Suggest you discuss with the dealer and/or Toyota rep since you brought it in while it was under warranty and they couldn't fix the problem. Always keep good records!
I have a 2-year-old Sienna at 30k miles. I found my two front tires terribly worn out because of bad alignment. I am a very, very gentle driver and, never feel the misalignment while driving. I don't know if my warranty covers the alignment problem.
A big mistake is that I haven't aligned my car since I bought it new. Now I have to pay for the two new tires. Do you know how often should I do the alignment? Please advise. Thanks for your time.
Tony
You seem to be a knowledgeable guy on these boards and you've helped me out before
A few of us have problems with the slider doors - creaking, sometimes rattling - sounds like something loose behind the inside door handle. I really notice this on the drivers side but now I think the passenger side door is starting to exhibit similar noises.
Problem seems to occur when the van's body twists such as an uneven road or simply backing out of garage and turning in a tight circle.
Are you aware of a fix? What would you suggest short of taking it to the dealer?
Appreciate your input.
I have a 2002 Sienna LE, about 9000 miles. Earlier this spring we started hearing a noise which sounds like the valves rattling. The noise is not on all the time, just when you would expect to hear it as a regular valve noise.
The dealer could not find anything wrong with the timing of the valves. He recommended we use premium gaz. That helped a bit but then the noise came back. It's now back anytime the outside temperature is above 45F. Took it in last week, dealer said they did not understand what could be wrong and Toyota had no idea (they suggested putting an additive in the gaz to clean the engine but that did not make any difference). Any suggestions? Has anyone experienced this?
Does anyone know whether we are damaging the engine when driving with this noise?
Thanks for your help.
The one on my driver's side always seems to need "help" to retract when I unbuckle.
I found that link, www.yotarepair.com, very helpful.
I also bought some Door-Ease - seems to work (at least so far).
This is the only time I have ever seen the blinking A/C light - it is also the only time I have ever heard my belt slip. Doesn't prove your theory, but it does support it. I'm just glad to see a theory - I was clueless!
Larry
the cold air from the a/c helps clear up your foggy windshield much faster than hot air. i personally don't like this set-up coz when you set your dial to defrost, that means your a/c is on and you are burning extra gas! just imagine, you have your a/c on during the winter to clear up the foggy windshield!
my used caravan was like this and i was wondering for the longest time why i use so much gas! coz i bought the van used, i didnt have a manual so i didnt know until a friend told me.
The same thing occured two days ago and fixed itself. Since it occured again yesterday, I made a service appointment with the dealer for this morning. However, when we got home late last night and gave it one more try, the power door worked again. This morning I tried it a few more times and it worked just fine, so I decided not to go to the dealer - until next time.
We've had intermittent problems with this power door for over a year - it stopped working a few times and each time the problem went away by itself in a day or two. A previous trip to the dealer did not unveil the cause of the problem. The cold and the rain appear to be a factor (this is just a casual and unscientific observation). To us the power door is such a cool feature, we sorely miss its utility each time it stopped working, even only for a short time.
Aside from this intermittent problem with the driver side power door and an intermittent speaker (rear driver side; scratchy noise) problem, the van has been excellent.
San Jose, CA
the air (with the a/c on) is much colder compared to the air coming out when you're on defrost. try it yourself and see if you get the same results.
pop your hood open and the compressor is on the front passenger side. it is to the right of the windshield fluid bottle and below the alternator. it's shaped almost like a can of paint with a belt pulley at the end. when the a/c is on, you will see the the compressor turn. there's a black round piece attached in front of the pulley. when your a/c is on, this piece will start and stop. it turns (on) when the set temp. rises (warm) and it turns (off) when it reaches the set temp. (cold).
when the a/c is off, this piece does not move - only the belt pulley rotates.
my sister's 1997 camry turns on the a/c automatically when you switch to defrost. the a/c light comes on as well.
San Jose, CA
I like this setup because (a) it works very well, especially in this wet winter climate on Vancouver Island; (b) I believe the ac compressor is less likely to have problems since it's being run more often - not being used for a prolonged period could cause bearings to seize, IMHO.
I have aways done this manually in previous vehicles I've owned - the owner's manuals tell you this, it's not an urban legend. Simply select defrost and hit your a/c button. Adjust temp accordingly.
No, the LED (on both my 00 Toyotas) doesn't come on when you select defrost. And I don't think you can run defrost when you've got recirc selected (it defeats the purpose and only makes it the fog worse).
As to the gas mileage problem - I sort of agree that I would prefer to manage the a/c compressor myself. But a mechanic told me once years ago that you need to run your a/c compressor periodically even in the winter or the system will tend to fail earlier - seals or belts or something. Since then I've always used a/c in conjunction with defrost in the winter and I haven't had problems with my a/c systems in all the cars I've had over the years.
i wonder if you have one of those automatic climate control system.
It is so annoying as it is loud...even the technician said it was annoying. Has anyone else encountered this problem? Any suggestions? Dealership said there was not much else they could do. My reply was they better find something to do as I paid close to 30 thousand for an annoying vehicle.
Thanks in advance
I have taken it to the dealership twice to complain about the air conditioning system and both times they said nothing was wrong. You try sitting in a traffic jam when it is 100 degrees outside with two kids and no a/c. It is not a pretty sight!
Now that it is winter, we have the same problem with the heating system. Once we are stopped in traffic, the fan starts blowing cold air. A few minutes after the car starts moving, the system starts blowing warm air again.
Can anyone suggest what the problem might be?
