Subaru Impreza WRX
18081838586224
  • beygobeygo Member Posts: 9
    All very good advice. However, I thought I've read somewhere that boxer engines are designed so that most of the engine has oil at all times, even at rest. Is this true, or was I hallucinating? :-)
    BG
  • mudpiemudpie Member Posts: 3
    I have a 2000 Outback and followed the Outback forum in early 2000. The WRX CEL light discussion/complaints are the SAME!!! Deja Vu!
    Plus my 2000 Outback had brake scoring too!
    So:
    1) Are these really "problems", or are some people doing something "wrong" to cause them?
    2) Does Subaru have an inconsistent quality supplier for their oxygen sensors and brake rotors?!
    3) Is waiting (Corkfish) for a 2003 WRX going to make any difference?
    Paint: definitely some companies have better paint than others. Ferraris go thru 26 sprays or dips. But the comparisons people have made are very unscientific (yep, I'm an engineer). Chips on the front end of the car have as much to do with the shape/angle of the front end as with paint quality. My boxy '86 Volvo didn't *have* any vertical painted surfaces that had to take the direct impact of flying debris, so no dings! But sheesh, the airflow (or something?! dunno.) caused debris to "float" over the grill & hood and smack the windshield all the time! 6 years & 150kmiles later, 6 cracks and scores of pits. The pitting was so annoying that I replaced the windshield! Plus, lots of debris could be found smashed into the radiator fins...
    Anyhow, I don't really care about little cosmetic defects. I have my $4 thingie of touchup paint and that'll do it for me.
    To paisan's "age" theory, and bedabi's "tinkering" theory, I'll add another. I have a "tailgate" theory that says many dings and cracked windshields are simple caused by following too closely.
    Think about it - you are getting hit by something, probably gravel or something, and that has to be coming from somewhere. The paint doesn't just spontaneously chip by itself. And for something to hit you that high up on your car (especially windshield), you had to be close. Otherwise gravity would have taken it out of your way.
    I'm guilty of this, too, but I guess I've been lucky. My wife has cracked her windshield twice already.
    BG: yes, because of the boxer layout. In a in-line or vee configuration, the oil has to travel upward to lube most moving parts. In the boxer, it's already there.
    -juice
  • mdimartimdimarti Member Posts: 12
    Have to chime in on the age argument. I am 25 yet I do not tinker with the car, nor do I race it. I actually treat the car very well, am religious in my oil changes, let the car warm up in the morning, don't drive hard until the car is fully warmed up etc. I drive anywhere between 250 and 500 miles a week, 90% of which is highway, some heavy traffic. Yet My CEL turns on like it is part of the instrument lighting. My theory would be that so much electronics are involved in the car that problems happen inevitably. Some worse than others, and Luck is a huge part
    Mark
    I don't think he meant in every case, just that there may be a correlation (i.e. more CELs for the under 30 vs. over 30 crowd).
    What gas are you using? You probably have a bad O2 sensor or something. Clearly it has nothing to do with your driving.
    -juice
  • p0926p0926 Member Posts: 4,423
    I must have missed something. Several posters have alluded to the WRX being plagued with a number of problems. The complaints I've seen thus far are:
    a. CEL: Several owners have experienced the CEL coming on. This however is not unique to the WRX as both Forester and Outback owners have also experienced this. The major cause is faulty oxygen sensors (which are a common part throughout the Subaru line). In this case, the CEL is not indicative of a mechanical problem but a potential emissions problem. In addition, many other makes are also plagued by CELs. From my understanding, the root of the problem is that the automakers are having a difficult time meeting the stricter US emission standards. FYI: industry-wide, the number one cause of the CEL is the failure to sufficiently tighten the gas cap after a fill-up.
    b. "Bad" Paint: Several owners have also complained about the quality of the WRX's paint. Again, this not only applies to the entire Subaru line but is also a very subjective complaint.
    c. Brake Scoring: A couple of owners have commented about brake scoring. This too does not seem to be WRX specific and may or may not be a problem.
    Also, driving habits may also have contributed to each of the above "problems".
