Mercury Mystique Problems
I have a 1995 Mercury Mystique. I recently took it to my mechanic for a front end alignment. My mechanic called me and said that the camber on the left side is off by 1 percent and .75 on the right side. He told me that Ford has no fixes for this problem. Does anybody know how to get my front end back in alignment. Apparently Ford never came up with a fix for this problem.
Pat
Roving Host
Now, I can get a little heat if I keep the PM's above 2500. Ever since I took it in that first time (three weeks ago) I have been back four times because the car now loses all heat inside and overheat. They have had the radiator out because they said they found a leak. (I live in a brand new house with a brand new garage. I have found NO coolant on the floor so I don't know where it would have leaked to!) The last time I had it in (last weekend) I was told that there is an air lock in the cooling system.
Two questions. Is this an ongoing thing with the Mystique/Contour line? And does any body know where I can get a heater core?
basis. I would suspect the heater core as said or the thermostat. How many miles are on the car? Did you have the vehicle looked at before you bought it? I would try to be patient with the dealer, and not assume the worst right off the bat. These are very good cars if taken care of.
Joseph
Good luck. I stiil feel that these are some of the most overlooked cars on the American market. I am looking again to replace yhe 1996 SE I sold awhile back.
There is a recall on the V6 having to do with the fan and overheating.
