Nah, then they would turn into another boring "one car fits all" company. I personally like the variety that GM offers, and I'm saddened to see Oldsmobile go since they had some really nice vehicles. My wife likes the looks of the Envoy but isn't very fond of the Trailblazer. If GM only made the Chevy version we would have bought elsewhere.
"Replace neon CHMSL with LED CHMSL (changes appearance when lit only)"
I had to have the CHMSL (Center High Mounted Stop Lamp) replaced under warranty a while back. Ironically, Ford began replacing their neon third brake lights on the Explorer with LED versions several years ago... LEDs are cheaper, are just as bright (if not brighter) and last longer...about time GM got a clue.
Frank
I have ordered this car, but I have put 0 down. Does anyone know if I can cancel? The model I ordered is pretty standard, but for the 3.73 reas axle. I can't imagine going through all the problems people are having. Yah, it looks good and it rides fine, but there are just too many stories. Plus, I am buying for a dealer that is 600Km away from where I am. Dealing with an other dealer will probably make my life even more miserable.
In case it helps someone on this board.....This car also had a problem where both the BRAKE and ABS warning light would illuminate and the blower motor wouldn't operate. Code was U1000 according to OnStar and dealer. Dealer replaced the ignition switch.
What's with all this Ford bashing? I've seen lots of 'em hold up very well and even had two F-150s last 200K + miles with only minor problems. Every Ford we've ever owned put together had fewer problems than this Trailblazer. My sister (works for GM) has a '96 Explorer with 140K on it that has had the thermostat, a door latch, and a piece of plastic trim on the driver's seat replaced. That's it besides scheduled maintenance, tires, etc. I don't consider myself biased but let's call 'em like we see 'em. This platform is having excessive serious problems and GM has unloaded a expesive piece of crap on us. I won't be going back for another round.....that would just be continuing an abousive relationship.
Think we're about to get some good old legal action going concerning this POS......Sales literature didn't mention anything about car abusing the owner!
I mounted the Reese Four-Bike Carrier last summer for our bikes. Nice thing is that it tilts out of the way for access inside the gate. Theres even an option for a brake light that wires into the very end of it.
It sticks out quite a bit, but I bought the 4 bike carrier as we rode with our friends a lot and with kids in the future...well you never know. Not sure if I will keep it or sell it, but prolly will hang onto it in case I get another vehicle with a 2" hitch.
Pictures and details here:
http://www.timlauro.com/cars/trailblazer/reese-bike-rack-mod.htm
tim
"One of the main advantages.....This is the difference between a crash and a sudden but safe stop."
REPLY:
Now if they could make it a factory option to fire the washer fluid spray from the rear window directly back at those kids in Hondas that tail behind you when you....oh....did I already rig that up You bet I've made it work! Great for summertime when they have their car all cleaned up.
They are out of ideas and called the zone manager to get me a free extended warranty and extended maintenance plan till the end of the lease. I can live with it and besides, I love this truck. Thank god for 2 year leases, if I owned this, I would not be so resigned.
GAM
I would recommend any of these triplets to my friends. Well, maybe not the Bravada. Just for the simple fact that GM decided to kill the Oldsmobile name. Just relax and look forward to the day it arrives.
I wonder what ratio was in the Edmunds test vehicle that blew away the Ex V8 in acelleration?
BTW, to answer the ratio difference question, a higher numbered ratio gives you more rpm per mph. Other things being equal, this would give you greater acceleration, greater towing ability, and lower mpg, all by having the engine running faster (and hence in the fatter, and flatter, part of the torque and HP curve) at any given speed.
the axle rating of 3.73 will make you lose about 1 mpg on avg. but will give you better towing by 1000lbs and get you going faster from a stop.
http://www.mpt.org/motorweek/reviews/rt2033.shtml
They will tear down your tranny see what failed order those parts and the Tech will rebuild it at the dealership.
"Yes, more than likely a 4.10 with those times. Also, with a 15/21 rating it has to be either 4wd or 4.10. And probably won't get those times with 4wd. It's amazing how much difference a few hundred pounds can make on acceleration runs, even on a 4400 pound vehicle."
REPLY:
Not sure what the results of others have been or if any have taken their Triplets to the track, but I have along with my other cars. 3.73's with nothing but a Cold Air Intake, temps in the mid 60's and about 1/2 tank of regular gas I ran consistant 15.7's in the 1/4 mile. My best being just over 15.6.
tim
1999 GTP @ 13.689
2000 Alero "GT" @ 15.591
2002 Trailblazer LTZ @ 15.675
Here is my take on the situation: at speed, the wind catches the mudflap and causes the plastic inner fender and lower rocker panel to vibrate where the flap is attached. This is transfered to the body near the pedals. I am going to try to attach the inner fender more securely to the body/frame. If this doesn't work, I may wedge some foam between the inner fender and the body.