    So it appears to me that the WRX really doesn't have a single unique first production year problem. Especially compared to the Ford Escape's numerous recalls (including the steering wheel falling off), the launch of the WRX has been flawless!
    Also, the anecdotal evidence that people provide regarding their positive experiences with other vehicles is next to useless. As an example, Corkfish's Nissan experience. To counter that, I had a Nissan that got a cracked cylinder head within the first 36K miles. But I didn't blame Nissan, since at the time, I was much younger and prone to the 0-100 starts that AH alluded to.
    In summary, from everything I've seen, the WRX's launch has been extremely successful and is an exceptional value for the money. And if you want a better paint job, plunk down another $10k and buy a less capable Audi or BMW.
    -Frank P.
  • esqknightesqknight Member Posts: 78
    Are alloy wheel locks worth bothering with? I know it is easy to steal hub caps, but how easy is it to steel rims..do thieves actually have to remove the tires? Has any had their rims stolen?
    Debating ordering the locks..its $18.50 or so plus shipping at Subaru parts, so money clearly isn't the issue, just convenience.
    Eric
  • WarpDriveWarpDrive Member Posts: 506
    Wheels locks are extra insurance. It reduces the temptation just a little bit. But it's a good idea to hide the lock in some place where it can't be found easily.
    I've actually seen new car at a dealer which had their wheels stolen (Dodge Intrepid). The car was jacked up, wheels taken off, and the car was left on blocks. Ouch, can't be good for the car.
    They downside is that they make more work if you have to change your wheels (like those who use racing wheels for autocross) often. The only thing you have to be careful is not to overtighten them which can happen inadvertantly if the service guy is ignorant. If they are overtightened, the locks may be damaged because you have to get excessive force to loosen them.
    The one thing you have to your advantage is that the WRX rims are not really a "hot" item. Most people want to replace those rims with larger 17 inch ones and they won't really fit other brands of cars. However, some TS wagon owners or older gen Impreza may look at the WRX rims with envy.
    Well put, Frank.
    BMW has the record, I think, with 14 recalls for the X5 already.
    Get wheel locks from Trak Auto or Pep Boys. The $20+ you'll spend is on the high side, and Subaru's wheel locks are bulky and look ugly IMO.
    -juice
  • ramiller1ramiller1 Member Posts: 124
    really are one of us after all. Come to think of it, lawyers have a reputation for knowing a good deal when they see one, so it's not so far-fetched you would be tooling around town in (not-so-undercover) Rexes.
    BTW, you guys can inspect my garage anytime you want--guarantee you won't find anything but a couple of (well-pampered) Scoobs parked out there! :)
  • hunter001hunter001 Member Posts: 851
    if the component is defective, there is nothing you can do about it, since it is bound to fail regardless of whether the car was taken care of or not. But if the component is a good one, it will last for ever, if taken care of properly with good driving habits. With nasty driving habits, even good components will fail with blame being unfairly foisted on the automaker. That was the point I was making.
    CELs are not mechanical problems at all. They are mainly due to problems with emissions sensors, unlike what a lot of people believe. It could also be due to over-sensitive emissions sensors, even though there would be no problems with the emissions at all. But it is always a good idea to get the sensors replaced, since the car is under warranty. That is what the warranty is for !!
    As pointed out earlier, the first thing I would look for is the tightness of the gas cap. Make sure that you hear at least 3-4 clicks when tightening the gascap. If the CEL comes on immediately after filling in the gas, it is almost certainly due to the gas cap not being tightened enough. The solution is to tighten it till you hear 3-4 clicks and then go through about 3 driving cycles (start the car, drive around a bit, then switch it off and repeat this about 3 times....the CEL magically disappears).
    Later...AH
  • bedabibedabi Member Posts: 149
    One word: BROOKLYN
    Wheel locks are a must. It's true, as I've said also, that Subarus aren't prone to theft, but I've seen way too many new cars jacked up on cinderblocks with their wheels stolen to ignore. I have the ones from subaruparts.com on my own wheels.
    I think you are just a little paranoid. I live in NYC, travel to crooklyn a lot. Subarus aren't high on the theives list. A Camary is far more likely to be stolen than your WRX. I do have wheel locks on my Trooper though, cause they were std. equipment.
