I'm at a loss for why this would happen twice. We are exclusively city drivers and I do not drive the car hard. Any advice or suggestions would be welcome.
Talldude
GAM
This is actually a bigger discount than it appears. When I used the employee discount, I had to pay taxes on it because it was an employer provided benefit. This roughly worked out to $500 on my Trailblazer. The general public won't have to pay taxes on this.
Talldude
Had mine replaced last year under warantee with no problems since
My '02 Envoy does the same thing and in hot, humid South Florida can be almost dangerous.
I found the following info in another topic that is now locked and I can't seem to find it again.
This is a known issue with GM. There is nothing they can do so they don't really acknowledge a fix. There was a TSB issued that essentially admitted the problem. Evidently the problem is that the sensor does not recognize the outer air temperature as high enough for the the condensor unit to come on. Once the vehicle gets moving, it recognizes the excessive OAT and the compressor kicks on.
I tried the fix suggested in the TSB for 'resetting' the sensor and it works !!!! You don't seem to have to do it everytime you start up, but I always do when it is super hot and the vehicle has been left in the sun.
Here goes......With the vehicle on and the AC running, simultaneously push the 'Mode' the 'Front Defrost' and the 'Rear Defrost' buttons. It will take three fingers. they are all right next to each other. While you are holding them for three to five seconds you will see the AC light flashing. When it is done flashing, release the buttons. You should see the EXT TEMP reading rise to the high 90's or over 100. The compressor will kick on and you will feel cold air in a few seconds instead on minutes. Note: You will have to cycle through the 'Mode' to get back to what you want. Also you have to turn off the 'Rear Defrost' that you turned on when you pushed the button.
This worked for me, too bad it took me almost three years to find it out. I have 85K in almost three years and have decided I'm going to keep this one for a while. Had the transmission valve body replaced under my extended warranty at 74K, other than that have not had any problems other than this AC gremlin. ((((Knock on wood))))
Good Luck.
Also talked to dealer about rust prob, got the expected runaround,shop mgr. sent me to bodyshop mgr,he refered me to his assistant, he was not aware of 5yr/100K rust through. I am going to take pics of rust, and write a letter to GM customer srevice.
Bill
On a funnier note, my wife got a product catalog from Pontiac the other day. I was reading about their new Miata fighter and in the specs they listed the front roll bar diameter as 26 inches! That's got to be one flimsy chasis if that's what it takes to prevent body roll! Me thinks they meant 26mm diameter. Ooops!
GAM
Thanks again...Bill
I
The rear urethane bushings will not fit the stock rear sway bar. Hotchkis bar is bigger diameter.
Tblazed - you want to give it a try since we were having the same a/c cooling delay at startup after the vehicle had been sitting in hot sun.
Also, I had the tranny serviced today. I took it to Mr. Transmission and it shifts smooth as butter. Before I had it serviced, I thought it shifted fine, but new fluid and filter makes a noticeable difference. In fact, I don't even feel it shift from first to second...amazing. The mechanic said the fluid looked brownish and I am glad to have it done for $72. I was reading a few posts on the tranny section that some triplets owners have lost transmissions in the 70-85K mile range. To be safe, I had mine done at 68k miles.
-gmfan
I have come across a 2002 Trailblazer LT.. Leather seats, Fully Loaded etc with only 18000 original miles on it. An old lady is selling it as it used to be her deceased husbands car. Its been garaged for over 2 years and has only been used a few times... Its absolutely like brand new... Problem is im not sure what to offer for it... We were thinking of 15000... It might even have some warranty left on it...Does this sound like a good deal??
You sound extremely frustrated and rightly so. I don't think anyone would expect a 5 day old vehicle to have an engine crap out. If GM agreed to buy back your trailblazer, you should consider yourself somewhat fortunate. Take a look at the "GM losing millions can they recover" forum. There are many out there who have had similiar problems with their GM products only to be left without any support from GM. I don't know the full circumstance of the issue you have, one of your problems sounds like your left making payments on a vehicle that doesn't run. Well based on the warranty, GM is supposed to provide you with a suitable comparable vehicle while yours is being worked on, talk to your dealer. If they won't help you, go to another dealer. That's the best thing about Chevy and GM is the amount of dealerships. I think many people have the preconceived notion they "HAVE" to go to their purchasing dealer only to get any warranty work done. Second If making the payment is the problem, call GM back and ask them to work with you. I know it may not all work out, but you'd be suprised. For one thing if you talk to the first person and they tell you they can't help you, ask to speak to their supervisor, and keep going up until you get an agreeable solution. I can't say I've been in your exact shoes, but I've had my issues with GM and with a little determination and patience, I was able to resolve the problems I did have. Good Luck
Was this the V-8 or the I-6 engine?
If GM already said they will buy it back, what more could you want? That sure seems fair to me.
Found I had no left signal or brake light and no backup lights on the trailer. Swapped bulbs on the trailer.
Tested the trailers harness for continuity and could not find a problem Then plugged the harness in at the hitch and did not get voltage through he appropriate wires. Then crawled under the bumper with the multi meter and behold, no voltage at the pins that corresponded to those lights.
Anyone else have one of these go bad? Worked fine last summer. I'm assuming this will be covered under my MajorGaurd
So, what are people seeing for idle speed on the 5.3 V8? Is there a service manual value or range for idle speed? Can it be easily adjusted by dealer?
Wxman
-gmfan
I've got everything hooked up for the high amperage leads, but there is a low amperage wire used to turn on the amp. It's commonly known as "the blue wire" and it just needs to go to a wire that is hot when the ignition is on, but not during engine cranking.
Used to be able to just slave off the radio hot wire, but afterlooking in the engine bay and under the back seat, I have no way of knowing which wire to use.
Any help please.
Also, anyone know how best to get signals from an xm radio into the Bose system? I'm using the cassette now, and don't get full dynamic range or quality, and the fm modulator is worse.
Thanks again....
Greg, Wichita
http://www.blitzsafe.com/blitz_appguide/Blitzsafe_Application_Guide.pdf
Hope this helps,
--Robert
The application guide pdf ababe has no entries for the 2000-2003 Olds or Chevy.
I'll give them a call.
Greg
Wichita
I have the '02 Envoy and have been pretty happy with it, but would like some more power/torque.
-gmfan
Advance info on the '06 TB says the 5.3L V8 will be available in SWB in both LS and LT trims. Will still require the Denali pkg in the '06 Envoy SWB to get a V8.
