should I continue with his advice or take it somewhere else for a different opinion? Thanks!
So, I took it to the dealer that I bought it from yesterday and they changed reset some computer on it. They also said that since the chip was being changed I needed to buy a new battery for it. They also suggested that since it's almost time for the 60,000 mile check up that I should have the fuel injectors flushed. They said when the mechanic drove it it never stalled?
So, I agreed to have them do the work at a cost of $250. I picked up the car last night and drove it home. It stalled on me (3) times. I called them this morning and told them that I was still having problems so they asked me to bring it back in.
I spoke with the mechanic and showed him in their parking lot that it's still stalling. He asked me when the last time I had the air filter changed. I told him recently when I had the oil changed. We looked at the air filter and it looked brand new. He said that since it wasn't a Nissan product then that could be the problem. So, I purchased an air filter from them and guess what? The car still stalls!!!!!
So, I've made another appointment with this dealership for next week. Hopefully someone there can figure out what's going on?
Bumming out in Connecticut
10/17/03
If I were you I would give them their air filter back and demand my money back. Also, they should not charge more than $5 an hour for this kind of incompetent trial-and-error "diagnostic" service.
Do you have any previous service records on the car? Any ideas what's been done since it was new?
The 60,000 mile service is a major service and should include everything in your owners manual.
It should run around $5-600, depending on how through your dealership is and what they have listed.
Do you have another dealer you can use?
As for the wheel size increase fad, I voiced my opinion before and will voice it again - it is an impractical approach because large low profile tires are more difficult to balance and give a harsher ride, even if handling potential increases somewhat. And the cost of tires is substantially higher. So this is also a money making scheme for tire manufacturers. 16 inch rims are a happy compromise for a Maxima and Nissan should never have gone beyond that size for this car.
You can see the same increasing tire size trend on SUVs and trucks. Many Dodge trucks now come with 20 inch rims. Wait till the people who buy these things fork over $ 800 for a set of tires and have some kid in the local tire store balance their wheels all wrong for the second time. They will like those wheels a lot less, believe me. I would not take 20 inch wheels for free unless they came on an Army deuce and a half truck with 9.00-20 tires.
petition as I'm trying to get Nissan to issue a recall for these
defective parts!!!
http://www.petitiononline.com/NIS_IGN/petition.html
It is true that Nissan should have recalled their vehicles and upgrade the coils for free. VW and Audi did recalll about 300,000 vehicles for the same reason recently. I have not had any problems with coils on the 98 Maxima with 71K miles yet but I will not be surprised if I have to fork over $ 420 for new coils pretty soon.
You might even end up with some extra cash out of the deal and it would add an additional 1/2 of rubber between your wheel and the road.
I recall the same issue surfacing when the 00 Maxima's came out originally with 16" wheels on the SE. A few months into production Nissan made 17" standard on the SE and there were quite a few drivers wanting to swap.
Some wanted the 17'looks and didn't care so much about the stiffer ride and some wanted the better ride and were willing to give up a bit in looks.
Regards
Sanjiv
I expect it to last to about 250-300kms w/no issues. As long as you maintain it properly, don't worry too much.
Dinu
PS My Protege is also great BTW
1. Defective brake light switch located under the brake pedal. The switch could be shorting to ground internally when activated. The best way to determine if the switch is shorting to ground is to bypass the switch by disconnecting the leads from it and jumpering the leads to complete the circuit. If the fuse does not blow, then the switch has a short.
2. If bypassing the switch test still blows the fuse, you may have a brake light wiring short somewhere downstream of the brake switch, shorting to ground becuase of damaged insulation. Trace the wires from the switch if the switch turns out not to be faulty.
Bumps aren't as harsh, pavement changes are less noticeable, and the ride is quieter (so much so that I notice I have the rear window air leaks that there is a TSB for).
" Maybe its time to try an Audi or BMW which cost the same as or less than a 2004 Maxima SE and give free maintenance up to 50k"
Stick with the Maxima - those headaches will cost you even more.
Dinu
PS: Who really is a Mazda6 and Mazda3 fan but drives a Maxima.
My neighbor paid $ 40K plus tax for a 2003 BMW 330Ci two door coupe with leather, sport package, and no sunroof. This car is much smaller than 2004 Maxima, has a tiny trunk, and has a 3 liter V6 engine with about 220 HP.
* Has anyone else had this problem?
* Gotten it fixed?
* Did the dealer charge you anything?
(I'm at 20,000 miles)
jl
You may have a "carbon clogged" engine, from using high toluene fuel. The carbon can run red hot and preignite the mixture in the engine. It can be cleaned out at reasonable cost. Dealers, and oil change places can do this for you.
Another possibility is a sensor has worn enough so it's affecting the ECUs ability to control the engine, but has not yet failed enough to trigger the check engine light (service engine soon in Nissans, as I recall).
You should get it fixed, as eventually it will damage valves or pistons.
Generally you cannot fix a tire punctured through the sidewall. If the hole is in the tread close to the sidewall, it can sometimes be repaired, but many places will be reluctant to do so because of liability issues.
Commercial or military truck tires have very tall profiles. For example, 900-20 tires go on 20 inch diameter rims. The overall diameter of the mounted tire is 40 inches, which means that there is 10 inches of sidewall between the rim and the tire tread. With a 20 inch sports car ultra low profile ratio tire the overall mounted tire diameter will be more like 23 inches, or 1.5 inch sidewall. That is not much protection for the rim.
You're advocating spending $100 to insure yourself against the odds of destroying one of your tires over the next 3-4 years and 40,000 miles or so.
Is that a full replacement warranty, or if you only have 3/32" of tread left will they only give a partial credit?
If they couldn't make money selling the warranty at $25, they would sell it for more. They know how many tires they sell and how many come back destroyed. You don't. They're preying on your fear to make money.
I don't buy insurance on risks that I could afford to cover. Sure, it would stink to drop $300 on a tire or $600 on a pair but it isn't going to kill me. Its the same reasoning behind carrying a $500 deductable on my insurance. The savings of not carying the additional coverage theoretically more than make up for the risks.
