Does anyone know if the indash 6-CD changer is standard on all 2002 Maxima, because I think mine doesn't have it, and I check with Nissan website and it says the indash 6-CD changer is standard on all Maxima, now I'm confuse???
I'm hoping someone has experience with this and can give me some advice before I take it to the dealer, because I don't trust them much. I'd especially like to avoid having them rip down the headliner while troubleshooting.
I have a '95 Maxima that is just about broken in - 78,000 miles and runs like it's new! I think the Maxima, especially if you pick up a low-mileage used one, is one of the best values around. There aren't a whole lot of 6 cylinders that you can get with a manual transmission and a trouble-free maintenance history. If you're having doubts - don't! Go for it!
I have no info about the 2002 Maxima, but my 2001 has the autodimming mirror engaged full-time (unless I choose to turn it off). My 1998 Buick Regal also has the same feature, and it also stays on all the time (including at start-up)unless turned off. Both have the switch to turn the autodimming feature on the bottom of the mirror.
zhangjo@yahoo.com
As to all the problems mentioned in this forum - I thought that's what it was for!! I have two Maxes and surely wouldn't have bought the second if I didn't think it was the best thing on wheels!!
I have yet to change the oil on my 02 Max SE. I have 2,800 miles on it right now. Also, I didn't keep in under 55 for the first 1,000 miles.
PLEASE tell me I am not in THAT bad of shape! It seems to be running perfectly. Purring like a kitten!
But you probably really should change the oil about now, since it's well broken in. Cheap insurance if you want to keep your car for a long time.
I'd appreciate some feedback especially if your Max is the same.
oehrlein- I will check on my 2002 SE tomorrow to see if it has the "left rear wheel well" cover.
When my GLE was delivered, the tire pressures were extremely low (actually in the 22-25 psi range!), and the ride improved dramatically when I got them up to the right pressures.
Semper Fi
2. your question has been answered in the other place you posted it, the "Check Engine Light" forum.
The car drives like a gem. I love the car. I have encountered 3 problems with the car.
1. During the first year, the automatic AC never seemed to get very cold regardless of how low I set the temperature. This seemed to be very noticable during my first summer of ownership. The dealer checked it twice and said it was normal. During the second year, it seemed fine. I guess, after constant use, the AC became more effective. During this last year, I have never since felt that the car did not cool down fast enough even on the hottest days.
2. My car has traction control and on occasion the TCS light would come on and stay on until I turned the car off and restarted it. Of course, the dealer could never duplicate this situation since it only occurred on rare occasions. This is no longer a problem. It has not happened for at least 5 months. It seems to have self corrected itself or gone away.
3. The paint chips very easily. Despite Nissan's claim that they test the chip worthiness of the Maxima's paint by shooting diamonds at the paint, it chips much too easily. I have never owned a car whose paint came off so easily. It's not a huge problem, but it does require frequent application of touch up paint. Stone chips often show bare metal. My 1988 Honda Accord has a much more durable paint job. Nissan's paint seems cheap and very thin.
Otherwise this car has been great. I would definitely buy it again. I plan on keeping it for many years.
Hope this helps.
thanks!
Has anyone else noticed this behavior, and is there a fix like the fuel cut?
Thanks in advance.
S
We got the fix and now the car is great. Yea, the shifter is not very sweet and the motor mounts allow a lot of transaxle movement that is transferred to the shifter, but the motor is buttery smooth and sometimes we forget to shift gears it revs so well. Never seen a car motor like it before.
There are many message on maxima 5-speed problems in archived discussions, as this problem was solved by the TSB computer upgrade.
Also, a trick to lower gear smooth shifts is to slighly use more throttle than you were using right before the shift, disengage clutch and let off the power, shift and keep going. The slight push before the shift carries you smoother into the next gear. Blip the throttle on downshifts and take it easy on the transmission. I don't get warm fuzzies about it feeling really bulletproof, but I just guessing at the feel of it. FYI My first car had a Hurst shifter and a Muncie M-21 tranny, so maybe I'm just used to more solid feel than this thing has!
DD
We got our car with 200miles on it, more than I usually would take but it still had nubs on the tires so I figured it hadn't been on any bonzi runs like I did in a similar car with a buddy on a test drive. They let me take home to htink about it and figure someone did that and had second thoughts.
fyi - we looked seriously at the olds intrigue, but the rear seat was at a odd layed back angle, was not as sporty, and the headliner and interior fit and finish was lacking. Motor 3.5 was fantastic, about 3x the usable torque of the 3.0 nissan motor I'd guess ( I know it doesn't measure that way but it really jumps off the line and revs nearly as good. saw on boards problems with alternators and front end. Our nissan has been flawless except for the computer upgrade and the soft paint on plastic.
Can't remember the brand name, but should be available at any Marine store.
Fronts are larger on most cars, rears smaller, different.
max has disks both front and rear.
decellerating with by downshifting the engine puts more wear on the motor than it would brakes, and brakes are cheaper, that's the general rule.
you don't want "economy" brakes. You have a nice car, make sure get quality pads. material used on brakes pads varies considerably, and that can affect performance and pad life both ways. If you are totally satisfied with the nissan pads and they lasted quite a while, you couldn't go wrong using them again. I got 65k on a set of dodge pads on my last car and I was so happy with them (and dissatisfied with a set of cheapo ones I got at a parts store for my truck) I gladly paid the dealer price for new ones.
most all pads now are semi-metalic, and these harder pads last longer and handle heat well, but they heat up the rotors and warp them faster than the old designs.
you can replace them yourself if you are semi-skilled and have some tools, pretty easy.
good luck
We have 2000 Nissan Maxima. Starting last Sunday, when we park our car in a garage trunks open him self. Our bedroom right over garage and all night I can hear clinking sound of trunks opener. Their two new thing in our house that was not here before Sunday: water heater and cell phone. I have another idea; maybe a button on a key remote control from Maxima gets stack and that why trunks opened every 1 min. I will check this theory tonight. Any other thought?
As you get away from the optimized fuel economy point [2000-2500 rpm] the injectors are richen to lower the combustion temperature. Not unusual to see a 25-30% decrease in cruise mpg when going 80 mph vs 55.
In fact my wife was squealing about my hitting WOT and rowing through the gears on this one short entrance ramp -- even though she was the one who wanted the Max the most. Now I think she would have liked something sleepy like the Avalon instead! After the baby, you know she's more conservative. Keep telling her "you don't have to slow for this corner"...
1. CD starts to skip when heat is on (4-5song in), CD itself is very warm when ejected.
2. I can't open the driver door (when locked) with the handle, must hit lock release first, can this be reset?
3. Brakes work fine but seem to grind a bit, is that normal?
4. Drivers side window squeals, what/where do I apply white grease?
I got 24 MPG on my first tank, not bad for 2/3 hi way 1/3 city.
Appreciate any help!
