Please tell me it wasn't someone at a dealership who gave you this information.
The 3rd brake light cover slides toward the front of the car. Push down while sliding to disengage the "teeth" that keep it from rattling loose.
The Capri was (since the early 70's) a Mercury coupe. I own a '73. No way could that be used for Lincoln.
I'd like to take the opportunity to thank all of you for listening and more importantly for replying. Sometimes it is hard to troubleshoot a problem objectively becasue automobile ownership can get quite emotional.
Any insight?
Interesting owning a car that's so well known & respected. . .or not.
Talk about a sleeper. The LS is more like a coma.
Soooo - that was the sound I heard when I started the TC I am driving today. From Enterprise - LS is in for service.
- Ray
Glad for a free loaner - not so happy driving a TC in Atlanta metro traffic . . .
At World in Alpharetta I've gotten a 4 door F150 and an Expedition the last 2 visits. We used Billy Howell in Cumming for the Aviator and got a LS.
Actually it's not as bloaty as it previously was. The fine tuning in the suspension last year won't leave you with that bloated, bulky, behemoth feel. The rear end won't twitch back at you, when your doing evasive manuevers. If anything, it's suspension feel will be as that of a Taurus for example... NOT that the Taurus excels in nimble feel, but I'm giving you an example of how it feels relative to it's size.
Granted, the Marauder's suspension tuning would be greatly appreciated but reality, do we really want grandpa/grandma to feel THAT confident in their Town Car?
I second the 4.6L 3V, don't be suprised to see such a revision in the next 2 years.... Ahem...
And since you brought it up....I drove an 04 Escalade my Lincoln dealer happened to have on the used lot today for an errand while he was washing my Navigator up. I was amazed at how much better the Navigator handles and rides. Add that objective opinion to the lack of features and style inside, and I am at a loss to understand why an unbiased buyer (some people are just plain Cadillac folks, you know) would chose the Escalade over the Navigator.
Now, back to your regularly scheduled topic
There was a very small amount of wetness around a big nut located about 1/3rd of the way across the steering rack from the driver's side. If anything came out of here it certainly couldn't make it to the exhaust manifold to cause smoke in front of the driver's windshield. Does anyone know what this is and if it might be a problem? The mechanic said it was an adjustment for steering play and that there was an 0 ring used to seal it. The service writer said he had to find out if there was a kit to replace the 0 ring. The mechanic said to not worry about it but to not tell anybody he told me that.
In conclusion the mechanic who is also an LS fan told me the valve cover leak problem is caused by a defect in the passenger side valve cover which causes pressure to build up and since the two valve covers are connected by a hose the pressure causes the driver's side valve cover to leak. So the fix (TSB) calls for the passenger side valve cover to be replaced and the driver's side gasket to be replaced. Very time consuming job. Around 4-5 hours because of all the stuff that has to be moved out of the way. It's a $600 job. The service writer being aware of the fact I knew about the TSB has offered to knock all but $250 off the cost of the repair. Sorry for the lengthly post but I've gotten a lot of good information off this board and felt I wanted to leave some for once. I won't be buying a steering rack.
I cannot find that TSB anywhere.
What is the date and TSB number?
<<<< the two valve covers are connected by a hose >>>> Not true.
I would change both valve covers, all the gaskets, o-rings and grommets, spark plugs and rubber boots if I had to do it all over again!
the spring in the rack was change still the vibration he change the rack and pignon still the vibration in the steering and the car seem to go right and left i drive them it shake at all speed
it was dificulte to take the car right in lane
one you can felt the steering going right and left a little
alignment is good balance good
when i took real bounce or hole the
vibration disappear four 1km worse when accelerating and when it very cold minus 20 it almost no vibration
when is hot vibration is worst
someone can told me what is the
isolinear dampers in the lower control arms
like div2 in 13609 message.....
dealer know noting about it
my last visit to the dealers
cost me 258$ for the time he spend on the car lincoln dont want to pay for the service anymore the car is still on warranty for the beep he re program the computer but the beep is still there most of the time when accelerating the first tire was
firestone fire hawk lh wearing out by the inside and the second one is falken
st115 still wearing out by inside the falken guy where i buy the tire re balance it and the vibration was still there i spend over 1000$ in lawyer and now i would
like to go with mechanical engineer am very lazy
dont know what to do need serious help........ poor Canadian with
serious problem pretty close to buy japanese car.