    -mike
    OK, first of all, you need to concede a few things. You live in Staten Island, IIRC. That's a whole world away from Brooklyn. Secondly, esqknight and I both have to street park our cars overnight, everynight. Paranoia means having a fear without a rational basis. That's not the case here. Granted my WRX isn't high on the thieves list, but thievery is more about opportunity than demand-side economics, and cars parked on the street in Brooklyn everynight is opportunity at it's best. Moreover, call it an occupational hazard, but as a prosecutor in this county, I'm in a better position to know about crime here than a layperson. (Although this didn't help me when my Maxima'a front passenger door was stolen while parked right in front of my building - yup, just the door!) <:-}
    But I did part my Rodeo on 125th street in Manhattan for 6 months straight. I live in NYC and have spent many nights in Crooklyn. Also my uncle and several other friends are cops in brooklyn as well, so I'm pretty in-tune with the crime out there.
    -mike
    PS: Out of the 25 cars on my block there are 6-8 stolen every year. which is probably a higher per-capita than your block.:)
    PPS: wheel locks aren't going to stop theives in NYC. Most will steal the whole car rather than just the wheels, this is why we have insurance.
    Wheel locks will take more time to take off, but a professional, determined thief will not be stopped by such a simple device. There are ratchet bits that adapt instantly and could be used to remove those.
    -juice
    When my dad was teaching @ a prison, he talked to a guy in for Grand Theft Auto, said wheel locks and stuff are pretty useless, most theives steal the whole car and strip off what they want. The best thing he said was to have a cut-off switch of some sort which will slow the theives down enough to not make it worth their while. He also said if they get an order for a car they'll just go with a flatbed and snatch it no matter what devices you have to stop them.
    -mike
    sure wouldn't be something to cry over, although I would sure miss the alloy wheels. Maybe the insurance would pay for better tires though. I was browsing through tires at The Tire Rack, and the RE92s are really close to the bottom of the barrel. The Dunlop SP Sport 5000 Asymmetrical seemed like a good buy, I wish I could get them to knock $200 off the price and tell them to keep the tires.
    Anyways, far as theft -- I am far more worried about thieves in Brooklyn making off with my whole car then I am about them jacking the car up on cinder blocks and stealing the tires..almost seem like they deserve them ;) plus I don't want to piss off said thieves by making them work so hard they decide to leave me additional presents like a broken windshield.
    Also, my car spends most nights in a driveway.
    Eric
    Eric,
    The SP5000s are great tires. What I'd do is buy the SP5000s and sell your RE92s to someone on the I-club who wants/needs em. I'm sure you could fetch at least $150 for em in new condition.
    -mike
    I hope you don't doubt my intelligence so much that you'd think I believe wheel locks will prevent an entire car from getting stolen. Very obviously, at best they will slow someone who intends to steal the WHEELS. This is all I'm hoping for - to lessen the opportunity. Several years ago, I kind of specialized in auto crimes. Bascially, if someone wants to steal your car badly enough, they will steal it. With a flatbed truck if need be. I've handled a couple of cases where manufacturer installed cutoff switches did foil a would be thief. To my surprise, I've had a couple of cases where cars where recovered by lojack devices. We even had a big sting operation where guys were flatbedding luxo-German cars and shipping them off to Russia. The luxo-SUVs get shipped to South America. Luxury cars don't get stripped because these owners can afford to buy real, new parts. Older Hondas, Toyotas and Nissans are much more valuable for their parts than they are whole. Recently we had a "condition" because keys from pre-1988 Toyotas fit into any other pre-1988 Toyota, and kids would steal one, ride till it ran out of gas, and then just park and steal another. Anyone with an older Toyota should be aware of this. Anyway, I never saw a Subaru get stolen, but that's not gonna stop me from doing what I can to prevent an opportunist from stealing parts of my car. I'd rather they just steal the whole thing and collect from insurance.
    P.S. Hell, out of 25 cars on my block there aren't even 6-8 cars worth stealing! Right now I'm more concerned about the gunshots I hear periodically around the corner. A bullet hole in a quarter panel would really suck.
