Thanks.................
If it is a Hugo are they using the same collector up front that they did in 2001? Do they go to a camero type muffler like the Hugo? Do they have another resonator between the back muffler and the tail pipe?
If it is a true dual are then using a H tube connection between the pipes? Is there multiple mufflers in each side or just one?
No I'm looking forward to the Phx 300M meet Nov. 10th.
You would set the record for the one who comes the furtherest if you drive down and join us. The only good part of that is that you'd get to drive your M all the way.
One part rubbing alcohol, one part white distilled vinager, and two parts distilled water. It is important to use the distilled water. I usuall use a cup measure and make a quart and put it in to rinsed out windex spray bottel. It is certainly cheaper than regular cleaner.
Incase your wondering the overspray does not effect the Zanio shine. I was worried about that. Some times I don't have time to use the Zano wash, Z6, and I have to run NMIFR300M through the Phillips 66 brushless car wash. I then rush home and dry the car. Invetable there are a few water spots. I use the window cleaner and a good towel to get the water spots off and they I use the Z8 spray enhancer. The results always look fantastic. I just got my car this last summer and I have three coats of Z2 on it, after the Z1 coat. Haven't used anything else but the spray enhancer after the car washes, about once a week, for the last three months. (Damm can't spell tonight). The car is an Inferno Red and I didn't use a clay bar and I didn't use Z5. I now see the swirls in the bright sunlight and I have gotten the Z5. I hope to do two coats of Z5 and one more of Z2 before going to the Phx meet. Lots of work but the car really looks great. Wow its fantastic how slick the car feels after using the spray enhancer after the car washes.
Yeah that would be a long drive ,also as much as I love the 300 I do not own one.Sorry,but I do drive a LH car so its close enough EH?
yes the LH is a great car. After all the only difference is the trunk is cut off to make the M. Did the LH have a performance handeling package?
On the triangles on the black hood bra, I was led to believe that those triangles were located in a manner to deflect rocks headed for the most critical vision areas of the windshield and where the rocks would be likely to do the most damage via a dead-on strike. But the wind explanation makes some sense too. By the way, for those who get these bras, I found that the plastic strips that are inserted into the triangles to make them stiff go in much easier if you take some shears/scissors and round the square corners off on the end that is inserted. I have had my bra for 3 years and use Armor-All or the 2001 stuff on it whenever I put it on. It still looks good, but it has the slight wrinkles [and has had them since day 1] that others have mentioned. I have seen no vibrations or the results of same on the finish. I take it off when rain is predicted unless I am on a long trip and it will dry while on the road. I never leave it on the car sitting for any length of time while wet. Some say leaving it on in all conditions and while wet will dull the paint underneath. I don't know, but its easy on and off.
Roger - do you notice less wind coming into the cabin with that deflector? The noise is sometimes a bit much, but not too bad normally. I just don't want to block all the wind
Silverbullet - can't wait to get skiing. I lived in Boulder for 2 seasons and it was great! Wish I could ski the rockies every day Killington isn't too bad though. The longdouble you were talking about is the killington double - now it's a gondola. Still slow, but warmer...
OK - Plugs question (again With the bosch - how do you actually gap the things? It seems with 4 prongs coming out the end it could be more tough than a standard plug with a gap tool...
Craig
I had figured that...
The LH is not a model of car, it is the code name for a platform of the car we build. The LH cars are the Intrepid,Concorde,LHS and 300M.You probably thought I was referring to the LHS. I own an Intrepid . Yes the Intrepid has a handling package (the same one the 300M uses when you order PHG) you get this package when you order an R/T
Pep boys carries them, but the one near me didn't regularly carry this one. It was about $10 more.
If I didn't already have one, I'd be jumping on this one. I bought mine from Wooddash on EBay for $40 something, somewhat below their list price of $70. http://www.wooddash.com/item/CHRYSLER_Wind_Deflectors_300M_99_2001 . I may have to bid on this one just because it's such a good deal.
Silver
Ain't Philly grand! :-D
http://www.kvrperformance.com
Is that the area where you're all meeting? Isn't Frank Lloyd Wright Blvd. and Scottsdale Rd. where all those car dealers are? I stayed at a timeshare right near there. Forget the name right now, but it was right next to some famous golf course. Wish I could see all these shiny, modded out 300M's.
avalanche165-
Your car is lookin good! I like the shaved door handles.
fastdriver
seriously though, im gonna have to figure out a way to afford those 20's i was lookin at if you keep posting those pics!!! (keep em comin, bro)
phases
Think I got a good deal.......
Two other things-
I went to THAT Krispy Creme when I was there because I heard so much about them here. As far as I know, we still don't have any in CT. I really can't say that I liked them better than the Dunkin Donuts jelly ones, but to each his own-like Zaino/NO Zaino! LOL.....
Also, there was some kind of a drive thru restaurant in that shopping center that ALWAYS had a line a mile long. Never did get a chance to check it out. WHAT is so good/great about it? Don't remember the name, but everytime we drove by, there was a long line.
Thanks for saving the Krispy Creme for me. Can't make it this time. Maybe some other time though.
fastdriver
http://www.detnews.com/2001/autos/0110/27/autos-328657.htm
fastdriver
old one
Good luck with the Dunlops.
Silver
Thank You!
tom
(DUBSON300M)