Your vibration issue sounds like a tire or wheel or balancingb issue. Try the Hunter Road Force balancer to solve the problem. The Hunter web site has details along with where you can find one in your local area. This should pinpoint any wheel/tire problems.
<<<<What is the date and TSB number?>>>>>>>>
<<<< the two valve covers are connected by a hose >>>> Not true.>>>>>>>>>>>>>
Dealer told me the TSB has been removed from system. Both the service writer and mechanic remembered it though. Maybe someone on here of the LS owner's club website can supply the number.
As far as you saying "not true" to the crossover hose all I can say is I trust the Lincoln mechanic who explained the problem to me. He owns an LS, he is a fan of the car and he did the mod on his own car.
They probably removed the TSB because they were wrong and they (Lincoln) would have to pay the high labor costs.
All Data, LLSOC = no TSB
My car 2000 LS8 Sport. The hose that crosses over is a fuel line which if you don't have the correct tool to remove will potentially result in a bad experience ( I know this for a fact!
There is no equalizing hose connected directly into the valve covers.
Maybe somewhere else in the intake system, head etc...?
Good luck and make sure they remove all the caked-on oil in the spark plug holes while they're at it! (Now THAT takes some time! Grr...
The vibration seemed to really a resonance and it seemed like it was in the suspension. What Div2 posted - isolinear dampers in the lower control arms - makes a lot of sense. It would explain why it goes away when you go over a bump and why the smoother the road, the worse the vibration (resonance) is.
The question is that if what Div2 says is the case, why was there never a TSB on this and why does no one at Ford know what is going on (including the regional field engineers)?
Good luck on getting a resolution, whitton. I would suggest that you keep fighting, keep calling Lincoln HQ until you can get to someone who will help you. Hopefully Div2 can come back with some more information on the LCA dampers and who in the Ford organization knows about this.
Issues starting to build on my 2000 Sport V8 with this & leaky valve cover. 56k. But still joy to drive.
told me it was impossible my tire give me that
kind of problem the tire start wearing out by inside at only 3000km he told me the direction have a problem i return to the dealer where i buy
the tire after rebalancing the tire the vibration was still there and he told me it was not normal
he feel something wrong with the direction the car
was going at right when you remove your hands of
the steering and vibration go off after bumps and
hole and in big cornering at highway speed i explain
to him the faq the car was almost not shaking
when cold temperature -20 and in hotter temperature the vibration was worst i took my car to the lift to find out the font suspension busing
in the lower control arm was moving twice in comparison to the rear one and the right one was worst you can see the tire going right and left in lateral movement he told
it was possible that cause my problem after a search on internet i fond jaguar has a tsb on it Some early cars might suffer a tire and steering wheel vibration which might be corrected by replacing the front suspension forward mounting bushing (TSB S204-07, May 2002).
http://www.canadiandriver.com/articles/jc/00-02s-type_a.htm am going back to the dealers with that
on Thursday he told me noting was loose in direction and give me a report on it he charge me
258$ to told me again my tire was not good the
dealer of my tire charge me noting to re balance
and test drive the car and cheek the direction
am gonna sue the dealer is sure i saw the bushing
moving and its abnormal i was installing for gec alstom electrical turbine for 10 years am not stupid in mechanic i buy this car in February the vibration was not there the bushing are to loose at front when it cold it fo sure vibration go off
the bushing is rubber and the rubber is way stiffer in minus 20 condition .......im gonna told
you whats happen when the bushing gonna be replace
Sadly, the Town Car is primarily now relegated to livery status, and the retail sales are just sauce for the elderly and dying goose. I hear Lincoln is not going to be putting a lot of R & D into the Panther cars, particularly the Town Car.
A/C . If I stop the car, turn off key and restart it blows out cold again. If you know what this is, what is involved in the repair, time and cost etc..
Thanks in advance!
vhkat1 - what were you quoted for a price to fix?
Ask your dealer for an AWA - After Warranty Adjustment. This will pay for all or part of your repair. It's at the dealer's discretion and Lincoln allows 2 of them per vehicle. Good luck.
I also have had to replace 1 back and 1 front window requlator since the warranty ran out about 8 months ago. My first lincoln. Maybe my last.