I also have running boards, but I am not sure if this makes the problem worse. Didn't GM say the front mudflaps didn't work with running boards? Hmmm....... For those without mudflaps, sorry this doesn't apply to you.
GAM
" If you have front mud flaps, TAKE THEM OFF, and see what happens. I put them on my '03 Envoy and vibration appeared overnight. It seems to occur from 45 mph and up.
Here is my take on the situation: at speed, the wind catches the mud flap and causes the plastic inner fender and lower rocker panel to vibrate where the flap is attached."
I say....hmmmm
Very very interesting. I do have OEM GMC molded mud flaps for my 03 Envoy. It just so happens I notice in high winds, the vibration in the pedal is much much more pronounced, just like you said. And just like you, the vibration starts at 45 mph and goes up from there. Gam2, do me (and everyone else)a favor and please post after you have removed the flaps and let me know. Thanks man.
"I'm a bit surprised you ran mid 15's in a 4wd, based on published test results."
REPLY:
Keep in mind that published results are not always going to match the real world. Many folks didn't and don't believe the GTP will run mid 14's bone stock. It does. Ran 14.667 with nothing done to it and only 2k on the ODO.
YOU WROTE:
"Maybe the K&N really does help! Just makes me wonder even more about reported "sluggish acceleration." Yes I know, 0-30, etc.... I will say though that my previous comments were based on my experience which is 3.73. I have not driven a 3.42, and there could be quite a bit of difference."
REPLY:
K&N helps mostly at the upper range. Not many folks will probably run to 90mph in the 1/4 mile, but that's when you will know. Overall however, K&N is the most basic and certainly a cumlative modification. Not much should be expected for most other than a nice deep intake sound, some throttle reponse and that's about it. It benefits most when there are other mods added. Forced induction certainly benefits
4.10's would take off from the line better no doubt. I've learned to launch and hold the gears quite well. If anyone is interested in modifying an automatic and especially rear drive cars..or 4x4's I guess...go with a new Torque Converter. You'll find the faster Vettes and F-Bodies are automatics with modified TC's.
I went 242 miles on 10.42 gallons! I kept the speed between 75-80 mph, plus up and down the mountains of TN. I was very impressed with the mileage. My departed '92 S-10 Blazer never did that good.
If anyone wants to buy 2 tickets for the Martinsville race in 2 weeks e-mail me. Great seats for face value. I think the price I paid was $150.
GAM
Have them replace the drive shaft, you sound like you had the exact same problem!!!!
I say...
The dealer swapped the drive shaft, wheels, tires, and exhaust system with a brand new Envoy last week. Still no difference. My only hope is the mud flaps are the culprit at this point. Thanks a lot though for your input, under most circumstances, you would be right.
I have 25,200 miles on my 2002 Trailblazer and I want to replace the air cleaner filter. I've been told that if I replace it with a K&N filter that I will get more power, and better gas mileage. I find this a bit hard to believe. Anyone here replace their stock filter with a K&N and notice that this is true? Just want to make sure before I dish out the $$$$ for it.
Thanks much.
Hope this helps.
I found some cables at www.rcainput.com that allows me to connect the cables to the back of the STOCK deck to my audio system so I can connect my iPod to my Envoy.
I have a 2003 Envoy, and here's the cable I found...http://www.rcainput.com/Merchant2/merchant.mv?Screen=PROD- &Store_Code=RCAI&Product_Code=GM9-AUX&Category_Code=g- m
Can anyone tell me if there is a cheeper cable aviable? I don't have a tape player in the car, and I don't want to degrade the quality by much.
Thanks for the help.
JP
Can I order these parts online? I could not find a parts ordering catalog on gmgoodwrench.com. Also, if any knows the parts numbers for these, please email.
You tweaked my curiosity, so I went and looked at the site. Here's what I noticed immediately:
(GM9-AUX) Not compatible with 2002-2003 Envoy
It looks like you'll have to wait a little longer.
Also I know they are making it for the 2003 envoy...just don't know when yet. I can't wait cause my iPod has over 500 songs in just under 3 days of ownership.
Max Powers.
http://www.neurosaudio.com/store/prod_neuros.asp
MAx Powers.
I'm sorry I don't remember which company I got the mirror from. I bought it last fall but didn't replace it until last weekend. I think I still have the box in my garage and will post back if I can get the details off of it. Good luck.