    At my previous home the neighbor across the street had her rims stolen from an Accord. Thing is, their offset is so common they fit on any car. Hence they are desired by thieves.
    Subaru uses a unique offset, so it'll probably only fit another Subie.
    -juice
    I don't doubt your intelligence, wheel locks won't stop them from stealing your car! I too heard about the german ones being flatbedded. I also agree that wheel locks for $20 is a worthwhile investment.
    -mike
    PS: If you are worried about bullet holes in your quarter panel, it's time for a new neighborhood! :)
    Are you saying that $20 is too much money to be spent for a little peace of mind? Not to bother? You've got some high standards! ;)
    I've had the Dunlop SP 5000s for about 1500 miles now. They are fantastic in the rain. I drove 400 miles in heavy rain, and the grip was very confidence inspiring. Much better grip while cornering also, and Tirerack puts it at the BEST all-season performance tire.
    Again, I'd rather have the whole car stolen than just some parts. That deductible when I had to replace the door on my Maxima was harsh. plus, I got that Max for so darn cheap ($14k brand new)I might have even made some money.
    P.S. Paisan - Wy move? It's generally a good neighborhood and more than that, RENT STABILIZED, baby!
    Then don't worry about gun shots! :) I don't like hearing gunshots outside my window personally ;)
    -mike
  • rex_ruthorrex_ruthor Member Posts: 140
    which could also be adapted into a TV sitcom....
    "Lawyers in da Hood" or..."Ghetto Law"
    Now being filmed in Crooklyn, NY!
    -mike
    but then I live in what would be considered the 'burbs of Brooklyn. Given the relative cheapness of the locks, I guess it doesn't make sense not to get the locks..just hope I don't lose the key. If I get the locks at pep boys or the like instead of the subie part, do I need any particular type to fit on the WRX?
    As for the tires, any other idea what to do with my RE92s? Given that I'm getting the car January, I'd like a good set of tires under me and my new car, but I'd also like to get some money back for the stocks.
    One more thing, has anyone else had the Strongard kit applied to their car and is it worth it?
    $700-$800 (with installation) on top of a new car purchase is a little rough (also makes the car less of a bargain). I'm tempted to just buy a tube of the touch up paint.
    Eric
    Since ther are at least 4 people who are in the area.
    -mike
    Try to sell them on i-club. Plenty of folks need all-seasons for the winter months. Or just run with them for a while like I did till your conscience won't feel the sting. (By the way, Civil or Housing?)
    rex_ruther: Yeah, I can't watch that show "Law and Order". First, why would I go home and then watch work? And second, Manhattan DA's are wusses. We need our own show. :]
    Given that you've ridden on both RE92s and Dunlop SP 5000s, how much of a difference is there in handling and safety? I'd rather pay some extra money if I'm going to feel much safer tooling around in my car.
    I'm in civil.
    Eric
    I can't honestly say there's that much of a differnce unless you are in some adverse conditions. Like I said, the Dunlops were better in heavy rain while cruising at 80 mph. Definitely stick better on quick corners, and they give the steering wheel a heavier, more substantial feel. But all the same, I am glad I at least wore the tread out a bit on the RE92s before I chucked them. If I were a much more aggressive driver, I'd probably appreciate them a bit more but I'm relativly tame. (When I visit my parents in the 'burbs, I have to constantly remind myself to tone it down though.)
    P.S. Cool, Housing Court is a total ZOO!
    I am still debating on the replacement tires for the stock RE92s. The options I am considering are the Dunlop SP Sport 5000s or the Michelin Pilot Sport A/S (All-seasons). The Michelins are much more expensive than the Dunlops ($178 vs $101 as per tirerack), but going by Michelin's quality standards, the tire should be worth every penny. The Michelins (205/55ZR16s) are supposed to have kevlar reinforcements etc in its structure (in addition to a variety of other innovations) and has a UTQG wear rating of 400, in addition to having a load rating of 90 (the dunlops and RE92s have a load rating of 89). In other words, the Michelins are the best. But is it worth $77 per tire more than the Dunlops??? Decisions, decisions...In any case, I think I will just wait until the RE92s wear out a bit.
