Ranger Problems
I'm having a problem with my '98 Ranger XL. Intermittently it will sense a "door ajar" when it does my dome light comes on and stays on. Often the light will go out after I shut the truck off. But it stays on a significant amount of time and I'm never quite comfortable leaving it for fear my battery will be dead in the morning. When this is happening I've started to pull the fuse for the dome lights. I know that's no solution. Does anyone have any idea what's wrong?
billyjack1
billyjack1
It's good to know that someone else has seen the problem. I'll try the WD-40 and if that doesn't work I'll replace the switches.
Thanks again.
ed
