My curiosity was still going so I removed the rear discs and exposed the parking brake shoes. As I suspected there was no real perceptible wear on the friction surfaces but I did find an adjustment rod that runs between the shoes. I adjusted this out (expanded) until I could just barely hear contact between the shoes and the inner drum then backed it off half a turn on both sides. Put it all back together and now the lever engages the parking brake halfway up the ratchet just like when it was new.
I think the adjustment at the lever between the seats serves to take up cable slack from inevitible cable stretching that occurs over time and the adjustment rod in the shoes takes up for any actual wear on the shoes themselves. I could be wrong about all this but I got the adjustment back to where it was when the vehicle was new.
Thanks for your help on this.
Glad you got it done. I have never taken the mechanism apart, so I couldn't be of any real help to you. Isn't it great when the dealer tells you that you need to have parts replaced when it's as simple as an adjustment? And then mechanics wonder why they have a bad name and nobody trusts them. There are honest guys out there, but they are the minority.
Has anyone had this experience and did you solve it??? :
Curious as to experiences of any other V8 drivers. Warranty is out in approx 500 miles.
Wxman
Greg
thanks for any help.
What the heck?! If anything, I expected the number to creep up if only slightly. Any chance the cleaner they use or a fuel additive might have caused this problem? I'm working through my second tank of gas post-service (mix of conservative highway and city driving) and expect to see similar miserable numbers but it won't be a direct comparison due to the highway miles.
Any thoughts out in edmunds-land? Thanks for all the collective wisdom!
They are concerned enough that they have kept it for a total of almost 7 weeks over 4 visits attempting to correct. Up to about 225 they don't care, but local service manager doesn't think it should be getting beyond there.
Can't confirm they have checked the IP gauge calibration, however, during lower temps it does read right at 195-200, where I would expect it to read.
Wxman
Does anyone have access to the full text of the TSB dealing with the intermediate steering shaft? Alldata requires that you subscribe to their service, and I don't.
I know there are at least two of these steering-shaft bulletins - one dealing with the full-size trucks and another specifically dealing with Trailblazers/Envoys, etc. That is the one I am interested in.
TIA
My advise would be to replace the end-links (they're not real expensive) and I'd be willing to bet the noise and vibration goes away. Cheapest place to buy those little buggers is www.rockauto.com, keep in mind that the left & right side are different numbers. (You can find the numbers by searching this forum ... they were given in April or early May of this year).
Check out Gas Saving Gizmos & Gadgets for more comments about spacers, etc. And you may enjoy the Breathe Easy: Int. & Exh. Headers + Mufflers and Pipes discussion.
Come to think of it, I've read enough about hyped dyno reading to be a bit suspicious of them too. :-) . But I didn't read any more about this than what you posted either.
While I doubt that most people could sense an additional 10 hp, twenty may be noticeable.
If you go this route, it'd be nice to see a reliable baseline so you'd know that the benefit is more than a seat of pants feel.
- WPK
I had one on my Envoy and the whistle under light throttle was more annoying than any benefit. (Bet they didn't mention the blasted whistle!) With my Borla split-cat-back exhaust and intake, there IS a .5 to 1 mpg increase if you take it easy.....when the spacer was on, I think the economy actually went down a bit! Think about it, the injectors are at the intake valves and there isn't any mixture to mix or atomize at the throttle body.....just plain air, and it has to split 6 ways for each cylinder.
So the changes are real and not just in the calculation of their numbers.
Carl
Seems I'd read that the best replacements (non-factory) actually had grease fittings on them. IIRC, NAPA was one source cited. Do the RockAuto units have grease fittings?
1) Ppull up on the two clips that hold the hadllamp assembly in and it gently pull forward.
2) On the back are two round rubber covers which pull off like a coffee can lid, one for the low beam and another for the high.
3) Remove the covers to access the bulbs to twist out and replace the bulb.
Reverse steps 1 & 2 to re-assemble.
If you want to ensure you don't scratch the top of the bumper, place a cotton towel between the headlamp and bumper before starting....or just be careful.
Ray
What kind of pad life is anyone else getting? Also brake dust is virtually non existant, and the brakes work great! GM gets an A+ in my book for this,
still sqeaks and moans after 3 trips to the dealer.
Greg
For those who might be having problems with unusual wear, pay close attention to lug nut torque when rotating tires etc. The way the brakes are designed as on most cars, the wheel ultimately holds every thing square and if the lug nuts are not torqued properly with respect to sequence (star pattern) and torque ft. lbs. (103 ft. lbs.) there is the risk of warpage of the rotor which is going to increase and accellerate wear of the pads.
Ceramics are a bit more expensive to buy but if you shop around you'll see thre is quite a bit of variance in pricing between NAPAONLINE and AUTOZONE.COM and others. You can get them for just a little more than premium quality metallics.
Thanks for your advice. I am guessing that you are taking the headlight assembly out from outside. Do I need any tool to pull up the clips?
Thanks again.
Mark
This vehicle has fantastic stopping. I read somewhere in a Car magazine it stops 60 to ) is 109 feet!!!
First I've heard or read they are ceramic from the factory. Maybe on the newer ones? My 2002 original pads leave some brake dust on the front wheels. Brakes are excellent IMO except the typical ABS action when trying to stop hard and fast on a washboard surface or gravel, and the ABS system lets up because of tire hop or slippage. Makes me wish for a switch to turn on or off the ABS. But that's the way ABS works. Other than that... excellent.
- WPK
Bill