    Later...AH
    $20 is not too much, it's just you can get smaller, better looking ones for less elsewhere. Sooner if you buy local, too. I have them on all my cars, BTW.
    -juice
    Are they all the same, or do I need a certain type of lock to fit the alloys that come on the WRX?
    I think it's just a certain thread type/size. Take one wheel nut with you, and you can compare them. Auto stores I've seen have bolts to try out and find your size.
    -juice
    A rep from TireRack who frequently posts on i-club compiled a top six list of tires based on TireRack's own testing. Here it is:
    "Ultra High Performance All Season
    Performance tires which are capable of going through the snow.
    1.) Sport 5000
    2.) AVS DB (the quietest tire I have driven)
    3.) G-Force KDWS
    4.) Pilot XGT Z4
    5.) P7000 Super Sport"
    Here's the link:
    http://i-club.com/forums/showthread.php?s=&threadid=64899
    esqknight: I think any lock would do. Lik juice says, you could get cheaper ones at Autozone.
    Many of you have expressed concern about the quality of paint on your Rexes, so here are "secrets" I've learned from many years of owning some fine automobiles.
    They've also worked quite well for the Subies we've owned.
    Secret #1--Rinsing your car frequently (2-3X/wk. if possible) with just plain water will do far more to maintain your paint than leaving the dirt on there and getting a deluxe car wash only once in a while. This takes 5 min. in the morning with a garden hose--no need to dry--you just want to get the harmful dirt off the finish.
    A guy in LA had a '50 Caddy and all he did was rinse it off every day--his paint stayed like new for 20 years! The car never gets really dirty this way, so you can go the whole summer and never pay for a car wash. In the winter, just pay the $1.50 and use the rinse and wax cycles only. Avoiding harsh car wash detergents will add years to your finish. Use mild soaps like Rain-X or Armour-All for tough cleaning at home--these won't take the wax off or hurt your paint.
    Secret #2--Use carnauba wax to seal the paint and give it a hard protective coating. It's an extra layer of insulation against harmful chemicals and flying debris. Classic Car wax is great if you can find it, Malm's is also outstanding. Mother's also makes a carnauba, but haven't tried it, so can't vouch for it. Many "modern" wax formulas without carnauba give a great shine but can be hard on the paint, IMO. There might be exceptions to this--haven't tried them all by any means.
    Secret #3--It takes two months for new paint to cure and harden. Asking the dealer not to touch the paint except to wash it off can save you a lot of grief later on. Some dealers use power buffers that can leave swirl marks in soft finishes. When you take delivery, just keep the paint clean as in #1, using a little spray wax from the self-serve wash to protect it. After 60 days, go ahead and apply the carnauba.
    Secret #4--Keep the car out of the elements day and night if possible. The more you can do this, the longer your paint will last. If you don't have a garage, a car cover can really help.
    Also, park in the shade, but not under trees where harmful bird poop and tree sap get on your finish. And those insect casualties on the hood and grill need to be washed off right away because they have some really nasty acids that will eat right through your paint. (I just keep a spray bottle of distilled water and a towel in the car for this.
    Nutty thing to do, I know, but hey, when you're a fanatic . . .)
    Secret #5--I agree that Stongard is great if you do a lot of hwy miles--those gravel trucks can really pulverize your front end in a hurry.
    I try to avoid the hwy whenever possible, and just a tube of touch-up does fine for us.
    Secret #6--Don't park next to big SUVs and pickups or 2 door sedans. They are much more likely to give you a wicked door ding than a 4-door sedan with smaller doors.
    Of course, one good hailstorm can send all your hard work down the tubes. Knock-on-wood. hope these suggestions help a little.
    ....the paint from the factory is fully cured because of the intensive curing process they use. You can wax your car right away. If extra painting is done at a body shop, then yes, you should wait a couple of months (applies to port-installed spoilers or ground effects)
  • silver_bulletsilver_bullet Member Posts: 1,339
    ...are quite popular, and are available from retail outlets or the Tire Rack. Any lock you choose should have the correct thread pitch (duh), proper reach or depth (depending on if your car uses lug bolts or lug nuts), and the proper taper, or seat (some cars have a spherical seat, some flat, with most having a conical seat). Nissan "factory" wheel locks are actually repackaged McGard locks, for instance.
