Visitor Agreement.
There are two reasons to lower a car. First is for performance -- the lowering springs are typically stiffer, thus reducing weight transfer under cornering, braking, and acceleration; and since the car is lower it has a lower center of gravity. (Note that you will get a much stiffer ride, too!)
The second reason is cosmetic. With plus sized wheels, the sidewall of the tire is much smaller making the proportions look strange. Due to an optical illusion, the gap between the tire and the fender looks bigger. Lower the car to reduce the gap.
I took my car to a suspension specialist to install the lowering springs. If you lower the car, be sure to get a four wheel alignment at the same time.
I seem to be one of the few that didn't experience problems with lowering the car. I didn't have to install a camber kit and I didn't have to change the motor mounts to correct the angle of the drive train. Speaking of this, does anybody know if the Special has any corrective pieces to handle the lower springs? If not, why would anybody else's need them?
Igor
M
sdmike2...nice play house..lucky kids.
I just snagged you a really detailed job description -- check your email.
#942 of 964 beach15 by mattanders1 Apr 04, 2002 (02:26 pm)
I could tell you that the 300M engine was harsh, and that the fit and finish weren't as good, but, in truth, it just reminds me too much a salesman's fleet car. Also, I don't know anyone under 50 that owns one.
#943 of 964 mattanders1- by fastdriver Apr 04, 2002 (02:31 pm)
mattanders1-
You live WHERE? What is like there now? Still scary? I just happened to click on your profile to see if you used to own a 300M too and saw your place of residence. Do you have your TL there with you? Those roads must be a good test of quality! ;-))
Harsh engine? The first I floored my 300M, I thought the engine was going to come through the hood! I didn't do that too often.
fastdriver
#944 of 964 by ruski Apr 04, 2002 (07:04 pm)
Beach, I did not have any problems with my 300M during the 3-year lease, except the engine speed sensor that needed to be replaced a couple of times (less than an hour for the replacement)
The tranny failure on my TL-S really made me lose confidence in Honda quality. Add to that my friend whose Accord's tranny failed... he would push the gas pedal and the car would roll back on an incline. How about that?
Also I don't think I am driving my car too aggressively. Certainly not any more aggressively than my 96 Buick Riviera or 98 Pontiac Grand Prix GTP or the 99 Chrysler 300M. All those cars had no problem with my driving habits. If anything I drove them more aggressively and faster than the TL-S because I am still babying my TL-S.
If an Acura is not supposed to be driven like many other cars, then it must be designed for sissies and grannies.
It's just like saying that someone's SUV broke because they took it off road. If they hadn't it would have been OK.
Ruski. 30 y.o.
who loved to floor his 300M engine.
__________________________________________________
Okay, so what do you all have to say?! I must concur with the fit & finish and "a salesman's fleet car", but would actually have to disagree with the engine harshness. Yeah, it did have a sort of "gruffness" to it and really didn't feel all that powerful, but when it was punched to pass or just go flying, boy did I love that growl! I've never liked cars that have silent engines (only under acceleration that is!). Creamy smoothness, a silken & quick transmission, and no knocking or chatter at idle are givens, but don't we all like a little tough growl when stepping into it?
Oh well, just can't wait to see your replies!
I don't think that position requires tons of Int'l travel, but think of how fun it will be to explain to your wife how boreing Amsterdam is.
Thank you for the info, guess I need to lower the car for wider wheel. But lowering the car has potential problem. Sound to me this depends on the suspension specialist.
I once saw a lowered wider wheel 99-00' 300M in San Jose on Coleman, wow, how macho it is! By any chance, is the owner in this board?
Muskateer, sound very easy to replace the spark plugs, why Bosch+4 needs no gapping? What happen if the plug comes with bigger gap by chance?
Can somebody tell me why spark plugs can make the difference?
Still blinking Doc.....
Oh, and the reason why I posted on the TL-S board in the first place was because the guy who made the first post I showed mentioned the 300M as one of the cars he tested before buying his new Acura. I asked him what his impressions were just to be curious and see what he thought of it, having decided to get the Acura.
On another note, wow, does that wood kit look great in Big Red!! I sometimes wish we had just gotten a '01 with the real timber instead and maybe we'd still have an M. Your car looks so much better than our Agate did with the cheap plood. Anymore mod's planned...?
http://www.ritchiefamily.com/car/consumer.jpg
On a slightly down note, CU lists the 99 M as a "used car to avoid". No details provided. Probably because of its two black marks in the table.
http://www.chrysler.com/300m/exterior/gallery.html#target1
I'll let you know how it goes.
On a side note, my Tornado Air is on it's way as we speak...or should I say as I type. I'll post pictures and give results when it's installed.
You know, nowadays transmission is my weak spot, now that I don't drive a 300M anymore.
In my case that praised Japanese turbine-like pulling sensation only lasted for 6,100 miles, then the tranny almost got me in a serious jam and needed to be replaced. Now every time I drive I am afraid it is going to happen again.
But it is still nice to see that they rated 300M so well (which I am pretty sure went against their own import-biased priciples)
Maybe now people will start bying more 300Ms and Otto will get busy again.
http://www.martelbros.com
has the best price.
Anyway, you'll be happy to hear that they rate the CL pretty high in reliability and customer satisfaction, and their reliability history for the '01 is similar to the M.
Let's say you're using the autostick to slow down and you shift it from 3rd to 2nd. This obviously increase the RPMs. Are you using any extra gas even if your foot is off of the gas pedal?
Stupid question number 2:
When car magazines do their 0-60 times, do they sit at a standstill and then tramp on the gas, or do they keep their foot on the brake while giving it gas to get the RPMs up, then take their foot off the brake and go? And do they always take it up to the red line before shifting?
#1. It uses more gas (an extreamly small amount at first) then less since, like you said your foot is off the gas. So over all the answer is less gas.
For the hi performance cars they tend to ride the brakes while giving the gas to get the rpms up. It does help a little. Something simular to the catapults on the Carriers. (brakes are on while hitting the after burners).
This concludes tire clinic 101 for today.
Last nite the defroster was on and I noticed that the top 6 inches or so would not defrost. The whole area of the thicker series of lines on the top edge do not defrost and the few inches of more widely spaced lines does not defrost.
My question is: is the entire window area supposed to completely defrost or is it normal for the upper 5 inches or so to remain undefrosted. My warranty is running out soon and I want to get this covered if its a defect? Could someone check their defrost pattern next time they use the defroster?
IF I remember correctly, my rear defogger only cleared the middle section of the window. The other wires are the radio antenna. Someone here will check.
fastdriver
The cap is all chrome with raised "300 M" lettering, no black lettering. the "M" is below the "300"
Sorry, no picture to post since I don't have a digital camera (yet!). Maybe Arby500 can put up a pic of his.
http://community.webshots.com/user/jasontalbot