    I did read this link a while back. Actually, the Pilot Sport A/S is a brand new tire from Michelin and has been out in the market for about a month or so. It is also classified as an Ultra-high performance All-season tire. It is a completely different tire from the Pilot XGT-Z4s. Incidentally, I do have the Pilot XGT-Z4s on my other car - Acura 3.2TL.
    The links below from www.michelin.com shows how the Pilot Sport A/S are better than the Pilot XGT-Z4s in pretty much all criteria.
    http://tires.michelin-us.com/catalog/tires/pilotxgtz4.html
    http://tires.michelin-us.com/catalog/tires/pilotsportas.html
    Also, here is something from Michelin's site:
    http://www.michelin-us.com/us/eng/tire/promo/pilot_sport/flash-home.htm
    Also, www.tirerack.com is a vendor and they would skew their tests towards those manufacturers whose sales arrangements would net them the most margin....just a thought.
    Later...AH
    Those Michelins look pretty nice.
    So.... am I to take it that I should disregard TireRack's testing for business bias and rely on Michelin's tests on their own tire as more objective? ;]
    I go by the user's ratings on tire-rack. But I make sure that there are a lot of miles on the test clock, with low test miles a bad or good rating could skew the #s a bit. Michelin tires are very long lasting IMHO, and decent performance wise, but are quite pricey. I rather replace them more often and have a grippier tire. Tread life isn't everything in a tire.
    -mike
    I can only comment on the Pilot XGT-Z4s since I have owned it for almost 20,000 miles on my Acura (225/55ZR16). Michelin's test results were spot on as far as my experience with those tires were concerned. The strengths and weaknesses of the tire, as experienced by me, was exactly as depicted on their site.
    Due to the above, I think I would go with their results on the Pilot Sport A/S tires too.
    If Consumer Reports or someone like that had done the test, I would go with their results since they are by and large devoid of any noticeable bias, even though their test parameters have to be watched closely before making any determination of the results.
    Also, if Michelin charges 70% more than the price of the dunlops (SP 5000s), I think they are confident that it is worth it, I would suppose. And I am not comparing the load factor of the Michelin which is slightly more than the dunlops (90 vs 89) or the UTQG rating (400 vs 340)...I am commenting on the virtues of the tire itself in terms of its extreme grip in the wet, excellent grip in the dry and regular handling and very good grip in snow and ice. If you look closely at the tires' construction (including the use of Kevlar etc), you will realise the reason for its price. That tire is well nigh indestructible. But they are a bit too rich for my blood and I might settle for the Dunlops after all. In fact, I would think that the Michelin Sport A/S would probably compete with the Pilot XGT-Z4s, which is another one of Michelin's Ultra-high performance all-season tires.
    Later...AH
  • bruticusbruticus Member Posts: 229
    I'm moving in mid-January; it might sound weird, but I've not even seen the place yet (my current housemate received a large cash windfall in October, decided to buy her own house (same monthly payment as the apartment and she's building equity) and asked me to tag along for a little while at least). I don't know if we'll have a garage, so was wondering if a car cover is a good idea, and if there is a particular kind that is not terribly time-consuming for morning off/evening on.
    TIA
    DjB
    Putting on a car cover with road grime and dust on the car, would result in a lot of scratches. Basically, the dust already on the car would act like a sandpaper when the car cover rubs on it. However, it is a good idea to put a car cover on after a carwash. But how often would you do that?
    Later...AH
    C&D has a little tidbit in their 10Best article about door dings. Minivans have the shortest doors, so park next to those if you must. I try to get end spots, too, so that cuts the dings in half right there.
    -juice
  • brekkebrekke Member Posts: 304
    The other day I was waiting in the car for my mom. The owner of the minivan parked next to us came out first. He flung open his car door so hard it bounced back. It made me wonder if he knew there was enough room to do that, or if that's how he always opened his car door. (Based solely on his appearance, I'd say the latter)
    Yikes! We're not safe anywhere. ;-)
    -juice
    I'd be out of my car screaming my head off if someone did that to my car with me in it!
    -mike
